[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-92-g4312d04
git at osgeo.org
git at osgeo.org
Thu Feb 18 06:50:08 PST 2021
the project "PostGIS".
via 4312d040ff9ef255bc3bac58068753b0422dfd23 (commit)
from b0e380d3c1c9945ca570ff0b930d3cf0c0ced973 (commit)
revisions in full, below.
commit 4312d040ff9ef255bc3bac58068753b0422dfd23
Author: Sandro Santilli <strk at kbt.io>
Date: Thu Feb 18 15:49:51 2021 +0100
Fix docs structure
diff --git a/doc/reference_accessor.xml b/doc/reference_accessor.xml
index 5384309..1ad25f4 100644
--- a/doc/reference_accessor.xml
+++ b/doc/reference_accessor.xml
@@ -406,7 +406,7 @@ ST_Dimension
<title>Description</title>
<para>A set-returning function (SRF) that extracts the components of a geometry.
It returns a set of
- <varname><xref linkend="geometry_dump" /></varname> rows,
+ <xref linkend="geometry_dump" /> rows,
each containing a geometry (<parameter>geom</parameter> field)
and an array of integers (<parameter>path</parameter> field).
</para>
@@ -518,7 +518,7 @@ SELECT (g.gdump).path, ST_AsEWKT((g.gdump).geom) as wkt
<para>A set-returning function (SRF) that extracts the coordinates (vertices) of a geometry.
It returns a set of
</para>
@@ -759,14 +759,15 @@ SELECT (g.gdump).path, ST_AsEWKT((g.gdump).geom) as wkt
<para>A set-returning function (SRF) that extracts the rings of a polygon.
- It returns a set of <varname><xref linkend="geometry_dump" /></varname> rows,
+ It returns a set of <xref linkend="geometry_dump" /> rows,
</para>
<para>
- The <parameter>geom</parameter> field contains each ring as a POLYGON.</para>
+ The <parameter>geom</parameter> field contains each ring as a POLYGON.
The <parameter>path</parameter> field is an integer array of length 1 containing the polygon ring index.
The exterior ring (shell) has index 0. The interior rings (holes) have indices of 1 and higher.
+ </para>
<note><para>This only works for POLYGON geometries. It does not work for MULTIPOLYGONS</para></note>
<para>Availability: PostGIS 1.1.3. Requires PostgreSQL 7.3 or higher.</para>
Summary of changes:
doc/reference_accessor.xml | 9 +++++----
1 file changed, 5 insertions(+), 4 deletions(-)
hooks/post-receive
