[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-93-g5363724
    git at osgeo.org
    git at osgeo.org
    Thu Feb 18 08:44:24 PST 2021
the project "PostGIS".
       via  5363724d5d1c1cbc1bf6eb3c42c18b970c192c14 (commit)
      from  4312d040ff9ef255bc3bac58068753b0422dfd23 (commit)
revisions in full, below.
commit 5363724d5d1c1cbc1bf6eb3c42c18b970c192c14
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Feb 15 16:09:11 2021 +0100
    Implement TopoGeom_addTopoGeom(tgt TopoGeometry, src TopoGeometry)
    Closes #4851
    Includes regression tests, documentation and NEWS entry
diff --git a/NEWS b/NEWS
index 741ad29..bcb4d2a 100644
--- a/NEWS
+++ b/NEWS
@@ -12,6 +12,7 @@ PostGIS 3.2.0
  * New features*
   - #4841, FindTopology to quickly get a topology record (Sandro Santilli)
+  - #4851, TopoGeom_addTopoGeom function (Sandro Santilli)
 PostGIS 3.1.0
 2020/12/18
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index 574fa6e..8e60a77 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -3250,6 +3250,65 @@ UPDATE mylayer SET tg = TopoGeom_remElement(tg, '{43,3}');
 			</refsection>
 		</refentry>
+    <refentry id="TopoGeom_addTopoGeom">
+			<refnamediv>
+				<refname>TopoGeom_addTopoGeom</refname>
+				<refpurpose>Adds element of a TopoGeometry to the definition of another TopoGeometry.</refpurpose>
+			</refnamediv>
+			<refsynopsisdiv>
+				<funcsynopsis>
+					<funcprototype>
+					<funcdef>topogeometry <function>TopoGeom_addTopoGeom</function></funcdef>
+					<paramdef><type>topogeometry </type> <parameter>tgt</parameter></paramdef>
+                    <paramdef><type>topogeometry </type> <parameter>src</parameter></paramdef>
+					</funcprototype>
+				</funcsynopsis>
+			</refsynopsisdiv>
+			<refsection>
+                <title>Description</title>
+                <para>
+Adds the elements of a <xref linkend="topogeometry" /> to the definition of
+another TopoGeometry, possibly changing its cached type (type attribute)
+to a collection, if needed to hold all elements in the source object.
+                </para>
+                <para>
+The two TopoGeometry objects need be defined against the *same*
+topology and, if hierarchically defined, need be composed by elements
+of the same child layer.
+                </para>
+                <!-- use this format if new function -->
+                <para>Availability: 3.2</para>
+			</refsection>
+			<refsection>
+				<title>Examples</title>
+        <programlisting>
+-- Set an "overall" TopoGeometry value to be composed by all
+-- elements of specific TopoGeometry values
+UPDATE mylayer SET tg_overall = TopoGeom_addTopogeometry(
+    TopoGeom_addTopoGeometry(
+        clearTopoGeom(tg_overall),
+        tg_specific1
+    tg_specific1
+				</programlisting>
+			</refsection>
+			<!-- Optionally add a "See Also" section -->
+			<refsection>
+				<title>See Also</title>
+        <para>
+<xref linkend="TopoGeom_addElement" />,
+<xref linkend="clearTopoGeom" />,
+<xref linkend="CreateTopoGeom" />
+        </para>
+			</refsection>
+		</refentry>
     <refentry id="toTopoGeom_editor_proxy">
 			<refnamediv>
         <refname>toTopoGeom</refname>
diff --git a/topology/sql/topogeometry/topogeom_edit.sql.in b/topology/sql/topogeometry/topogeom_edit.sql.in
index 0889bb7..6b93bf8 100644
--- a/topology/sql/topogeometry/topogeom_edit.sql.in
+++ b/topology/sql/topogeometry/topogeom_edit.sql.in
@@ -93,3 +93,129 @@ END
 LANGUAGE 'plpgsql' VOLATILE STRICT;
+-- Add the component of a TopoGeometry to the definition of
+-- another TopoGeometry.
