[postgis-tickets] [PostGIS] #3239: ST_{Mod, New}EdgeHeal does not check for TopoGeometry defined by removed node
trac at osgeo.org
Wed Jul 14 14:00:26 PDT 2021
#3239: ST_{Mod,New}EdgeHeal does not check for TopoGeometry defined by removed
node
Reporter: strk | Owner: strk
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 3.2.0
Component: topology | Version: 2.1.x
Resolution: fixed | Keywords:
Changes (by Sandro Santilli <strk@…>):
* status: new => closed
* resolution: => fixed
Comment:
In [changeset:"1ea1cb69940be217f3a98412b1621c5b887c566e/git" 1ea1cb6/git]:
#!CommitTicketReference repository="git"
revision="1ea1cb69940be217f3a98412b1621c5b887c566e"
Prevent healing edges if connecting node is used in a TopoGeometry
Closes #3239 in main branch (3.2.0dev)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3239#comment:15>
