[postgis-tickets] [SCM] PostGIS branch main updated. 3.1.0rc1-365-g0981555
Wed Jul 28 13:23:31 PDT 2021
the project "PostGIS".
The branch, main has been updated
       via  0981555c35abb4a0c6984e302f399cea95ecc64b (commit)
      from  ff9de2c109dccd338ed5678bd334cbfe797cee8f (commit)
revisions in full, below.
commit 0981555c35abb4a0c6984e302f399cea95ecc64b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Jul 28 13:20:38 2021 -0700
    Replace home-grown axis swapping code with the proj_normalize_for_visualization()
    function from proj. This moves responsibility for maintaining "gis friendly"
    coordinates, with eastings in X and northings in Y (longitude first, latitude second)
    to proj, for proj versions 6.1 and greater. This means that proj 6.0 is
    demoted to using the old proj4 proj_api.h header, but otherwise we
    lose a bunch of code to maintain, and there should be no major changes in
    behaviour.
diff --git a/.gitignore b/.gitignore
index 14d4342..4c5328e 100644
--- a/.gitignore
+++ b/.gitignore
@@ -1,3 +1,4 @@
 *.a
 *.la
 .libs
@@ -29,7 +30,6 @@ doc/html/docbook.css
 doc/Makefile
 doc/Makefile.comments
 doc/po/*/*.xml
-doc/po/*/*.po~
 doc/po/*/html
 doc/po/*/xsl
 doc/po/*/*_comments.sql
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index a48921f..f2a148c 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -35,7 +35,11 @@
 #include "../postgis_config.h"
-#if POSTGIS_PROJ_VERSION < 60
+#if POSTGIS_PROJ_VERSION < 61
+/* For Proj 6.0 use of old API */
+#define ACCEPT_USE_OF_DEPRECATED_PROJ_API_H
 #include "proj_api.h"
 typedef struct PJ
@@ -53,16 +57,12 @@ typedef PJ LWPROJ;
 typedef struct LWPROJ
-	PJ* pj;
-        /* CRSs are swapped: Used in transformation calls */
-	uint8_t source_swapped;
-	uint8_t target_swapped;
-        /* Source crs is geographic: Used in geography calls (source srid == dst srid) */
-        uint8_t source_is_latlong;
-        /* Source ellipsoid parameters */
-        double source_semi_major_metre;
-        double source_semi_minor_metre;
+    PJ* pj;
+    /* Source crs is geographic: Used in geography calls (source srid == dst srid) */
+    uint8_t source_is_latlong;
+    /* Source ellipsoid parameters */
+    double source_semi_major_metre;
+    double source_semi_minor_metre;
 } LWPROJ;
 #endif
@@ -2450,8 +2450,15 @@ int lwgeom_is_simple(const LWGEOM *lwgeom);
 int lwgeom_transform_from_str(LWGEOM *geom, const char* instr, const char* outstr);
+ * Transform (reproject) a geometry in-place.
+ * @param geom the geometry to transform
+ * @param pj the transformation
+int lwgeom_transform(LWGEOM *geom, LWPROJ* pj);
+int ptarray_transform(POINTARRAY *pa, LWPROJ* pj);
  * Get a projection from a string representation
@@ -2459,23 +2466,14 @@ int lwgeom_transform_from_str(LWGEOM *geom, const char* instr, const char* outst
 projPJ projpj_from_string(const char* txt);
-#endif
- * Transform (reproject) a geometry in-place.
