[postgis-tickets] [SCM] PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots. branch master updated. d7c42220eb672eee3b181686f12f27e13ec81575
Mon Mar 8 08:54:10 PST 2021
the project "PostGIS Buildbots; Jenkins jobs and instructions for setting up winnie and debbie bots.".
       via  d7c42220eb672eee3b181686f12f27e13ec81575 (commit)
      from  fd3f3e792c8812b08b90d2e64ab2653adc4dbf4a (commit)
revisions in full, below.
commit d7c42220eb672eee3b181686f12f27e13ec81575
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Mar 8 11:54:05 2021 -0500
    some changes forgot to commit
diff --git a/debian/jenkins_setup.txt b/debian/jenkins_setup.txt
index fcf0de0..f93dc9e 100644
--- a/debian/jenkins_setup.txt
+++ b/debian/jenkins_setup.txt
@@ -73,7 +73,8 @@ apt install imagemagick
 apt install libxml2 libxml2-dev
 apt install bison
 apt install libiconv-hook1
-apt install subversion
+apt install libprotobuf-c-dev protobuf-c-compiler libprotobuf-c1 #for mvt support
+apt install subversion #no longer needed
 #(for future translation work)
 apt install poxml
 apt install curl
@@ -81,7 +82,7 @@ apt install python-dev
 #wget https://bitbucket.org/pypa/setuptools/raw/bootstrap/ez_setup.py -O - | sudo python
 apt install python-pip
-pip install transifex-client
+pip install transifex-client #for translation
 #for doxygen build and  graph generation
 apt install doxygen graphviz
diff --git a/freebsd/bessie32_setup.txt b/freebsd/bessie32_setup.txt
index 1ca827c..29c6706 100644
--- a/freebsd/bessie32_setup.txt
+++ b/freebsd/bessie32_setup.txt
@@ -152,8 +152,7 @@ git pull
 gmake
 pkg search postgresql #shows all postgresql
 pkg install postgresql11-contrib #needed to get citext
-#   -Wl,-rpath=/usr/local/lib/gcc9
+#note said this may be needed for compiling   -Wl,-rpath=/usr/local/lib/gcc9
 sudo gmake install
 sudo gmake installcheck PGUSER=postgres
 sudo cpan TAP::Parser::SourceHandler::pgTAP
\ No newline at end of file
diff --git a/freebsd/bessie_setup.txt b/freebsd/bessie_setup.txt
index 918c550..3997540 100644
--- a/freebsd/bessie_setup.txt
+++ b/freebsd/bessie_setup.txt
@@ -154,14 +154,16 @@ rm -rf /home/jenkin/tmp/* #had 11G of junk
 pkg upgrade #upgraded pkg: 1.13.2 -> 1.15.10
 #for pgtap tests needed for pgrouting
+pkg search postgresql #shows all postgresql
+pkg install postgresql11-contrib #needed to get citext
 cd /root
 git clone https://github.com/theory/pgtap.git
 cd pgtap
 git pull
 gmake
-pkg search postgresql #shows all postgresql
-pkg install postgresql11-contrib #needed to get citext
-#note said this may be needed for compiling   -Wl,-rpath=/usr/local/lib/gcc9
 sudo gmake install
diff --git a/raspberry_pi/berrie.txt b/raspberry_pi/berrie.txt
index 38c66de..340b1fa 100644
--- a/raspberry_pi/berrie.txt
+++ b/raspberry_pi/berrie.txt
@@ -8,7 +8,7 @@ apt install libjson-c-dev
 apt install dblatex
-apt install bison
+apt install bison flex
 apt install proj
diff --git a/raspberry_pi/berrie64.txt b/raspberry_pi/berrie64.txt
index a1e480f..3b34aee 100644
--- a/raspberry_pi/berrie64.txt
+++ b/raspberry_pi/berrie64.txt
@@ -1,9 +1,10 @@
-berrie64 is running 64-bit Arm Raspberry Pie
+#berrie64 is running 64-bit Arm Raspberry Pie
+#Debian GNU/Linux 10 (buster)
 sudo bash
 apt install default-jdk
 apt install autoconf libtool build-essential
-apt install libreadline6 libreadline6-dev zlib1g-dev
+apt install libreadline7 libreadline7-dev zlib1g-dev
 apt install libcunit1-dev libcunit1-doc libcunit1
 apt install docbook
 apt install libxml2-dev xsltproc docbook-xsl docbook-mathml gettext
@@ -16,6 +17,7 @@ apt install libiconv-hook1
 apt install git
 apt install proj-bin
 apt install postgresql-server-dev
+#installed geos 3.7.1
 apt install libgeos libgeos-dev libproj-dev
 apt install libgdal-dev
 apt install pkg-config
Summary of changes:
 debian/jenkins_setup.txt   | 5 +++--
 freebsd/bessie32_setup.txt | 3 +--
 freebsd/bessie_setup.txt   | 8 +++++---
 raspberry_pi/berrie.txt    | 2 +-
 raspberry_pi/berrie64.txt  | 6 ++++--
 5 files changed, 14 insertions(+), 10 deletions(-)
hooks/post-receive
