[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-282-ga724cfc
Wed Jul 7 06:37:42 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  a724cfca065ca748aa8894639477ceb4ed76d5d6 (commit)
      from  1735811117212c292740df7edc96414ee73f4b85 (commit)
revisions in full, below.
commit a724cfca065ca748aa8894639477ceb4ed76d5d6
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 7 12:15:38 2021 +0200
    Rewrite edge coverage check to speed it up
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index ceca303..e22eff1 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -616,45 +616,84 @@ BEGIN
   -- Check edges are covered by their left-right faces (#4830)
   RAISE DEBUG 'Checking for edges coverage';
-  FOR rec IN
-    WITH edge_coverage AS (
+  FOR rec IN --{
+    WITH
+    face_coverage AS (
+      SELECT f.face_id, array_agg(e.edge_id) covered_edges
+      FROM face_check f, edge_data e
+      WHERE ST_Covers(f.geom, e.geom)
+      GROUP BY f.face_id
+    edges_to_check AS (
+      SELECT
+        e.*
+      FROM edge_data e
+      WHERE ( bbox IS NULL OR e.geom && bbox )
+      AND e.edge_id NOT IN (
+        SELECT unnest(invalid_edges)
+    edge_coverage AS (
       SELECT
         e.edge_id,
         e.left_face,
         e.right_face,
-        array_agg(COALESCE(f.face_id, 0)) covered_by
-      FROM
-        edge_data e
-        LEFT JOIN face_check f ON ( ST_Covers(f.geom, e.geom) )
-        -- skip invalid edges (toxic, and will be already reported previously)
-        WHERE
-            invalid_edges IS NULL OR NOT e.edge_id = ANY(invalid_edges)
-          AND
-            bbox IS NULL OR e.geom && bbox
-      GROUP BY
-        e.edge_id, e.left_face, e.right_face
+        array_agg(DISTINCT fc.face_id)
+          filter (WHERE fc.face_id IS NOT NULL) faces_covering
+      FROM edges_to_check e
+      LEFT JOIN face_coverage fc ON (
+        e.edge_id = ANY(fc.covered_edges)
+      GROUP BY edge_id, left_face, right_face
-    SELECT
-       left_face = ANY(covered_by) left_face_covered,
-       right_face = ANY(covered_by) right_face_covered
-       from edge_coverage
+    SELECT *
+    FROM edge_coverage
     WHERE
-      ( left_face != 0 AND NOT left_face = ANY(covered_by) )
+      -- Edges dangling in universal face needs be
+      -- NOT covered by any face
+        left_face = 0 AND
+        right_face = 0 AND
+        faces_covering IS NOT NULL
+      OR
+        left_face != 0 AND
+          faces_covering IS NULL OR
+          NOT left_face = ANY(faces_covering)
       OR
-      ( right_face != 0 AND NOT right_face = ANY(covered_by) )
+        right_face != 0 AND
+          NOT right_face = ANY(faces_covering)
       OR
-      ( right_face = 0 AND left_face = 0 AND covered_by[1] != 0 )
+          ( right_face = 0 AND left_face != 0 )
+          OR
+          ( right_face != 0 AND left_face = 0 )
+        AND
+          array_upper(faces_covering, 1) != 1
     ORDER BY edge_id
-  LOOP --{
+  LOOP --}{
       retrec.id1 := rec.edge_id;
-      retrec.id2 := NULL; -- TODO: write expected containing_face here ?
-      IF rec.left_face = 0 AND rec.right_face = 0 THEN
+      retrec.id2 := NULL;
+      IF rec.left_face = 0
+         AND rec.right_face = 0
+      THEN
         retrec.error := 'edge covered by some face has universal face on both sides';
+        --retrec.error := format('edge covered by faces %s has universal face on both sides', rec.faces_covering);
         RETURN NEXT retrec;
       ELSE
         retrec.error := 'edge not covered by both its side faces';
Summary of changes:
 topology/sql/manage/ValidateTopology.sql.in | 95 ++++++++++++++++++++---------
 1 file changed, 67 insertions(+), 28 deletions(-)
hooks/post-receive
