[postgis-tickets] [PostGIS] #4984: PostGIS Performance test suite
trac at osgeo.org
Wed Aug 25 22:06:23 PDT 2021
Reporter: robe | Owner: robe
Type: task | Status: assigned
Priority: medium | Milestone: PostGIS Performance
Component: postgis | Version: master
Keywords: |
I created a separate project at pramsey's suggestion that will be sued for
doing more intensive tests and tests against real data.
Project is here - https://git.osgeo.org/gitea/postgis/postgis-performance
I settled on using pgTap because Vicky likes it and uses it for pgRouting
so I thought I should know how to use it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4984>