- * @param geom the geometry to transform
- * @param pj the input and output
-int lwgeom_transform(LWGEOM *geom, LWPROJ* pj);
-int ptarray_transform(POINTARRAY *pa, LWPROJ* pj);
-#if POSTGIS_PROJ_VERSION >= 60
+#else // POSTGIS_PROJ_VERSION >= 61
  * Allocate a new LWPROJ containing the reference to the PROJ's PJ
  * If extra_geography_data is true, it will generate the following values for
  * the source srs: is_latlong (geometric or not) and spheroid values
-LWPROJ *lwproj_from_PJ(PJ *pj, int8_t extra_geography_data);
+LWPROJ *lwproj_from_str(const char* str_in, const char* str_out);
 #endif
diff --git a/liblwgeom/lwgeom_transform.c b/liblwgeom/lwgeom_transform.c
index 3bc3799..f2bcb84 100644
--- a/liblwgeom/lwgeom_transform.c
+++ b/liblwgeom/lwgeom_transform.c
@@ -46,7 +46,7 @@ to_dec(POINT4D *pt)
 static int
 point4d_transform(POINT4D *pt, LWPROJ *pj)
@@ -136,66 +136,7 @@ lwgeom_transform_from_str(LWGEOM *geom, const char* instr, const char* outstr)
 	return rv;
- * Transform given LWGEOM geometry
- * from inpj projection to outpj projection
-int
-lwgeom_transform(LWGEOM *geom, LWPROJ *pj)
-	uint32_t i;
-	/* No points to transform in an empty! */
-	if ( lwgeom_is_empty(geom) )
-		return LW_SUCCESS;
-	switch(geom->type)
-		case POINTTYPE:
-		case LINETYPE:
-		case CIRCSTRINGTYPE:
-		case TRIANGLETYPE:
-			LWLINE *g = (LWLINE*)geom;
-			if ( ! ptarray_transform(g->points, pj) ) return LW_FAILURE;
-			break;
-		case POLYGONTYPE:
-			LWPOLY *g = (LWPOLY*)geom;
-			for ( i = 0; i < g->nrings; i++ )
-				if ( ! ptarray_transform(g->rings[i], pj) ) return LW_FAILURE;
-			break;
-		case MULTIPOINTTYPE:
-		case MULTILINETYPE:
-		case MULTIPOLYGONTYPE:
-		case COLLECTIONTYPE:
-		case COMPOUNDTYPE:
-		case CURVEPOLYTYPE:
-		case MULTICURVETYPE:
-		case MULTISURFACETYPE:
-		case POLYHEDRALSURFACETYPE:
-		case TINTYPE:
-			LWCOLLECTION *g = (LWCOLLECTION*)geom;
-			for ( i = 0; i < g->ngeoms; i++ )
-				if ( ! lwgeom_transform(g->geoms[i], pj) ) return LW_FAILURE;
-			break;
-		default:
-			lwerror("lwgeom_transform: Cannot handle type '%s'",
-			          lwtype_name(geom->type));
-			return LW_FAILURE;
 projPJ
 projpj_from_string(const char *str1)
@@ -209,202 +150,94 @@ projpj_from_string(const char *str1)
-#else /* POSTGIS_PROJ_VERION >= 60 */
-static PJ *
-proj_cs_get_simplecs(const PJ *pj_crs)
-	PJ *pj_sub = NULL;
-	if (proj_get_type(pj_crs) == PJ_TYPE_COMPOUND_CRS)
-		/* Sub-CRS[0] is the horizontal component */
-		pj_sub = proj_crs_get_sub_crs(NULL, pj_crs, 0);
-		if (!pj_sub)
-			lwerror("%s: proj_crs_get_sub_crs(0) returned NULL", __func__);
-	else if (proj_get_type(pj_crs) == PJ_TYPE_BOUND_CRS)
-		pj_sub = proj_get_source_crs(NULL, pj_crs);
-		if (!pj_sub)
-			lwerror("%s: proj_get_source_crs returned NULL", __func__);
-	else
-		/* If this works, we have a CS so we can return */
-		pj_sub = proj_crs_get_coordinate_system(NULL, pj_crs);
-		if (pj_sub)
-			return pj_sub;
-	/* Only sub-components of the Compound or Bound CRS's get here */
-	/* If we failed to get sub-components, or we failed to extract */
