[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-462-g85ce169
git at osgeo.org
git at osgeo.org
Mon Aug 30 10:10:54 PDT 2021
the project "PostGIS".
via 85ce1695ce65294046a437450600845b635b0226 (commit)
from 45e491242d9d63beb7eac0961b16439d00c93bd4 (commit)
revisions in full, below.
commit 85ce1695ce65294046a437450600845b635b0226
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Aug 30 20:10:36 2021 +0300
KMeans: make cppcheck happy in attempt to make bessie32 happy
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index 0fa4642..c48d587 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -2544,7 +2544,7 @@ LWGEOM* lwgeom_voronoi_diagram(const LWGEOM* g, const GBOX* env, double toleranc
* @param k the number of clusters to calculate
* @param max_radius maxmimum radius of cluster before it's split
-int * lwgeom_cluster_kmeans(const LWGEOM **geoms, uint32_t ngeoms, uint32_t k, double max_radius);
+int * lwgeom_cluster_kmeans(const LWGEOM **geoms, uint32_t n, uint32_t k, double max_radius);
#include "lwinline.h"
diff --git a/liblwgeom/lwkmeans.c b/liblwgeom/lwkmeans.c
index 87863d0..dc76d35 100644
--- a/liblwgeom/lwkmeans.c
+++ b/liblwgeom/lwkmeans.c
@@ -109,7 +109,8 @@ static uint8_t
update_r(POINT4D *objs, uint32_t *clusters, uint32_t n, POINT4D *centers, double *radii, uint32_t k)
uint8_t converged = LW_TRUE;
- memset(radii, 0, sizeof(double) * k);
+ if (radii)
+ memset(radii, 0, sizeof(double) * k);
for (uint32_t i = 0; i < n; i++)
@@ -175,10 +176,8 @@ kmeans_init(POINT4D *objs, uint32_t n, POINT4D *centers, uint32_t k)
double *distances;
uint32_t p1 = 0, p2 = 0;
- uint32_t i, j;
uint32_t duplicate_count = 1; /* a point is a duplicate of itself */
- double max_dst = -1, current_distance;
- double dst_p1, dst_p2;
+ double max_dst = -1;
/* k=0, k=1: any point will do */
assert(n > 0);
@@ -189,11 +188,11 @@ kmeans_init(POINT4D *objs, uint32_t n, POINT4D *centers, uint32_t k)
/* k >= 2: find two distant points greedily */
- for (i = 1; i < n; i++)
+ for (uint32_t i = 1; i < n; i++)
/* if we found a larger distance, replace our choice */
- dst_p1 = distance3d_sqr_pt4d_pt4d(&objs[i], &objs[p1]);
- dst_p2 = distance3d_sqr_pt4d_pt4d(&objs[i], &objs[p2]);
+ double dst_p1 = distance3d_sqr_pt4d_pt4d(&objs[i], &objs[p1]);
+ double dst_p2 = distance3d_sqr_pt4d_pt4d(&objs[i], &objs[p2]);
if ((dst_p1 > max_dst) || (dst_p2 > max_dst))
if (dst_p1 > dst_p2)
@@ -229,26 +228,26 @@ kmeans_init(POINT4D *objs, uint32_t n, POINT4D *centers, uint32_t k)
distances = lwalloc(sizeof(double) * n);
/* initialize array with distance to first object */
- for (j = 0; j < n; j++)
+ for (uint32_t j = 0; j < n; j++)
distances[j] = distance3d_sqr_pt4d_pt4d(&objs[j], ¢ers[0]);
distances[p1] = -1;
distances[p2] = -1;
/* loop i on clusters, skip 0 and 1 as found already */
- for (i = 2; i < k; i++)
+ for (uint32_t i = 2; i < k; i++)
uint32_t candidate_center = 0;
double max_distance = -DBL_MAX;
/* loop j on objs */
/* empty objs and accepted clusters are already marked with distance = -1 */
if (distances[j] < 0)
continue;
/* update minimal distance with previosuly accepted cluster */
- current_distance = distance3d_sqr_pt4d_pt4d(&objs[j], ¢ers[i - 1]);
+ double current_distance = distance3d_sqr_pt4d_pt4d(&objs[j], ¢ers[i - 1]);
if (current_distance < distances[j])
distances[j] = current_distance;
@@ -273,14 +272,6 @@ kmeans_init(POINT4D *objs, uint32_t n, POINT4D *centers, uint32_t k)
-static int
-cluster_centroid_cmp(const void *a, const void *b)
- POINT4D *p1 = (POINT4D *)a;
- POINT4D *p2 = (POINT4D *)b;
- return p1->m - p2->m;
static uint32_t
kmeans(POINT4D *objs,
uint32_t *clusters,
@@ -312,18 +303,10 @@ kmeans(POINT4D *objs,
break;
/* XMeans-inspired improve_structure pass to split clusters bigger than limit into 2 */
- if (max_radius)
- for (uint32_t i = 0; i < cur_k; i++)
- centers[i].m = radii[i];
- qsort(centers, cur_k, sizeof(POINT4D), cluster_centroid_cmp);
- update_r(objs, clusters, n, centers, radii, cur_k);
- uint32_t new_k = improve_structure(objs, clusters, n, centers, radii, cur_k, max_radius);
- if (new_k == cur_k)
- break;
- cur_k = new_k;
+ uint32_t new_k = improve_structure(objs, clusters, n, centers, radii, cur_k, max_radius);
+ if (new_k == cur_k)
+ break;
+ cur_k = new_k;
if (!converged)
@@ -439,7 +422,7 @@ lwgeom_cluster_kmeans(const LWGEOM **geoms, uint32_t n, uint32_t k, double max_r
if (k > 1 || max_radius > 0)
- uint32_t *clusters_dense = lwalloc(sizeof(int) * num_non_empty);
+ uint32_t *clusters_dense = lwalloc(sizeof(uint32_t) * num_non_empty);
memset(clusters_dense, 0, sizeof(uint32_t) * num_non_empty);
converged = kmeans(objs, clusters_dense, num_non_empty, centers, radii, k, max_radius);
@@ -454,13 +437,6 @@ lwgeom_cluster_kmeans(const LWGEOM **geoms, uint32_t n, uint32_t k, double max_r
lwfree(clusters_dense);
- else if (k == 0)
- /* k=0: everything is unclusterable */
- for (uint32_t i = 0; i < n; i++)
- clusters[i] = KMEANS_NULL_CLUSTER;
- converged = LW_TRUE;
else
/* k=1: mark up NULL and non-NULL */
Summary of changes:
liblwgeom/liblwgeom.h.in | 2 +-
liblwgeom/lwkmeans.c | 54 ++++++++++++++----------------------------------
2 files changed, 16 insertions(+), 40 deletions(-)
hooks/post-receive