+-- The two TopoGeometry objects need to be defined on the *same*
+-- topology and need to be compatible (both simple or built over
+-- the same child layer, and the target TopoGeometry needs to allow
+-- for holding components of the type found in the source TopoGeometry)
+CREATE OR REPLACE FUNCTION topology.TopoGeom_addTopoGeom(tgt topology.TopoGeometry, src topology.TopoGeometry)
+  RETURNS topology.TopoGeometry
+AS
+$BODY$
+DECLARE
+  sql TEXT;
+  topo topology.topology;
+  srcElementTypes int[];
+  srcLayer topology.layer;
+  tgtLayer topology.layer;
+  maxElemType int;
+BEGIN
+  -- Get topology information
+  topo := topology.FindTopology(topology_id(src));
+#ifdef POSTGIS_TOPOLOGY_DEBUG
+  RAISE DEBUG 'Source TopoGeometry is "%", its topology_id is "%"', src, topo.id;
+#endif
+  IF topology_id(src) != topology_id(tgt) THEN
+    RAISE EXCEPTION 'Source and target TopoGeometry objects need be defined on the same topology';
+  END IF;
+  RAISE DEBUG 'Target TopoGeometry is "%"', tgt;
+#endif
+  SELECT * FROM topology.layer
+  WHERE topology_id = topo.id
+    AND layer_id = layer_id(src)
+  INTO srcLayer;
+    AND layer_id = layer_id(tgt)
+  INTO tgtLayer;
+  -- Check simple/hierarchical compatibility
+  IF srcLayer.child_id IS NULL THEN
+    IF srcLayer.child_id IS NOT NULL THEN
+      RAISE EXCEPTION 'Cannot add components of hierarchical TopoGeometry to a non-hierarchical TopoGeometry';
+    END IF;
+  ELSIF tgtLayer.child_id IS NULL THEN
+      RAISE EXCEPTION 'Cannot add components of non-hierarchical TopoGeometry to a hierarchical TopoGeometry';
+  ELSIF tgtLayer.child_id != srcLayer.childId THEN
+      RAISE EXCEPTION 'Cannot add components of hierarchical TopoGeometry to a hierarchical TopoGeometry based on different layer';
+  END IF;
+  -- Add every element of the source TopoGeometry to
+  -- the definition of the target TopoGeometry
+  sql := format($$
+WITH inserted AS (
+  INSERT INTO %1$I.relation(
+    topogeo_id,
+    layer_id,
+    element_id,
+    element_type
+  SELECT %2$s, %3$s, element_id, element_type
+  FROM %1$I.relation
+  WHERE topogeo_id = %4$L
+  AND layer_id = %5$L
+  EXCEPT
+  WHERE topogeo_id = %2$L
+  AND layer_id = %3$L
+  RETURNING element_type
+SELECT array_agg(DISTINCT element_type) FROM inserted
+    topo.name,      -- %1
+    id(tgt),        -- %2
+    layer_id(tgt),  -- %3
+    id(src),        -- %4
+    layer_id(src)   -- %5
+  RAISE DEBUG 'SQL: %', sql;
+  EXECUTE sql INTO srcElementTypes;
+  -- TODO: Check layer's feature_type compatibility ?
+  -- or let the relationTrigger take care of it ?