-	/* a CS from a generic CRS, then this is another case we don't */
-	/* handle */
-	if (!pj_sub)
-		lwerror("%s: %s", __func__, proj_errno_string(proj_context_errno(NULL)));
-	/* If the components are usable, we can extract the CS and return */
-	int pj_type = proj_get_type(pj_sub);
-	if (pj_type == PJ_TYPE_GEOGRAPHIC_2D_CRS || pj_type == PJ_TYPE_PROJECTED_CRS)
-		PJ *pj_2d = proj_crs_get_coordinate_system(NULL, pj_sub);
-		proj_destroy(pj_sub);
-		return pj_2d;
-	/* If the components are *themselves* Bound/Compound, we can recurse */
-	if (pj_type == PJ_TYPE_COMPOUND_CRS || pj_type == PJ_TYPE_BOUND_CRS)
-		return proj_cs_get_simplecs(pj_sub);
-	/* This is a case we don't know how to handle */
-	lwerror("%s: un-handled CRS sub-type: %s", __func__, pj_type);
-	return NULL;
-static uint8_t
-proj_crs_is_swapped(const PJ *pj_crs)
-	int axis_count;
-	PJ *pj_cs = proj_cs_get_simplecs(pj_crs);
-	if (!pj_cs)
-		lwerror("%s: proj_cs_get_simplecs returned NULL", __func__);
-	axis_count = proj_cs_get_axis_count(NULL, pj_cs);
-	if (axis_count >= 2)
-		const char *out_name1, *out_abbrev1, *out_direction1;
-		const char *out_name2, *out_abbrev2, *out_direction2;
-		/* Read first axis */
-		proj_cs_get_axis_info(NULL,
-			pj_cs, 0,
-			&out_name1, &out_abbrev1, &out_direction1,
-			NULL, NULL, NULL, NULL);
-		/* Read second axis */
-			pj_cs, 1,
-			&out_name2, &out_abbrev2, &out_direction2,
-		proj_destroy(pj_cs);
-		/* Directions agree, this is a northing/easting CRS, so reverse it */
-		if(out_direction1 && STR_IEQUALS(out_direction1, "north") &&
-		   out_direction2 && STR_IEQUALS(out_direction2, "east") )
-			return LW_TRUE;
-		/* Oddball case? Both axes north / both axes south, swap */
-		if(out_direction1 && out_direction2 &&
-		   ((STR_IEQUALS(out_direction1, "north") && STR_IEQUALS(out_direction2, "north")) ||
-		    (STR_IEQUALS(out_direction1, "south") && STR_IEQUALS(out_direction2, "south"))) &&
-		   out_name1 && STR_ISTARTS(out_name1, "northing")  &&
-		   out_name2 && STR_ISTARTS(out_name2, "easting"))
-			return LW_TRUE;
-		/* Any lat/lon system with Lat in first axis gets swapped */
-		if (STR_ISTARTS(out_abbrev1, "Lat"))
-			return LW_TRUE;
-		return LW_FALSE;
-	/* Failed the axis count test, leave quietly */
-	return LW_FALSE;
+#else /* POSTGIS_PROJ_VERION >= 61 */
 LWPROJ *
-lwproj_from_PJ(PJ *pj, int8_t extra_geography_data)
+lwproj_from_str(const char* str_in, const char* str_out)
-	PJ *pj_source_crs = proj_get_source_crs(NULL, pj);
 	uint8_t source_is_latlong = LW_FALSE;
-	double out_semi_major_metre = DBL_MAX, out_semi_minor_metre = DBL_MAX;
+	double semi_major_metre = DBL_MAX, semi_minor_metre = DBL_MAX;
-	if (!pj_source_crs)
-		lwerror("%s: unable to access source crs", __func__);
+	/* Usable inputs? */
+	if (! (str_in && str_out))
 		return NULL;
-	uint8_t source_swapped = proj_crs_is_swapped(pj_source_crs);
-	/* We only care about the extra values if there is no transformation */
-	if (!extra_geography_data)
-		proj_destroy(pj_source_crs);
