[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-63-g937eaae
git at osgeo.org
git at osgeo.org
Mon Feb 8 21:36:43 PST 2021
the project "PostGIS".
via 937eaae4abd88811e9bd8ba4270471cc00f3bb3b (commit)
from a2a5961828613c10796f72753cf70980d6b414a5 (commit)
revisions in full, below.
commit 937eaae4abd88811e9bd8ba4270471cc00f3bb3b
Author: Martin Davis <mtnclimb at gmail.com>
Date: Mon Feb 8 21:36:34 2021 -0800
Improve doc Reference Valid entries
diff --git a/doc/reference_validation.xml b/doc/reference_validation.xml
index 2536473..eef1e92 100644
--- a/doc/reference_validation.xml
+++ b/doc/reference_validation.xml
@@ -42,17 +42,17 @@
<title>Description</title>
<para>
- Test if an ST_Geometry value is well-formed in 2D according to the OGC rules.
- For geometries that are invalid, the PostgreSQL NOTICE will provide details of why it is not valid.
- For geometries with 3 and 4 dimensions, the validity still only tested in 2 dimensions.
+ Tests if an ST_Geometry value is well-formed and valid in 2D according to the OGC rules.
+ For geometries with 3 and 4 dimensions, the validity is still only tested in 2 dimensions.
+ For geometries that are invalid, a PostgreSQL NOTICE is emitted providing details of why it is not valid.
</para>
<para>
-For the version with flags,
-supported <varname>flags</varname> are documented in <xref linkend="ST_IsValidDetail" />
+For the version with the <varname>flags</varname> parameter,
+supported values are documented in <xref linkend="ST_IsValidDetail" />
This version does not print a NOTICE explaining invalidity.
</para>
<para>For more information on the definition of geometry validity, refer
- to <link linkend="OGC_Validity">"Ensuring OpenGIS compliancy of geometries"</link>
+ to <xref linkend="OGC_Validity" />
</para>
<note>
<para>SQL-MM defines the result of ST_IsValid(NULL) to be 0, while
@@ -96,7 +96,6 @@ NOTICE: Self-intersection at or near point 0 0
<xref linkend="ST_IsSimple" />,
<xref linkend="ST_IsValidReason" />,
<xref linkend="ST_IsValidDetail" />,
-<xref linkend="ST_Summary" />
</para>
</refsection>
</refentry>
@@ -106,7 +105,7 @@ NOTICE: Self-intersection at or near point 0 0
<refnamediv>
<refname>ST_IsValidDetail</refname>
- <refpurpose>Returns a <varname>valid_detail</varname> row stating if a geometry is valid, and if not a reason why and a location.</refpurpose>
+ <refpurpose>Returns a <varname>valid_detail</varname> row stating if a geometry is valid or if not a reason and a location.</refpurpose>
</refnamediv>
<refsynopsisdiv>
@@ -122,20 +121,29 @@ NOTICE: Self-intersection at or near point 0 0
<refsection>
- <para>Returns a valid_detail row, formed by a boolean (valid) stating if a geometry is valid, a varchar (reason) stating a reason why it is invalid and a geometry (location) pointing out where it is invalid.</para>
+ <para>Returns a <varname>valid_detail</varname> row,
+ containing a boolean (<varname>valid</varname>) stating if a geometry is valid,
+ a varchar (<varname>reason</varname>) stating a reason why it is invalid
+ and a geometry (<varname>location</varname>) pointing out where it is invalid.</para>
- <para>Useful to substitute and improve the combination of ST_IsValid and ST_IsValidReason to generate a detailed report of invalid geometries.</para>
+ <para>Useful to improve on the combination of <xref linkend="ST_IsValid" /> and <xref linkend="ST_IsValidReason" /> to generate a detailed report of invalid geometries.</para>
<para>
-The 'flags' argument is a bitfield. It can have the following values:
- <itemizedlist>
- <listitem>
+The optional <varname>flags</varname> parameter is a bitfield. It can have the following values:
+ <itemizedlist>
+<listitem>
<para>
-1: Consider self-intersecting rings forming holes as valid.
- This is also know as "the ESRI flag".
- Note that this is against the OGC model.
+0: Use usual OGC SFS validity semantics.
</para>
- </listitem>
+</listitem>
+<listitem>
+<para>
+1: Consider certain kinds of self-touching rings (inverted shells and exverted holes) as valid.
+ This is also known as "the ESRI flag", since this is the validity model used by those tools.
+ Note that this is invalid under the OGC model.
+</para>
+</listitem>
</itemizedlist>
</para>
<para>Performed by the GEOS module.</para>
@@ -218,9 +226,9 @@ SELECT * FROM ST_IsValidDetail('LINESTRING(220227 150406,2220227 150407,222020 1
<refsection>
- <para>Returns text stating if a geometry is valid or not an if not valid, a reason why.</para>
+ <para>Returns text stating if a geometry is valid, or if invalid a reason why.</para>
- <para>Useful in combination with ST_IsValid to generate a detailed report of invalid geometries and reasons.</para>
+ <para>Useful in combination with <xref linkend="ST_IsValid" /> to generate a detailed report of invalid geometries and reasons.</para>
<para>
Allowed <varname>flags</varname> are documented in <xref linkend="ST_IsValidDetail" />.
@@ -305,7 +313,7 @@ SELECT ST_IsValidReason('LINESTRING(220227 150406,2220227 150407,222020 150410)'
<para>
The function attempts to create a valid representation of a given invalid
geometry without losing any of the input vertices.
- Already-valid geometries are returned without further intervention.
+ Valid geometries are returned unchanged.
</para>
<para>
@@ -316,8 +324,8 @@ SELECT ST_IsValidReason('LINESTRING(220227 150406,2220227 150407,222020 150410)'
<para>
In case of full or partial dimensional collapses, the output geometry
- may be a collection of lower-to-equal dimension geometries or a
- geometry of lower dimension.
+ may be a collection of lower-to-equal dimension geometries,
+ or a geometry of lower dimension.
</para>
<para>
Summary of changes:
doc/reference_validation.xml | 52 +++++++++++++++++++++++++-------------------
1 file changed, 30 insertions(+), 22 deletions(-)
hooks/post-receive
