[postgis-tickets] [PostGIS] #4872: Failure on windows - wkt_input
trac at osgeo.org
Mon Mar 8 22:33:24 PST 2021
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Keywords: |
I vaguely remember this failing beofre and Raul did something:
-------------- Dependencies --------------
GEOS config: /projects/geos/rel-3.9w64gcc81/bin/geos-config
GEOS version: 3.9.2dev
GDAL config: /projects/gdal/rel-3.2.1w64gcc81/bin/gdal-config
GDAL version: 3.2.1
SFCGAL config: /projects/CGAL/rel-sfcgal-1.3.9w64gcc81/bin
/sfcgal-config
SFCGAL version: 1.3.8
PostgreSQL config:
/projects/postgresql/rel/pg11w64gcc81/bin/pg_config
PostgreSQL version: PostgreSQL 11.2
PROJ4 version: 71
Libxml2 config: /projects/libxml/rel-
libxml2-2.9.9w64gcc81/bin/xml2-config
Libxml2 version: 2.9.9
JSON-C support: yes
protobuf support: yes
protobuf-c version: 1002001
PCRE support: yes
Perl: /usr/bin/perl
--------------- Extensions ---------------
Suite: wkt_input
Test: test_wkt_in_point ...FAILED
1. cu_in_wkt.c:108 - CU_ASSERT_STRING_EQUAL(r,s)
I'm not sure how long this has been broken because build has been broken
because of GEOS 3.10 issue I am having compiling so I flipped to 3.9dev.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4872>
