[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-259-g424ce73
Thu Jul 1 11:36:54 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  424ce7343f5165fa7cb1391ded0b3e376b9cbc15 (commit)
       via  9b44f27f8393d723aed5e1f5db8defacd36f8659 (commit)
       via  e229449130861affa0952380bb9bc4de03056610 (commit)
      from  ba050a61b052dc3f559b6aace630dad191eabb27 (commit)
revisions in full, below.
commit 424ce7343f5165fa7cb1391ded0b3e376b9cbc15
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 1 18:36:19 2021 +0200
    Add optional bbox parameter to ValidateTopology
    Closes #4936
    Includes test and documentation.
diff --git a/NEWS b/NEWS
index 592b97f..e87d347 100644
--- a/NEWS
+++ b/NEWS
@@ -6,6 +6,7 @@ PostGIS 3.2.0
   - #4933, topology.GetFaceByPoint will not work with topologies having invalid edge linking.
  * Enhancements *
+  - #4936, Bounding box limited ValidateTopology (Sandro Santilli)
   - #4933, Speed up topology building in presence of big faces (Sandro Santilli)
   - #3233, ValidateTopology check for node's containing_face (Sandro Santilli)
   - #4830, ValidateTopology check for edges side face containment
diff --git a/doc/extras_topology.xml b/doc/extras_topology.xml
index c918e8b..952b5fb 100644
--- a/doc/extras_topology.xml
+++ b/doc/extras_topology.xml
@@ -558,7 +558,8 @@ FROM topology.layer;
 				<funcsynopsis>
 					<funcprototype>
 					<funcdef>setof validatetopology_returntype <function>ValidateTopology</function></funcdef>
-					<paramdef><type>varchar </type> <parameter>topology_schema_name</parameter></paramdef>
+					<paramdef><type>varchar </type> <parameter>toponame</parameter></paramdef>
+					<paramdef choice="opt"><type>geometry</type> <parameter>bbox</parameter></paramdef>
 					</funcprototype>
 				</funcsynopsis>
 			</refsynopsisdiv>
@@ -566,7 +567,13 @@ FROM topology.layer;
 			<refsection>
                 <title>Description</title>
-                <para>Returns a set of <xref linkend="validatetopology_returntype"/> objects detailing issues with topology. List of possible errors and what the returned ids represent are displayed below:</para>
+                <para>
+Returns a set of <xref linkend="validatetopology_returntype"/> objects
+detailing issues with topology, optionally limiting the check to the
+area specified by the <varname>bbox</varname> parameter.
+                </para>
+                <para>List of possible errors and what the returned ids represent are displayed below:</para>
                   <informaltable rowsep="1" frame="all">
                     <tgroup cols="3">
@@ -631,6 +638,7 @@ FROM topology.layer;
 	<!-- use this format if not a new function but functionality enhanced -->
                 <para>Enhanced: 2.0.0 more efficient edge crossing detection and fixes for false positives that were existent in prior versions.</para>
                 <para>Changed: 2.2.0 values for id1 and id2 were swapped for 'edge crosses node' to be consistent with error description.</para>
+                <para>Changed: 3.2.0 added optional bbox parameter.</para>
 			</refsection>
diff --git a/topology/test/invalid_topology.sql b/topology/test/invalid_topology.sql
index c38072c..1bcd260 100644
--- a/topology/test/invalid_topology.sql
+++ b/topology/test/invalid_topology.sql