-	else
+	PJ* pj = proj_create_crs_to_crs(PJ_DEFAULT_CTX, str_in, str_out, NULL);
+	if (!pj)
+		return NULL;
+	/* Fill in geodetic parameter information when a null-transform */
+	/* is passed, because that's how we signal we want to store */
+	/* that info in the cache */
+	if (strcmp(str_in, str_out) == 0)
+		PJ *pj_source_crs = proj_get_source_crs(PJ_DEFAULT_CTX, pj);
 		PJ *pj_ellps;
-		double out_inv_flattening;
-		int out_is_semi_minor_computed;
 		PJ_TYPE pj_type = proj_get_type(pj_source_crs);
 		if (pj_type == PJ_TYPE_UNKNOWN)
+			proj_destroy(pj);
 			lwerror("%s: unable to access source crs type", __func__);
 			return NULL;
 		source_is_latlong = (pj_type == PJ_TYPE_GEOGRAPHIC_2D_CRS) || (pj_type == PJ_TYPE_GEOGRAPHIC_3D_CRS);
-		pj_ellps = proj_get_ellipsoid(NULL, pj_source_crs);
+		pj_ellps = proj_get_ellipsoid(PJ_DEFAULT_CTX, pj_source_crs);
 		if (!pj_ellps)
+			proj_destroy(pj);
 			lwerror("%s: unable to access source crs ellipsoid", __func__);
 			return NULL;
-		if (!proj_ellipsoid_get_parameters(NULL,
+		if (!proj_ellipsoid_get_parameters(PJ_DEFAULT_CTX,
 						   pj_ellps,
-						   &out_semi_major_metre,
-						   &out_semi_minor_metre,
-						   &out_is_semi_minor_computed,
-						   &out_inv_flattening))
+						   &semi_major_metre,
+						   &semi_minor_metre,
+						   NULL,
+						   NULL))
 			proj_destroy(pj_ellps);
+			proj_destroy(pj);
 			lwerror("%s: unable to access source crs ellipsoid parameters", __func__);
 			return NULL;
-	PJ *pj_target_crs = proj_get_target_crs(NULL, pj);
-	if (!pj_target_crs)
-		lwerror("%s: unable to access target crs", __func__);
-		return NULL;
-	uint8_t target_swapped = proj_crs_is_swapped(pj_target_crs);
-	proj_destroy(pj_target_crs);
+	/* Add in an axis swap if necessary */
+	PJ* pj_norm = proj_normalize_for_visualization(PJ_DEFAULT_CTX, pj);
+	/* Swap failed for some reason? Fall back to coordinate operation */
+	if (!pj_norm)
+		pj_norm = pj;
+	/* Swap is not a copy of input? Clean up input */
+	else if (pj != pj_norm)
+		proj_destroy(pj);
+	/* Allocate and populate return value */
 	LWPROJ *lp = lwalloc(sizeof(LWPROJ));
-	lp->pj = pj;
-	lp->source_swapped = source_swapped;
-	lp->target_swapped = target_swapped;
+	lp->pj = pj_norm; /* Caller is going to have to explicitly proj_destroy this */
+	lp->source_is_latlong = LW_FALSE;
 	lp->source_is_latlong = source_is_latlong;
-	lp->source_semi_major_metre = out_semi_major_metre;
-	lp->source_semi_minor_metre = out_semi_minor_metre;
+	lp->source_semi_major_metre = semi_major_metre;
+	lp->source_semi_minor_metre = semi_minor_metre;
 	return lp;
 int
-	PJ *pj = proj_create_crs_to_crs(NULL, instr, outstr, NULL);
-	if (!pj)
+	LWPROJ *lp = lwproj_from_str(instr, outstr);
+	if (!lp)
-		PJ *pj_in = proj_create(NULL, instr);
+		PJ *pj_in = proj_create(PJ_DEFAULT_CTX, instr);
 		if (!pj_in)
 			lwerror("could not parse proj string '%s'", instr);
 		proj_destroy(pj_in);
-		PJ *pj_out = proj_create(NULL, outstr);
+		PJ *pj_out = proj_create(PJ_DEFAULT_CTX, outstr);