+--  IF tgtLayer.feature_type != 4 THEN -- 'mixed' typed target can accept anything
+--    IF srcLayer.feature_type != tgtLayer.feature_type THEN
+--    END IF;
+--  END IF;
+  RAISE DEBUG 'Target type: %', type(tgt);
+  RAISE DEBUG 'Detected source element types: %', srcElementTypes;
+  -- Check if target TopoGeometry type needs be changed
+  IF type(tgt) != 4 -- collection TopoGeometry accept anything
+  THEN
+    IF array_upper(srcElementTypes, 1) > 1
+    OR srcElementTypes[1] != tgt.type
+    THEN
+      -- source is mixed-typed or typed differently from
+      -- target, so we turn target type to collection
+      RAISE DEBUG 'Changing target element type to collection';
+      tgt.type = 4;
+    END IF;
+  END IF;
+  RETURN tgt;
+END
+$BODY$
+LANGUAGE 'plpgsql' VOLATILE STRICT;
diff --git a/topology/test/regress/topogeom_addtopogeom.sql b/topology/test/regress/topogeom_addtopogeom.sql
new file mode 100644
index 0000000..59e630b
--- /dev/null
+++ b/topology/test/regress/topogeom_addtopogeom.sql
@@ -0,0 +1,81 @@
+\set VERBOSITY terse
+set client_min_messages to WARNING;
+-- See https://trac.osgeo.org/postgis/ticket/4851
+select NULL FROM createtopology('tt');
+-- Create simple puntal layer (will be layer 1)
+CREATE TABLE tt.f_puntal(id serial);
+SELECT 'simple_puntual_layer', AddTopoGeometryColumn('tt', 'tt', 'f_puntal','g','POINT');
+-- Create a lineal layer (will be layer 2)
+CREATE TABLE tt.f_lineal(id serial);
+SELECT 'simple_lineal_layer', AddTopoGeometryColumn('tt', 'tt', 'f_lineal','g','LINE');
+-- Create an areal layer (will be layer 3)
+CREATE TABLE tt.f_areal(id serial);
+SELECT 'simple_areal_layer', AddTopoGeometryColumn('tt', 'tt', 'f_areal','g','POLYGON');
+-- Create a collection layer (will be layer 4)
+CREATE TABLE tt.f_coll(id serial);
+SELECT 'simple_collection_layer', AddTopoGeometryColumn('tt', 'tt', 'f_coll','g','COLLECTION');
+-- Create a hierarchical puntal layer (will be layer 5)
+CREATE TABLE tt.f_hier_puntal(id serial);
+SELECT 'hierarchical_puntual_layer', AddTopoGeometryColumn('tt', 'tt', 'f_hier_puntal','g','POINT', 1);
+-- point to point
+SELECT 'tg2tg.poi2poi', ST_AsText(TopoGeom_addTopoGeom(
+    toTopoGeom('POINT(1 1)', 'tt', 1),
+    toTopoGeom('POINT(0 0)', 'tt', 1)
+-- point to mixed
+SELECT 'tg2tg.poi2mix', ST_AsText(TopoGeom_addTopoGeom(
+    toTopoGeom('LINESTRING(1 1, 0 0)', 'tt', 4),
+-- line to line
+SELECT 'tg2tg.lin2lin', ST_AsText(TopoGeom_addTopoGeom(
+    toTopoGeom('LINESTRING(0 1, 2 1)', 'tt', 2),
+    toTopoGeom('LINESTRING(0 0, 2 0)', 'tt', 2)
+-- line to mixed
+SELECT 'tg2tg.lin2mix', ST_AsText(TopoGeom_addTopoGeom(
+    toTopoGeom('POINT(0 0)', 'tt', 4),
+-- poly to poly
+SELECT 'tg2tg.pol2pol', ST_AsText(ST_Simplify(ST_Normalize(TopoGeom_addTopoGeom(
+    toTopoGeom(ST_MakeEnvelope(0,10,20,10), 'tt', 3),
+    toTopoGeom(ST_MakeEnvelope(0,0,10,10), 'tt', 3)
+)::geometry), 0));
+-- poly to mixed
+    toTopoGeom(ST_MakePoint(0,0), 'tt', 4),
+    toTopoGeom(ST_MakeEnvelope(0,0,10,10), 'tt', 4)
+)::geometry), 0));
+-- TODO: point to point (hierarchical)