@@ -150,7 +150,19 @@ INSERT INTO invalid_topology.edge VALUES(32, 4, 4, 31, -31, 12, 12,
 INSERT INTO invalid_topology.edge VALUES(33, 3, 3, 28, 28, 13, 13,
   '01020000000100000000000000000039400000000000804140');
--- Validate topology
-SELECT * from topology.validatetopology('invalid_topology');
+-- Set face mbr based on referencing edges mbr
+UPDATE invalid_topology.face f
+SET mbr = (
+  WITH env AS (
+    SELECT ST_Envelope(ST_Union(ST_Envelope(e.geom))) env
+    FROM invalid_topology.edge e
+    WHERE
+      ( e.left_face = f.face_id OR e.right_face = f.face_id )
+  SELECT ST_MakeEnvelope(st_xmin(env), st_ymin(env), st_xmax(env), st_ymax(env))
+  FROM env
+WHERE face_id > 0;
 END;
diff --git a/topology/test/regress/legacy_invalid.sql b/topology/test/regress/legacy_invalid.sql
index bb2f916..9afad61 100644
--- a/topology/test/regress/legacy_invalid.sql
+++ b/topology/test/regress/legacy_invalid.sql
@@ -2,5 +2,58 @@ set client_min_messages to WARNING;
 \i ../invalid_topology.sql
+-- Validate full topology, store invalidities in a table
+CREATE TABLE invalid_topology.invalidities AS
+SELECT * from topology.validatetopology('invalid_topology');
+SELECT * FROM invalid_topology.invalidities;
+-- Test bbox-limited checking
+-- See https://trac.osgeo.org/postgis/ticket/4936
+CREATE TABLE invalid_topology.grid_invalidities AS
+WITH
+extents AS (
+  SELECT ST_Envelope(ST_Extent(geom)) env
+    UNION
+  FROM invalid_topology.node
+    UNION
+  SELECT ST_Envelope(ST_Extent(mbr))
+  FROM invalid_topology.face
+topo_envelope AS (
+  SELECT ST_Envelope(ST_Union(env)) env
+  FROM extents
+-- roughly a 8x5 grid on whole topology extent
+grid AS (
+  SELECT *
+  FROM ST_SquareGrid(
+      ST_Length(
+        ST_BoundingDiagonal(
+          ( SELECT env FROM topo_envelope )
+      )/8.0,
+SELECT g.i, g.j, vt.*
+FROM grid g,
+LATERAL topology.validatetopology('invalid_topology', g.geom) vt ;
+-- Check that all errors found by the catch-all validator
+-- are also cought by the per-cell validator
+CREATE TABLE invalid_topology.missing_invalidities AS
+  SELECT error, id1, id2 FROM invalid_topology.invalidities
+    EXCEPT
+  SELECT error, id1, id2 FROM invalid_topology.grid_invalidities
+SELECT '#4936', 'missing_count', count(*)
+FROM invalid_topology.missing_invalidities ;
+SELECT '#4936', 'missing', *
 -- clean up
 SELECT topology.DropTopology('invalid_topology');
diff --git a/topology/test/regress/legacy_invalid_expected b/topology/test/regress/legacy_invalid_expected
index bc2cd65..ffcf2b0 100644
--- a/topology/test/regress/legacy_invalid_expected
+++ b/topology/test/regress/legacy_invalid_expected
@@ -22,4 +22,7 @@ not-isolated node has not-null containing_face|4|
 edge not covered by both its side faces|27|
 edge not covered by both its side faces|28|
 edge not covered by both its side faces|30|
+#4936|missing_count|2
+#4936|missing|face has no rings|10|
+#4936|missing|face without edges|10|
 Topology 'invalid_topology' dropped
diff --git a/topology/topology.sql.in b/topology/topology.sql.in
index fa672ba..fcff96b 100644
--- a/topology/topology.sql.in
+++ b/topology/topology.sql.in
@@ -1438,12 +1438,15 @@ LANGUAGE 'plpgsql' VOLATILE STRICT;
 CREATE CAST (topology.TopoGeometry AS Geometry) WITH FUNCTION topology.Geometry(topology.TopoGeometry) AS IMPLICIT;
