[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-280-gd71411c
    git at osgeo.org
    git at osgeo.org
    Wed Jul  7 03:57:41 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  d71411caf5b122fc3595c6af3b925a17fc4de129 (commit)
      from  18dac3acf7cd78509ef5229f9018225519f2d73c (commit)
revisions in full, below.
commit d71411caf5b122fc3595c6af3b925a17fc4de129
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 7 12:23:32 2021 +0200
    Restore support for PostgreSQL-9.6, broke by edge-linking commit
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index 43ca7e3..ceca303 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -23,36 +23,36 @@ CREATE TYPE topology.ValidateTopology_ReturnType AS (
   id2 integer
-CREATE OR REPLACE FUNCTION topology._CheckEdgeLinking(curedge ANYELEMENT, prevedge ANYELEMENT)
+CREATE OR REPLACE FUNCTION topology._CheckEdgeLinking(curedge_edge_id INT, prevedge_edge_id INT, prevedge_next_left_edge INT, prevedge_next_right_edge INT)
 RETURNS topology.ValidateTopology_ReturnType
 AS
 $BODY$
 DECLARE
   retrec topology.ValidateTopology_ReturnType;
 BEGIN
-  IF prevedge.edge_id > 0
+  IF prevedge_edge_id > 0
   THEN -- previous was outgoing, this one should be next-right
-    IF prevedge.next_right_edge != curedge.edge_id THEN
+    IF prevedge_next_right_edge != curedge_edge_id THEN
       RAISE DEBUG 'Edge % should be next-right of edge %, is % instead',
-        curedge.edge_id,
-        abs(prevedge.edge_id),
-        prevedge.next_right_edge
+        curedge_edge_id,
+        abs(prevedge_edge_id),
+        prevedge_next_right_edge
       retrec.error = 'invalid next_right_edge';
-      retrec.id1 = abs(prevedge.edge_id);
-      retrec.id2 = curedge.edge_id; -- we put the expected one here, for convenience
+      retrec.id1 = abs(prevedge_edge_id);
+      retrec.id2 = curedge_edge_id; -- we put the expected one here, for convenience
       RETURN retrec;
     END IF;
   ELSE -- previous was incoming, this one should be next-left
-    IF prevedge.next_left_edge != curedge.edge_id THEN
+    IF prevedge_next_left_edge != curedge_edge_id THEN
       RAISE DEBUG 'Edge % should be next-left of edge %, is % instead',
-        curedge.edge_id,
-        prevedge.next_left_edge
+        curedge_edge_id,
+        prevedge_next_left_edge
       retrec.error = 'invalid next_left_edge';
       RETURN retrec;
     END IF;
   END IF;
@@ -421,7 +421,12 @@ BEGIN
       IF last_node_id IS NOT NULL
       THEN
         -- Check that last edge (CW from prev one) is correctly linked
-        retrec := topology._CheckEdgeLinking(last_node_first_edge, last_node_prev_edge);
+        retrec := topology._CheckEdgeLinking(
+          last_node_first_edge.edge_id,
+          last_node_prev_edge.edge_id,
+          last_node_prev_edge.next_left_edge,
+          last_node_prev_edge.next_right_edge
         IF retrec IS NOT NULL
         THEN
           RETURN NEXT retrec;
@@ -433,7 +438,12 @@ BEGIN
       last_node_first_edge = rec;
     ELSE --{
       -- Check that this edge (CW from last one) is correctly linked
-      retrec := topology._CheckEdgeLinking(rec, last_node_prev_edge);
+        rec.edge_id,
       THEN
         RETURN NEXT retrec;
@@ -447,7 +457,12 @@ BEGIN
     --RAISE DEBUG 'Out of loop: last_node_prev_edge edge_id:% next_left_edge:%', last_node_prev_edge.edge_id, last_node_prev_edge.next_left_edge;
     --RAISE DEBUG 'Out of loop: last_node_first_edge: %', last_node_first_edge;
     THEN
       RETURN NEXT retrec;
Summary of changes:
 topology/sql/manage/ValidateTopology.sql.in | 49 +++++++++++++++++++----------
 1 file changed, 32 insertions(+), 17 deletions(-)
hooks/post-receive
