[postgis-tickets] [PostGIS] #4916: st_asgeobuf() with WINDOW PARTITION crashes server
trac at osgeo.org
Sat Jul 31 21:31:47 PDT 2021
Reporter: Robins | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.1.4
Component: postgis | Version: 3.0.x
Resolution: | Keywords: st_asgeobuf
Comment (by robe):
Confirmed crashes on PostGIS 3.1.3 against PostgreSQL 14beta2.
Backtrace looks like:
Backtrace stopped: previous frame inner to this frame (corrupt stack?)
(gdb) cont
Continuing.
[Thread 6848.0x433c exited with code 0]
Thread 1 received signal SIGSEGV, Segmentation fault.
[Switching to Thread 6848.0xf44]
pg_detoast_datum (datum=0x0) at fmgr.c:1724
1724 if (VARATT_IS_EXTENDED(datum))
(gdb) bt
#0 pg_detoast_datum (datum=0x0) at fmgr.c:1724
#1 0x000000006f004ead in pgis_asgeobuf_transfn (fcinfo=0x520e990)
at lwgeom_out_geobuf.c:75
#2 0x000000000064a2f1 in advance_windowaggregate (
winstate=winstate at entry=0x533b0a8, perfuncstate=0x84fb2f0,
peraggstate=0x84fb140) at nodeWindowAgg.c:345
#3 0x000000000064e15b in eval_windowaggregates (winstate=0x533b0a8)
at nodeWindowAgg.c:964
#4 ExecWindowAgg (pstate=0x533b0a8) at nodeWindowAgg.c:2207
#5 0x000000000060c5ba in ExecProcNode (node=0x533b0a8)
at ../../../src/include/executor/executor.h:257
#6 ExecutePlan (execute_once=<optimized out>, dest=0x84a3630,
direction=<optimized out>, numberTuples=0, sendTuples=<optimized out>,
operation=CMD_SELECT, use_parallel_mode=<optimized out>,
planstate=0x533b0a8, estate=0x533ae70) at execMain.c:1551
#7 standard_ExecutorRun (queryDesc=0x84b5aa0, direction=<optimized out>,
count=0, execute_once=<optimized out>) at execMain.c:361
#8 0x00000000007bfc7b in PortalRunSelect (portal=portal at entry=0x52dc590,
forward=forward at entry=true, count=0, count at entry=2147483647,
dest=dest at entry=0x84a3630) at pquery.c:919
#9 0x00000000007c195c in PortalRun (portal=portal at entry=0x52dc590,
count=count at entry=2147483647, isTopLevel=isTopLevel at entry=true,
run_once=run_once at entry=true, dest=dest at entry=0x84a3630,
altdest=altdest at entry=0x84a3630, qc=qc at entry=0x520f360) at
pquery.c:763
#10 0x00000000007ba13b in exec_simple_query (
query_string=0x53141e0 " SELECT public.st_asgeobuf(NULL::pg_class,
version() )
over (partition by RANDOM());") at postgres.c:1214
#11 0x00000000007bd998 in PostgresMain (argc=argc at entry=1,
argv=argv at entry=0x520f980, dbname=<optimized out>,
username=0x1d8c10 "postgres") at postgres.c:4486
#12 0x000000000071faa1 in BackendRun (port=0x520f7b0, port=0x520f7b0)
at postmaster.c:4507
#13 SubPostmasterMain (argc=argc at entry=3, argv=argv at entry=0x1d6b00)
at postmaster.c:5020
#14 0x0000000000963c73 in main (argc=3, argv=0x1d6b00) at main.c:186
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4916#comment:6>