---  ValidateTopology(toponame)
+--  ValidateTopology(toponame, [bbox])
 --  Return a Set of ValidateTopology_ReturnType containing
 --  informations on all topology inconsistencies
-CREATE OR REPLACE FUNCTION topology.ValidateTopology(toponame varchar)
+-- Availability: 1.0.0
+-- Changed: 3.2.0 - add bbox optional parameter
+CREATE OR REPLACE FUNCTION topology.ValidateTopology(toponame varchar, bbox geometry DEFAULT NULL)
   RETURNS setof topology.ValidateTopology_ReturnType
 AS
@@ -1489,6 +1492,14 @@ BEGIN
       node b
     WHERE a.node_id < b.node_id
     AND ST_DWithin(a.geom, b.geom, 0) -- NOTE: see #1625 and #1789
+    AND (
+      bbox IS NULL
+      OR (
+        a.geom && bbox
+        AND
+        b.geom && bbox
   LOOP
     retrec.error = 'coincident nodes';
     retrec.id1 = rec.id1;
@@ -1507,6 +1518,14 @@ BEGIN
     WHERE e.start_node != n.node_id
     AND e.end_node != n.node_id
     AND ST_Within(n.geom, e.geom)
+    AND (
+      bbox IS NULL
+      OR (
+        n.geom && bbox
+        AND
+        e.geom && bbox
   LOOP
     retrec.error = 'edge crosses node';
     retrec.id1 = rec.eid; -- edge_id
@@ -1518,7 +1537,12 @@ BEGIN
   RAISE DEBUG 'Checking for invalid or not-simple edges';
   FOR rec IN
     SELECT e.geom, e.edge_id as id1, e.left_face, e.right_face
-    FROM edge e ORDER BY edge_id
+    FROM edge e
+    WHERE (
+      bbox IS NULL
+      OR e.geom && bbox
+    ORDER BY edge_id
   LOOP --{
     -- Any invalid edge becomes a cancer for higher level complexes
@@ -1577,6 +1601,14 @@ BEGIN
           NOT e2.edge_id = ANY (invalid_edges)
+      AND (
+        bbox IS NULL
+        OR (
+          e1.geom && bbox
+          AND
+          e2.geom && bbox
   LOOP --{
     IF ST_RelateMatch(rec.im, 'FF1F**1*2') THEN
@@ -1642,6 +1674,10 @@ BEGIN
       node n
     WHERE e.start_node = n.node_id
     AND NOT ST_Equals(ST_StartPoint(e.geom), n.geom)
+    AND (
+      bbox IS NULL
+      OR e.geom && bbox
   LOOP --{
     retrec.error = 'edge start node geometry mis-match';
@@ -1659,6 +1695,10 @@ BEGIN
       node n
     WHERE e.end_node = n.node_id
     AND NOT ST_Equals(ST_EndPoint(e.geom), n.geom)
+    AND (
+      bbox IS NULL
+      OR e.geom && bbox
   LOOP --{
     retrec.error = 'edge end node geometry mis-match';
@@ -1671,7 +1711,12 @@ BEGIN
   FOR rec IN
     SELECT face_id as id1
     FROM face
-    WHERE face_id > 0 EXCEPT (
+    WHERE face_id > 0
+    AND (
+      bbox IS NULL
+      OR mbr && bbox
+    EXCEPT (
       SELECT left_face FROM edge
       UNION
       SELECT right_face FROM edge
@@ -1704,6 +1749,10 @@ BEGIN
         TRUE
       END
+    AND (
+      bbox IS NULL
+      OR mbr && bbox
   -- Build a gist index on geom
@@ -1783,13 +1832,16 @@ BEGIN
     WHERE
-       e.edge_id IS NULL AND (
-        n.containing_face != f.face_id
-        OR ( n.containing_face IS NULL AND f.face_id IS NOT NULL )
-     OR ( n.containing_face IS NOT NULL AND e.edge_id IS NOT NULL )
+     ( bbox IS NULL OR n.geom && bbox )
+     AND (
+        e.edge_id IS NULL AND (
+          n.containing_face != f.face_id
+          OR ( n.containing_face IS NULL AND f.face_id IS NOT NULL )
+      OR ( n.containing_face IS NOT NULL AND e.edge_id IS NOT NULL)
     GROUP BY n.node_id, n.containing_face
