[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-64-g88b689c
git at osgeo.org
git at osgeo.org
Tue Feb 9 06:24:24 PST 2021
the project "PostGIS".
via 88b689c8f1d3e72dde2e3ee534d48b514ccf63f3 (commit)
from 937eaae4abd88811e9bd8ba4270471cc00f3bb3b (commit)
revisions in full, below.
commit 88b689c8f1d3e72dde2e3ee534d48b514ccf63f3
Author: Sandro Santilli <strk at kbt.io>
Date: Fri Feb 5 16:24:06 2021 +0100
Allows uninstalling when having functions returning table types.
Drops tables at the end, before schemas
Drops table triggers before dropping functions
References #4841
diff --git a/utils/create_undef.pl b/utils/create_undef.pl
index d98ccce..4036801 100755
--- a/utils/create_undef.pl
+++ b/utils/create_undef.pl
@@ -4,6 +4,7 @@
# PostGIS - Spatial Types for PostgreSQL
# http://postgis.net
+# Copyright (C) 2021 Sandro Santilli <strk at kbt.io>
# Copyright (C) 2011 OpenGeo.org
# Copyright (C) 2009-2010 Paul Ramsey <pramsey at opengeo.org>
# Copyright (C) 2001-2005 Refractions Research Inc.
@@ -23,14 +24,18 @@ eval "exec perl -w $0 $@"
($#ARGV == 1) || die "Usage: perl create_undef.pl <postgis.sql> <pgsql_version #>\nCreates a new SQL script to delete all the PostGIS functions.\n";
# drops are in the following order:
-# 1. Indexing system stuff
-# 2. Meta datatables <not done>
-# 3. Aggregates
-# 3. Casts
-# 4. Operators
-# 5. Functions
-# 6. Types
-# 7. Tables
+# - Views
+# - Aggregates
+# - Operator classes and families
+# - Operators
+# - Casts
+# - Table triggers
+# - Functions except those needed for types definition
+# - Types (if unused in column types)
+# - Support functions
+# - Functions needed for types definition
+# - Tables
+# - Schemas
my @aggs = ();
my @casts = ();
@@ -44,6 +49,7 @@ my @opcs = ();
my @views = ();
my @tables = ();
my @schemas = ();
+my @triggers = ();
my $version = $ARGV[1];
@@ -103,6 +109,30 @@ while( my $line = <INPUT>)
elsif ($line =~ /^create schema \s*([\w\.]+)/i) {
push (@schemas, $1);
+ elsif ($line =~ /^create trigger \s*([\w\.]+)/i) {
+ my $trignam = $1;
+ my $trigtab = undef;
+ #print STDERR "XXX trignam: $trignam\n";
+ while ( not defined($trigtab) )
+ #print STDERR "XXX subline: $line";
+ if ( $line =~ /ON\s*([\w\.]*)/i )
+ $trigtab = $1;
+ #print STDERR "XXX trigtab: $trigtab\n";
+ last;
+ last if ( $line =~ /;\s*$/ );
+ $line = <INPUT>;
+ if ( not defined($trigtab) )
+ die "Couldn't parse CREATE TRIGGER $trignam (could not find target table)\n";
+ my $trigdef = $trignam . ' ON ' . $trigtab;
+ #print STDERR "XXX trigdef: $trigdef\n";
+ push (@triggers, $trigdef);
elsif ( $line =~ /^create operator class (\w+)/i ) {
my $opcname = $1;
my $am = '';
@@ -161,16 +191,6 @@ foreach my $view (@views)
print "DROP VIEW IF EXISTS $view;\n";
-print "-- Drop all tables.\n";
-# we reverse table definitions so foreign key constraints
-# are more likely not to get in our way
- at tables = reverse(@tables);
-foreach my $table (@tables)
- print "DROP TABLE IF EXISTS $table;\n";
print "-- Drop all aggregates.\n";
foreach my $agg (@aggs)
@@ -222,6 +242,12 @@ foreach my $cast (@casts)
+print "-- Drop all table triggers.\n";
+foreach my $tr (@triggers)
+ print "DROP TRIGGER IF EXISTS $tr;\n";
print "-- Drop all functions except " . (keys %type_funcs) . " needed for type definition.\n";
foreach my $fn (@funcs)
@@ -325,6 +351,16 @@ foreach my $fn (@type_funcs)
+print "-- Drop all tables.\n";
+# we reverse table definitions so foreign key constraints
+# are more likely not to get in our way
+ at tables = reverse(@tables);
+foreach my $table (@tables)
+ print "DROP TABLE IF EXISTS $table;\n";
print "-- Drop all schemas.\n";
if (@schemas)
Summary of changes:
utils/create_undef.pl | 72 ++++++++++++++++++++++++++++++++++++++-------------
1 file changed, 54 insertions(+), 18 deletions(-)
hooks/post-receive
