[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.3-6-gd719113
git at osgeo.org
git at osgeo.org
Tue Jul 6 06:54:16 PDT 2021
the project "PostGIS".
The branch, stable-3.1 has been updated
via d7191135a2db03a6b87543343cca9fb149596f9e (commit)
from de40b71dc1037bd83a8f228d55ee2f8f9ef00ed8 (commit)
revisions in full, below.
commit d7191135a2db03a6b87543343cca9fb149596f9e
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Jul 6 12:40:34 2021 +0200
Return the full ("fit") face mbr from cb_getFacesById
Add test of face mbr invalidity on TopoGeo_addLineString
References #4941 in stable-3.1 branch (3.1.4dev)
diff --git a/NEWS b/NEWS
index 4116c08..dc1d19e 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,7 @@ PostGIS 3.1.4
* Bug Fixes
- #4918, Fix rare crash in st_minpossiblevalue (Paul Ramsey)
+ - #4941, Fix loose mbr in topology.face on update (Sandro Santilli)
PostGIS 3.1.3
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index be74d9a..f7ba493 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -873,9 +873,11 @@ fillFaceFields(LWT_ISO_FACE* face, HeapTuple row, TupleDesc rowdesc, int fields)
/* NOTE: this is a geometry of which we want to take (and clone) the BBOX */
geom = (GSERIALIZED *)PG_DETOAST_DATUM(dat);
g = lwgeom_from_gserialized(geom);
+ lwgeom_refresh_bbox(g); /* Ensure we use a fit mbr, see #4149 */
box = lwgeom_get_bbox(g);
if ( box )
+ POSTGIS_DEBUGF(1, "Face %d bbox xmin is %.15g", face->face_id, box->xmin);
face->mbr = gbox_clone(box);
else
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index a510b52..c9f3463 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -399,3 +399,60 @@ FROM topology.TopoGeo_addLinestring('t4758',
'LINESTRING( 11.38330505 60.408239599999995, 11.3832721 60.408194249999994)') AS t
ORDER BY t;
SELECT 't4758.end', topology.DropTopology('t4758');
+-- See https://trac.osgeo.org/postgis/ticket/4941
+SELECT NULL FROM createtopology('b4941');
+SELECT 'b4941', 'outer_ring', count(*) FROM (
+ SELECT TopoGeo_addLineString('b4941',
+ 'LINESTRING(
+ 12.123711265448206 65.12785021295713,
+ 12.123711265448206 65.21007378815003,
+ 12.208829785296102 65.12785021295713,
+ 12.123711265448206 65.12785021295713)
+) foo;
+SELECT 'b4941', 'mbr-invalid-before', face_id
+FROM b4941.face
+WHERE face_id > 0
+AND NOT ST_Equals(
+ mbr,
+ ST_Envelope(
+ ST_GetFaceGeometry('b4941', face_id)
+SELECT 'b4941', 'inner_ring', count(*) FROM (
+ 'LINESTRING(
+ 12.164016376530826 65.16373151830707,
+ 12.164026259700226 65.16368501062713,
+ 12.164003720888175 65.16368611107725,
+) foo;
+SELECT 'b4941', 'mbr-invalid-after-hole', face_id
+FROM b4941.face
+WHERE face_id > 0
+AND NOT ST_Equals(
+ mbr,
+ ST_Envelope(
+SELECT 'b4941', 'crossing_line', count(*) FROM (
+ 'LINESTRING(
+ 12.123387 65.128411,
+ 12.164015866 65.163701383,
+ 12.168618 65.167537
+) foo;
+SELECT 'b4941', 'mbr-invalid-after-cross', face_id
+FROM b4941.face
+WHERE face_id > 0
+AND NOT ST_Equals(
+ mbr,
+ ST_Envelope(
+SELECT NULL FROM topology.DropTopology('b4941');
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index d786940..7bd753d 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -217,3 +217,6 @@ t4758.2|2
t4758.2|4
t4758.2|5
t4758.end|Topology 't4758' dropped
+b4941|outer_ring|1
+b4941|inner_ring|1
+b4941|crossing_line|5
Summary of changes:
NEWS | 1 +
topology/postgis_topology.c | 2 +
topology/test/regress/topogeo_addlinestring.sql | 57 ++++++++++++++++++++++
.../test/regress/topogeo_addlinestring_expected | 3 ++
4 files changed, 63 insertions(+)
hooks/post-receive