+-- TODO: point to mixed (hierarchical)
+-- TODO: line to line (hierarchical)
+-- TODO: line to mixed (hierarchical)
+-- TODO: poly to poly (hierarchical)
+-- TODO: poly to mixed (hierarchical)
+-- TODO: BOGUS calls (incompatible merges)
+DROP TABLE tt.f_coll;
+DROP TABLE tt.f_areal;
+DROP TABLE tt.f_lineal;
+DROP TABLE tt.f_hier_puntal;
+DROP TABLE tt.f_puntal;
+select NULL from droptopology('tt');
diff --git a/topology/test/regress/topogeom_addtopogeom_expected b/topology/test/regress/topogeom_addtopogeom_expected
index 0000000..1abdecc
--- /dev/null
+++ b/topology/test/regress/topogeom_addtopogeom_expected
@@ -0,0 +1,11 @@
+simple_puntual_layer|1
+simple_lineal_layer|2
+simple_areal_layer|3
+simple_collection_layer|4
+hierarchical_puntual_layer|5
+tg2tg.poi2poi|MULTIPOINT(0 0,1 1)
+tg2tg.poi2mix|GEOMETRYCOLLECTION(LINESTRING(1 1,0 0),POINT(0 0))
+tg2tg.lin2lin|MULTILINESTRING((0 0,2 0),(0 1,1 1,2 1))
+tg2tg.lin2mix|GEOMETRYCOLLECTION(LINESTRING(0 0,2 0),POINT(0 0))
+tg2tg.pol2pol|MULTIPOLYGON(((0 0,0 10,10 10,10 0,0 0)))
+tg2tg.pol2pol|GEOMETRYCOLLECTION(POLYGON((0 0,0 10,10 10,10 0,0 0)),POINT(0 0))
diff --git a/topology/test/regress/totopogeom.sql b/topology/test/regress/totopogeom.sql
index 9d93521..91bb7cf 100644
--- a/topology/test/regress/totopogeom.sql
+++ b/topology/test/regress/totopogeom.sql
@@ -1,5 +1,5 @@
-set client_min_messages to ERROR;
 select 'create', createtopology('tt') > 0;
@@ -199,7 +199,9 @@ SELECT 'tgup1.3', id(t.g), st_area(t.g), count(r.*)
   WHERE t.id = -1 AND r.layer_id = 4 AND r.topogeo_id = id(t.g)
   GROUP BY id(t.g), st_area(t.g);
 -- http://trac.osgeo.org/postgis/ticket/3359
 -- NOTE: requires identifier of the second edge to be 2
 TRUNCATE tt.relation CASCADE;
 TRUNCATE tt.edge_data CASCADE;
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index fa4025f..be7cf85 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -59,6 +59,7 @@ TESTS += \
 	$(topsrcdir)/topology/test/regress/topogeo_addpoint.sql \
 	$(topsrcdir)/topology/test/regress/topogeo_addpolygon.sql \
   $(topsrcdir)/topology/test/regress/topogeom_edit.sql \
+  $(topsrcdir)/topology/test/regress/topogeom_addtopogeom.sql \
 	$(topsrcdir)/topology/test/regress/topogeometry_type.sql \
 	$(topsrcdir)/topology/test/regress/topojson.sql \
   $(topsrcdir)/topology/test/regress/topologysummary.sql \
Summary of changes:
 NEWS                                               |   1 +
 doc/extras_topology.xml                            |  59 ++++++++++
 topology/sql/topogeometry/topogeom_edit.sql.in     | 126 +++++++++++++++++++++
 topology/test/regress/topogeom_addtopogeom.sql     |  81 +++++++++++++
 .../test/regress/topogeom_addtopogeom_expected     |  11 ++
 topology/test/regress/totopogeom.sql               |   4 +-
 topology/test/tests.mk                             |   1 +
 7 files changed, 282 insertions(+), 1 deletion(-)
 create mode 100644 topology/test/regress/topogeom_addtopogeom.sql
 create mode 100644 topology/test/regress/topogeom_addtopogeom_expected
hooks/post-receive