 		if (!pj_out)
 			lwerror("could not parse proj string '%s'", outstr);
@@ -413,78 +246,12 @@ lwgeom_transform_from_str(LWGEOM *geom, const char* instr, const char* outstr)
 		lwerror("%s: Failed to transform", __func__);
 		return LW_FAILURE;
-	LWPROJ *lp = lwproj_from_PJ(pj, LW_FALSE);
 	int ret = lwgeom_transform(geom, lp);
-	proj_destroy(pj);
-	lwfree(lp);
+	proj_destroy(lp->pj);
 	return ret;
 int
-	uint32_t i;
-	if (lwgeom_is_empty(geom))
-		case POINTTYPE:
-		case LINETYPE:
-			if (!ptarray_transform(g->points, pj))
-			break;
-		case POLYGONTYPE:
-			for (i = 0; i < g->nrings; i++)
-				if (!ptarray_transform(g->rings[i], pj))
-			break;
-		case TINTYPE:
-			for (i = 0; i < g->ngeoms; i++)
-				if (!lwgeom_transform(g->geoms[i], pj))
-			break;
-		default:
-int
 ptarray_transform(POINTARRAY *pa, LWPROJ *pj)
 	uint32_t i;
@@ -505,9 +272,6 @@ ptarray_transform(POINTARRAY *pa, LWPROJ *pj)
-	if (pj->source_swapped)
-		ptarray_swap_ordinates(pa, LWORD_X, LWORD_Y);
 	if (n_points == 1)
 		/* For single points it's faster to call proj_trans */
@@ -567,9 +331,6 @@ ptarray_transform(POINTARRAY *pa, LWPROJ *pj)
-	if (pj->target_swapped)
 	/* Convert radians to degrees if necessary */
 	if (proj_angular_output(pj->pj, PJ_FWD))
@@ -584,3 +345,64 @@ ptarray_transform(POINTARRAY *pa, LWPROJ *pj)
 #endif
+ * Transform given LWGEOM geometry
+ * from inpj projection to outpj projection
+int
+lwgeom_transform(LWGEOM *geom, LWPROJ *pj)
+	uint32_t i;
+	/* No points to transform in an empty! */
+	if ( lwgeom_is_empty(geom) )
+		return LW_SUCCESS;
+	switch(geom->type)
+		case POINTTYPE:
+		case LINETYPE:
+		case CIRCSTRINGTYPE:
+		case TRIANGLETYPE:
+			LWLINE *g = (LWLINE*)geom;
+			if ( ! ptarray_transform(g->points, pj) ) return LW_FAILURE;
+			break;
+		case POLYGONTYPE:
+			LWPOLY *g = (LWPOLY*)geom;
+			for ( i = 0; i < g->nrings; i++ )
+				if ( ! ptarray_transform(g->rings[i], pj) ) return LW_FAILURE;
+			break;
+		case MULTIPOINTTYPE:
+		case MULTILINETYPE:
+		case MULTIPOLYGONTYPE:
+		case COLLECTIONTYPE:
+		case COMPOUNDTYPE:
+		case CURVEPOLYTYPE:
+		case MULTICURVETYPE:
+		case MULTISURFACETYPE:
+		case POLYHEDRALSURFACETYPE:
+		case TINTYPE:
+			LWCOLLECTION *g = (LWCOLLECTION*)geom;
+			for ( i = 0; i < g->ngeoms; i++ )
+				if ( ! lwgeom_transform(g->geoms[i], pj) ) return LW_FAILURE;
+			break;
+		default:
+			lwerror("lwgeom_transform: Cannot handle type '%s'",
+			          lwtype_name(geom->type));
+			return LW_FAILURE;
diff --git a/libpgcommon/lwgeom_transform.c b/libpgcommon/lwgeom_transform.c
index 23f20da..8fff336 100644
--- a/libpgcommon/lwgeom_transform.c
+++ b/libpgcommon/lwgeom_transform.c
@@ -67,8 +67,8 @@ static void
 PROJSRSDestroyPJ(void *projection)
 	LWPROJ *pj = (LWPROJ *)projection;
-/* Ape the Proj 6+ API for versions < 6 */
+/* Ape the Proj 6+ API for versions < 6.1 */
 	if (pj->pj_from)
 		pj_free(pj->pj_from);
@@ -359,7 +359,7 @@ pjstrs_pfree(PjStrs *strs)
 		pfree(strs->srtext);
+#if POSTGIS_PROJ_VERSION >= 61
 static char*
