[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-336-gf2cd119
    git at osgeo.org
    git at osgeo.org
    Wed Jul 14 07:13:55 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  f2cd119bba43fdffd3ace23406d145ce914096a7 (commit)
      from  04aa7f611dbedd47b9b56993696032fbd3ef4331 (commit)
revisions in full, below.
commit f2cd119bba43fdffd3ace23406d145ce914096a7
Author: Sandro Santilli <strk at kbt.io>
Date:   Wed Jul 14 15:49:36 2021 +0200
    Add ptarray_closest_vertex_2d liblwgeom function
    Includes unit test.
diff --git a/liblwgeom/cunit/cu_ptarray.c b/liblwgeom/cunit/cu_ptarray.c
index 0ac5fa0..c7cdf48 100644
--- a/liblwgeom/cunit/cu_ptarray.c
+++ b/liblwgeom/cunit/cu_ptarray.c
@@ -653,6 +653,39 @@ static void test_ptarray_scroll()
   lwline_free(line);
+static void test_ptarray_closest_vertex_2d()
+  LWLINE *line;
+  POINTARRAY *pa;
+	double dist;
+  POINT2D qp;
+  const char *wkt;
+  char *wktout;
+	int rv;
+  wkt = "LINESTRING (0 0 0, 1 0 0, 2 0 0, 3 0 10)";
+  line = lwgeom_as_lwline(lwgeom_from_text(wkt));
+  pa = line->points;
+	qp.x = qp.y = 0;
+	rv = ptarray_closest_vertex_2d(pa, &qp, &dist);
+	ASSERT_INT_EQUAL(rv, 0);
+	ASSERT_DOUBLE_EQUAL(dist, 0);
+	qp.x = qp.y = 1;
+	ASSERT_INT_EQUAL(rv, 1);
+	ASSERT_DOUBLE_EQUAL(dist, 1);
+	qp.x = 5; qp.y = 0;
+	ASSERT_INT_EQUAL(rv, 3);
+	ASSERT_DOUBLE_EQUAL(dist, 2);
+  lwline_free(line);
 ** Used by the test harness to register the tests in this file.
@@ -671,4 +704,5 @@ void ptarray_suite_setup(void)
 	PG_ADD_TEST(suite, test_ptarrayarc_contains_point);
 	PG_ADD_TEST(suite, test_ptarray_scale);
 	PG_ADD_TEST(suite, test_ptarray_scroll);
+	PG_ADD_TEST(suite, test_ptarray_closest_vertex_2d);
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index bbacc19..a48921f 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1089,6 +1089,15 @@ extern POINTARRAY* ptarray_flip_coordinates(POINTARRAY *pa);
 extern POINTARRAY *ptarray_substring(POINTARRAY *pa, double d1, double d2,
                                                           double tolerance);
+ * @param pa the subject pointarray
+ * @param qp the query point
+ * @param dist optional output for actual distance from vertex
+extern int ptarray_closest_vertex_2d(const POINTARRAY *pa,
+                                     const POINT2D *qp, double *dist);
 * Strip out the Z/M components of an #LWGEOM
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index 5f1f22c..003e3f6 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -1295,6 +1295,35 @@ closest_point_on_segment(const POINT4D *p, const POINT4D *A, const POINT4D *B, P
 	ret->m = A->m + ( (B->m - A->m) * r );
+int
+ptarray_closest_vertex_2d(const POINTARRAY *pa, const POINT2D *qp, double *dist)
+	uint32_t t, pn=0;
+	POINT2D *p;
+	double mindist = DBL_MAX;
+	/* Loop through pointarray looking for nearest segment */
+	for (t=0; t<pa->npoints; t++)
+		double dist_sqr;
+		getPoint2d_p_ro(pa, t, &p);
+		dist_sqr = distance2d_sqr_pt_pt(p, qp);
+		if (dist_sqr < mindist)
+			mindist = dist_sqr;
+			pn = t;
+			if ( mindist == 0 )
+				LWDEBUG(3, "Breaking on mindist=0");
+				break;
+	if ( dist ) *dist = sqrt(mindist);
+	return pn;
  * Given a point, returns the location of closest point on pointarray
  * and, optionally, it's actual distance from the point array.
Summary of changes:
 liblwgeom/cunit/cu_ptarray.c | 34 ++++++++++++++++++++++++++++++++++
 liblwgeom/liblwgeom.h.in     |  9 +++++++++
 liblwgeom/ptarray.c          | 29 +++++++++++++++++++++++++++++
 3 files changed, 72 insertions(+)
hooks/post-receive
