[postgis-tickets] [PostGIS] #4951: Geometries returning zero area with PostGIS 3.1.2
trac at osgeo.org
Mon Jul 12 14:34:21 PDT 2021
Reporter: mboeringa | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.1.3
Component: postgis | Version: 3.1.x
Resolution: invalid | Keywords:
Comment (by mboeringa):
Hi Paul,
Nice answer, although it is always a bit difficult to wrap my head around
such a description and mentally visualize what happens. Putting the
examples in the online WKT renderer, helped though.
So, due to the particular and a bit unfortunate peculiar nature of these
polygons, combined with calculating the "convex hull", you end up with a
dimensional collapse... so, yes, that explains zero area well.
I must admit that between active code development, and multiple long
running import and process sessions on global planet data, it is difficult
for me to 100% garantuee I processed these geometries before (e.g. I also
recently tested Facebook's Daylight distribution, but Facebook may have
dropped these geometries from their distribution, IRDK).
Nonetheless, if you have a possibility to easily test this in previous
version, it might be worthwhile to test the result in at least on older
version of PostGIS before closing the issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4951#comment:2>
