[postgis-tickets] [PostGIS] #4864: addedge test failure
PostGIS trac at osgeo.org
Wed Mar 3 14:00:22 PST 2021
  Reporter:  pramsey   |      Owner:  strk
      Type:  defect    |     Status:  closed
  Priority:  high      |  Milestone:  PostGIS 3.2.0
 Component:  topology  |    Version:  master
Resolution:  fixed     |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  assigned => closed
 * resolution:   => fixed
Comment:
 In [changeset:"289bb4842d039b7ed6abc7180d2208c0a9ef474c/git" 289bb48/git]:
 #!CommitTicketReference repository="git"
 revision="289bb4842d039b7ed6abc7180d2208c0a9ef474c"
 Do not rely on ST_PointOnSurface ( MULTIPOINT )
 The operation is not defined in that case, and different GEOS
 version can return different values.
 Closes #4864
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4864#comment:5>