 pgstrs_get_entry(const PjStrs *strs, int n)
@@ -377,7 +377,7 @@ pgstrs_get_entry(const PjStrs *strs, int n)
 #endif
 * Utility function for GML reader that still
 * needs proj4text access
@@ -421,7 +421,7 @@ AddToPROJSRSCache(PROJSRSCache *PROJCache, int32_t srid_from, int32_t srid_to)
 	oldContext = MemoryContextSwitchTo(PROJCache->PROJSRSCacheContext);
 	PJ *projection = palloc(sizeof(PJ));
 	pj_from_str = from_strs.proj4text;
 	pj_to_str = to_strs.proj4text;
@@ -438,7 +438,8 @@ AddToPROJSRSCache(PROJSRSCache *PROJCache, int32_t srid_from, int32_t srid_to)
 		    "could not form projection from 'srid=%d' to 'srid=%d'",
 		    srid_from, srid_to);
 #else
-	PJ *projpj = NULL;
+	LWPROJ *projection = NULL;
 	/* Try combinations of ESPG/SRTEXT/PROJ4TEXT until we find */
 	/* one that gives us a usable transform. Note that we prefer */
 	/* EPSG numbers over SRTEXT and SRTEXT over PROJ4TEXT */
@@ -450,16 +451,11 @@ AddToPROJSRSCache(PROJSRSCache *PROJCache, int32_t srid_from, int32_t srid_to)
 		pj_to_str   = pgstrs_get_entry(&to_strs,   i % 3);
 		if (!(pj_from_str && pj_to_str))
 			continue;
-		projpj = proj_create_crs_to_crs(NULL, pj_from_str, pj_to_str, NULL);
-		if (projpj && !proj_errno(projpj))
+		projection = lwproj_from_str(pj_from_str, pj_to_str);
+		if (projection)
 			break;
-	if (!projpj)
-		elog(ERROR, "could not form projection (PJ) from 'srid=%d' to 'srid=%d'", srid_from, srid_to);
-		return NULL;
-	LWPROJ *projection = lwproj_from_PJ(projpj, srid_from == srid_to);
 	if (!projection)
 		elog(ERROR, "could not form projection (LWPROJ) from 'srid=%d' to 'srid=%d'", srid_from, srid_to);
@@ -557,7 +553,7 @@ GetLWPROJ(int32_t srid_from, int32_t srid_to, LWPROJ **pj)
 static int
 proj_pj_is_latlong(const LWPROJ *pj)
 	return pj_is_latlong(pj->pj_from);
 #else
 	return pj->source_is_latlong;
@@ -611,14 +607,14 @@ int
 spheroid_init_from_srid(int32_t srid, SPHEROID *s)
 	LWPROJ *pj;
-#if POSTGIS_PROJ_VERSION >= 48 && POSTGIS_PROJ_VERSION < 60
+#if POSTGIS_PROJ_VERSION >= 48 && POSTGIS_PROJ_VERSION < 61
 	double major_axis, minor_axis, eccentricity_squared;
 #endif
 	if ( GetLWPROJ(srid, srid, &pj) == LW_FAILURE)
 		return LW_FAILURE;
 	if (!pj->source_is_latlong)
 		return LW_FAILURE;
 	spheroid_init(s, pj->source_semi_major_metre, pj->source_semi_minor_metre);
diff --git a/libpgcommon/lwgeom_transform.h b/libpgcommon/lwgeom_transform.h
index f2a65e5..db58c64 100644
--- a/libpgcommon/lwgeom_transform.h
+++ b/libpgcommon/lwgeom_transform.h
@@ -56,7 +56,7 @@ typedef struct srs_precision
 	int precision_m;
 } srs_precision;
 /* Needs to call postgis_initialize_cache first */
 char *GetProj4String(int32_t srid);
 #endif
diff --git a/postgis/lwgeom_in_gml.c b/postgis/lwgeom_in_gml.c
index 664ed93..8b3238e 100644
--- a/postgis/lwgeom_in_gml.c
+++ b/postgis/lwgeom_in_gml.c
@@ -112,7 +112,7 @@ Datum geom_from_gml(PG_FUNCTION_ARGS)
 	/* Zero for undefined */
 	root_srid = PG_GETARG_INT32(1);
 	/* Internally lwgeom_from_gml calls gml_reproject_pa which, for PROJ before 6, called GetProj4String.
