[postgis-tickets] [PostGIS] #4843: GEOS error
trac at osgeo.org
Tue Feb 9 07:18:21 PST 2021
#4843: GEOS error
Reporter: ezimanyi | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.2
Component: postgis | Version: 2.5.x
Keywords: GEOS ST_Intersects |
I have loaded into PostGIS OSM data from Belgium. I have synthetically
generated trips on the road network and I need to project the trips
(LINESTRING) to the municipalities (POLYGON). When I perform an
intersection of one trip and one municipality (whose name is Anderlecht) I
get an error from GEOS. A have isolated the trip and the municipality that
generates the error in CSV files. This is how to reproduce the error
$ createdb geoserror
$ psql geoserror
# create extension postgis
# create table trip(tripgeo geometry);
# copy trip(tripgeo) from '/path/to/file/trip.csv' CSV HEADER;
# create table municipality(municgeo geometry);
# copy municipality(municgeo) from '/path/to/file/municipality.csv' CSV
HEADER;
# select st_intersects(municgeo, tripgeo) from municipality, trip;
st_intersects
t
(1 row)
# select st_intersection(municgeo, tripgeo) from municipality, trip;
2021-02-09 16:06:13.040 CET [6575] ERROR: lwgeom_intersection: GEOS
Error: TopologyException: found non-noded intersection between LINESTRING
(476752 6.59276e+06, 476752 6.59275e+06) and LINESTRING (476753
6.59276e+06, 476752 6.59275e+06) at 476752.16199349175 6592757.7807903718
2021-02-09 16:06:13.040 CET [6575] STATEMENT: select
ERROR: lwgeom_intersection: GEOS Error: TopologyException: found non-
noded intersection between LINESTRING (476752 6.59276e+06, 476752
6.59275e+06) and LINESTRING (476753 6.59276e+06, 476752 6.59275e+06) at
# select postgis_full_version();
POSTGIS="2.5.5" [EXTENSION] PGSQL="130" GEOS="3.8.0-CAPI-1.13.1 "
PROJ="Rel. 6.3.1, February 10th, 2020" GDAL="GDAL 3.0
.4, released 2020/01/28" LIBXML="2.9.10" LIBJSON="0.13.1" RASTER
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4843>
