[postgis-tickets] [PostGIS] #4864: addedge test failure
trac at osgeo.org
Tue Mar 9 19:45:38 PST 2021
Reporter: pramsey | Owner: strk
Type: defect | Status: reopened
Priority: high | Milestone: PostGIS 3.2.0
Component: topology | Version: master
Resolution: | Keywords:
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
This needs to be backported to 3.1 and probably 3.0 as well.
Getting this error on 3.1 with GEOS 3.9.2dev
./topology/test/regress/addedge .. failed (diff expected obtained:
/projects/postgis/tmp/3.1.1dev_pg13_geos3.9_gdal3.2.0w64/test_143_diff)
--- ./topology/test/regress/addedge_expected 2021-03-09
22:31:24.954846700 -0500
+++ /projects/postgis/tmp/3.1.1dev_pg13_geos3.9_gdal3.2.0w64/test_143_out
2021-03-09 22:40:28.949824100 -0500
@@ -17,7 +17,7 @@
e6|6
#770-1|7
#770-2|8
-ERROR: Edge intersects (not on endpoints) with existing edge 7 at or
near point POINT(8 10)
+ERROR: Edge intersects (not on endpoints) with existing edge 7 at or
near point POINT(10 12)
#770-1*|7
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4864#comment:6>