 	 * That function requires access to spatial_ref_sys, so in order to have it ready we need to ensure
 	 * the internal cache is initialized
@@ -303,12 +303,12 @@ static xmlNodePtr get_xlink_node(xmlNodePtr xnode)
  * Use Proj to reproject a given POINTARRAY
 static POINTARRAY *
 gml_reproject_pa(POINTARRAY *pa, int32_t srid_in, int32_t srid_out)
-	PJ pj;
+	LWPROJ pj;
 	char *text_in, *text_out;
 	if (srid_in == SRID_UNKNOWN) return pa; /* nothing to do */
@@ -333,16 +333,12 @@ gml_reproject_pa(POINTARRAY *pa, int32_t srid_in, int32_t srid_out)
 	return pa;
-#else
- * TODO: rework GML projection handling to skip the spatial_ref_sys
- * lookups, and use the Proj 6+ EPSG catalogue and built-in SRID
- * lookups directly. Drop this ugly hack.
+#else /* POSTGIS_PROJ_VERSION >= 61 */
 static POINTARRAY *
 gml_reproject_pa(POINTARRAY *pa, int32_t epsg_in, int32_t epsg_out)
-	PJ *pj;
 	LWPROJ *lwp;
 	char text_in[16];
 	char text_out[16];
@@ -358,27 +354,26 @@ gml_reproject_pa(POINTARRAY *pa, int32_t epsg_in, int32_t epsg_out)
 	snprintf(text_in, 16, "EPSG:%d", epsg_in);
 	snprintf(text_out, 16, "EPSG:%d", epsg_out);
-	pj = proj_create_crs_to_crs(NULL, text_in, text_out, NULL);
-	lwp = lwproj_from_PJ(pj, LW_FALSE);
+	lwp = lwproj_from_str(text_in, text_out);
 	if (!lwp)
-		proj_destroy(pj);
 		gml_lwpgerror("Could not create LWPROJ*", 57);
 		return NULL;
 	if (ptarray_transform(pa, lwp) == LW_FAILURE)
-		proj_destroy(pj);
 		elog(ERROR, "gml_reproject_pa: reprojection failed");
 		return NULL;
-	proj_destroy(pj);
+	proj_destroy(lwp->pj);
 	pfree(lwp);
 	return pa;
 #endif /* POSTGIS_PROJ_VERSION */
diff --git a/postgis/lwgeom_transform.c b/postgis/lwgeom_transform.c
index fbd3d89..80f7b25 100644
--- a/postgis/lwgeom_transform.c
+++ b/postgis/lwgeom_transform.c
@@ -152,7 +152,7 @@ Datum transform_geom(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(postgis_proj_version);
 Datum postgis_proj_version(PG_FUNCTION_ARGS)
 	const char *ver = pj_get_release();
 	text *result = cstring_to_text(ver);
 #else
Summary of changes:
 .gitignore                     |   2 +-
 liblwgeom/liblwgeom.h.in       |  44 +++--
 liblwgeom/lwgeom_transform.c   | 384 +++++++++++------------------------------
 libpgcommon/lwgeom_transform.c |  30 ++--
 libpgcommon/lwgeom_transform.h |   2 +-
 postgis/lwgeom_in_gml.c        |  25 ++-
 postgis/lwgeom_transform.c     |   2 +-
 7 files changed, 150 insertions(+), 339 deletions(-)
hooks/post-receive