   LOOP --{
     IF rec.edge_id IS NOT NULL THEN
@@ -1816,7 +1868,14 @@ BEGIN
         edge_data e
         LEFT JOIN face_check f ON ( ST_Covers(f.geom, e.geom) )
         -- skip invalid edges (toxic, and will be already reported previously)
-        WHERE invalid_edges IS NULL OR NOT e.edge_id = ANY(invalid_edges)
+        WHERE
+            invalid_edges IS NULL OR NOT e.edge_id = ANY(invalid_edges)
+          AND
+            bbox IS NULL OR e.geom && bbox
       GROUP BY
         e.edge_id, e.left_face, e.right_face
@@ -1859,8 +1918,8 @@ BEGIN
   RETURN;
 END
-LANGUAGE 'plpgsql' VOLATILE STRICT;
--- } ValidateTopology(toponame)
+LANGUAGE 'plpgsql' VOLATILE; -- NOTE: we need VOLATILE to use SHOW
+--} ValidateTopology(toponame, bbox)
 --  CreateTopology(name, SRID, precision, hasZ)
commit 9b44f27f8393d723aed5e1f5db8defacd36f8659
Date:   Thu Jul 1 17:56:39 2021 +0200
    ValidateTopology: error out if topology schema is unexistent
    ... and warn if it's not registered in topology.topology
index 67da649..fa672ba 100644
@@ -1457,6 +1457,24 @@ DECLARE
   search_path_backup text;
 BEGIN
+  IF NOT EXISTS (
+    SELECT oid
+    FROM pg_catalog.pg_namespace
+    WHERE nspname = toponame
+  THEN
+    RAISE EXCEPTION 'Topology schema % does not exist', toponame;
+  END IF;
+  IF NOT EXISTS (
+    SELECT id
+    FROM topology.topology
+    WHERE name = toponame
+  THEN
+    RAISE WARNING 'Topology % is not registered in topology.topology', toponame;
+  END IF;
   EXECUTE 'SHOW search_path' INTO search_path_backup;
   EXECUTE 'SET search_PATH TO ' || quote_ident(toponame) || ','
                                 || search_path_backup;
commit e229449130861affa0952380bb9bc4de03056610
Date:   Thu Jul 1 17:46:03 2021 +0200
    Add DEBUG output in ValidateTopology
    Since it's an expensive operation the messages can give an idea
    of what's happening, during the operations
index 8b83e38..67da649 100644
@@ -1463,6 +1463,7 @@ BEGIN
   -- Check for coincident nodes
+  RAISE DEBUG 'Checking for coincident nodes';
   FOR rec IN
     SELECT a.node_id as id1, b.node_id as id2
     FROM
@@ -1479,6 +1480,7 @@ BEGIN
   -- Check for edge crossed nodes
   -- TODO: do this in the single edge loop
+  RAISE DEBUG 'Checking for edges crossing nodes';
   FOR rec IN
     SELECT n.node_id as nid, e.edge_id as eid
     FROM
@@ -1495,10 +1497,11 @@ BEGIN
   END LOOP;
   -- Scan all edges
+  RAISE DEBUG 'Checking for invalid or not-simple edges';
   FOR rec IN
-  LOOP
+  LOOP --{
     IF NOT ST_IsValid(rec.geom) THEN
@@ -1532,9 +1535,10 @@ BEGIN
       RETURN NEXT retrec;
     END IF;
-  END LOOP;
+  END LOOP; --}
   -- Check for edge crossing
+  RAISE DEBUG 'Checking for crossing edges';
   FOR rec IN
     SELECT
       e1.edge_id as id1,
@@ -1555,7 +1559,7 @@ BEGIN
-  LOOP
+  LOOP --{
       CONTINUE; -- no interior intersection
@@ -1608,10 +1612,11 @@ BEGIN
     retrec.id2 = rec.id2;
     RETURN NEXT retrec;
-  END LOOP;
+  END LOOP; --}
   -- Check for edge start_node geometry mis-match
   -- TODO: move this in the first edge table scan
+  RAISE DEBUG 'Checking for edges start_node mismatch';
   FOR rec IN
     SELECT e.edge_id as id1, n.node_id as id2
     FROM
@@ -1619,15 +1624,16 @@ BEGIN
       node n
-  LOOP
+  LOOP --{
     RETURN NEXT retrec;
