[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-291-g61638f9
Thu Jul 8 09:28:21 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  61638f97778d8a75bca8cba9117244f129179746 (commit)
      from  c40f25324c1e7d54f3ba78b20b662b142f09b235 (commit)
revisions in full, below.
commit 61638f97778d8a75bca8cba9117244f129179746
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jul 8 18:27:27 2021 +0200
    Make ValidateTopology mixed face labeling errors more predictable
    Will start rings from edge with lowest signed id
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index ceca2ec..9c813e8 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -247,7 +247,7 @@ BEGIN
   SELECT -edge_id FROM edges_to_check
-  CREATE INDEX ON side_label_check_edge (edge_id); -- DROP ?
+  CREATE INDEX ON side_label_check_edge (edge_id);
   RAISE DEBUG 'Checking edge side faces labeling';
@@ -258,6 +258,7 @@ BEGIN
     -- Fetch next unvisited edge
     SELECT edge_id
     FROM pg_temp.side_label_check_edge
+    ORDER BY edge_id
     LIMIT 1
     INTO nextEdge;
diff --git a/topology/test/regress/validatetopology_expected b/topology/test/regress/validatetopology_expected
index f21a9dd..340796f 100644
--- a/topology/test/regress/validatetopology_expected
+++ b/topology/test/regress/validatetopology_expected
@@ -11,19 +11,19 @@
 #4830.1|---||
 #4830.1|edge not covered by both its side faces|4|
 #4830.1|edge not covered by both its side faces|6|
-#4830.1|mixed face labeling in ring|3|
+#4830.1|mixed face labeling in ring|-6|
 #4830.2|---||
 #4830.2|edge not covered by both its side faces|4|
 #4830.2|edge not covered by both its side faces|6|
-#4830.2|mixed face labeling in ring|3|
+#4830.2|mixed face labeling in ring|-6|
 #4830.3|---||
 #4830.3|edge not covered by both its side faces|7|
 #4830.3|edge not covered by both its side faces|8|
-#4830.3|mixed face labeling in ring|-7|
+#4830.3|mixed face labeling in ring|-8|
 #4830.4|---||
 #4830.4|edge not covered by both its side faces|7|
 #4830.4|edge not covered by both its side faces|8|
-#4830.4|mixed face labeling in ring|-7|
+#4830.4|mixed face labeling in ring|-8|
 #4830.5|---||
 #4830.5|edge covered by some face has universal face on both sides|9|
 #3042|---||
@@ -36,13 +36,13 @@
 #3042|invalid next_right_edge|19|-10
 #3042|invalid next_right_edge|25|25
 #3042|mixed face labeling in ring|-22|
+#3042|mixed face labeling in ring|-21|
 #3042|mixed face labeling in ring|-20|
 #3042|mixed face labeling in ring|-10|
 #3042|mixed face labeling in ring|-9|
-#3042|mixed face labeling in ring|-7|
+#3042|mixed face labeling in ring|-6|
 #3042|mixed face labeling in ring|-3|
-#3042|mixed face labeling in ring|13|
 #3042|mixed face labeling in ring|19|
 #4944|---||
+#4944|mixed face labeling in ring|-21|
 #4944|mixed face labeling in ring|-19|
-#4944|mixed face labeling in ring|19|
Summary of changes:
 topology/sql/manage/ValidateTopology.sql.in     |  3 ++-
 topology/test/regress/validatetopology_expected | 14 +++++++-------
 2 files changed, 9 insertions(+), 8 deletions(-)
hooks/post-receive