-  END LOOP;
+  END LOOP; --}
   -- Check for edge end_node geometry mis-match
+  RAISE DEBUG 'Checking for edges end_node mismatch';
   FOR rec IN
     FROM
@@ -1635,14 +1641,15 @@ BEGIN
       node n
-  LOOP
+  LOOP --{
     RETURN NEXT retrec;
-  END LOOP;
+  END LOOP; --}
   -- Check for faces w/out edges
+  RAISE DEBUG 'Checking for faces without edges';
   FOR rec IN
     FROM face
@@ -1651,16 +1658,18 @@ BEGIN
       UNION
-  LOOP
+  LOOP --{
     retrec.error = 'face without edges';
     retrec.id2 = NULL;
     RETURN NEXT retrec;
-  END LOOP;
+  END LOOP; --}
   -- Now create a temporary table to construct all face geometries
   -- for checking their consistency
+  RAISE DEBUG 'Constructing geometry of all faces';
   CREATE TEMP TABLE face_check ON COMMIT DROP AS
   SELECT
     face_id,
@@ -1686,19 +1695,21 @@ BEGIN
   CREATE INDEX "face_check_bt" ON face_check (face_id);
   -- Scan the table looking for NULL geometries
+  RAISE DEBUG 'Checking for faces with no rings';
   FOR rec IN
     SELECT face_id FROM face_check
     WHERE geom IS NULL OR ST_IsEmpty(geom)
-  LOOP
+  LOOP --{
     -- Face missing !
     retrec.error := 'face has no rings';
     retrec.id1 := rec.face_id;
     retrec.id2 := NULL;
     RETURN NEXT retrec;
-  END LOOP;
+  END LOOP; --}
   -- Scan the table looking for overlap or containment
   -- TODO: also check for MBR consistency
+  RAISE DEBUG 'Checking for face-in-face';
   FOR rec IN
     SELECT
       f1.geom,
@@ -1710,7 +1721,7 @@ BEGIN
       face_check f2
       WHERE f1.face_id < f2.face_id
       AND f1.geom && f2.geom
-  LOOP
+  LOOP --{
     -- Face overlap
     IF ST_RelateMatch(rec.im, 'T*T***T**') THEN
@@ -1736,9 +1747,10 @@ BEGIN
     RETURN NEXT retrec;
     END IF;
-  END LOOP;
+  END LOOP; --}
   -- Check nodes have correct containing_face (#3233)
+  RAISE DEBUG 'Checking for node containing_face correctness';
   FOR rec IN
     SELECT
       n.node_id,
@@ -1761,7 +1773,7 @@ BEGIN
-  LOOP
+  LOOP --{
       -- node is not really isolated
       retrec.error := 'not-isolated node has not-null containing_face';
@@ -1771,9 +1783,10 @@ BEGIN
     retrec.id1 := rec.node_id;
     retrec.id2 := NULL; -- TODO: write expected containing_face here ?
     RETURN NEXT retrec;
-  END LOOP;
+  END LOOP; --}
   -- Check edges are covered by their left-right faces (#4831)
+  RAISE DEBUG 'Checking for edges coverage';
   FOR rec IN
     WITH edge_coverage AS (
       SELECT
@@ -1801,7 +1814,7 @@ BEGIN
       OR
       ( right_face = 0 AND left_face = 0 AND covered_by[1] != 0 )
     ORDER BY edge_id
-  LOOP
+  LOOP --{
       retrec.id1 := rec.edge_id;
       IF rec.left_face = 0 AND rec.right_face = 0 THEN
@@ -1819,7 +1832,7 @@ BEGIN
 --          RETURN NEXT retrec;
 --        END IF;
       END IF;
-  END LOOP;
+  END LOOP; --}
   DROP TABLE face_check;
Summary of changes:
 NEWS                                          |   1 +
 doc/extras_topology.xml                       |  12 +-
 topology/test/invalid_topology.sql            |  16 ++-
 topology/test/regress/legacy_invalid.sql      |  53 +++++++++
 topology/test/regress/legacy_invalid_expected |   3 +
 topology/topology.sql.in                      | 154 ++++++++++++++++++++------
 6 files changed, 203 insertions(+), 36 deletions(-)
hooks/post-receive
