[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-114-g2a73173
git at osgeo.org
git at osgeo.org
Tue Mar 9 18:58:30 PST 2021
the project "PostGIS".
via 2a73173e3b32400521bd3e8a7e09c9d6ca531838 (commit)
from d758f50258f36905e9fbfcdece276060ec8b3762 (commit)
revisions in full, below.
commit 2a73173e3b32400521bd3e8a7e09c9d6ca531838
Author: Regina Obe <lr at pcorp.us>
Date: Tue Mar 9 21:58:22 2021 -0500
fix from pramsey for NaN on mingw64. Closes #4872
diff --git a/liblwgeom/lwin_wkt_lex.c b/liblwgeom/lwin_wkt_lex.c
index 6cd2fe2..f194112 100644
--- a/liblwgeom/lwin_wkt_lex.c
+++ b/liblwgeom/lwin_wkt_lex.c
@@ -1,6 +1,6 @@
-#line 2 "lwin_wkt_lex.c"
+#line 1 "lwin_wkt_lex.c"
-#line 4 "lwin_wkt_lex.c"
+#line 3 "lwin_wkt_lex.c"
#define YY_INT_ALIGNED short int
@@ -8,11 +8,17 @@
#define yy_create_buffer wkt_yy_create_buffer
#define yy_delete_buffer wkt_yy_delete_buffer
-#define yy_flex_debug wkt_yy_flex_debug
+#define yy_scan_buffer wkt_yy_scan_buffer
+#define yy_scan_string wkt_yy_scan_string
+#define yy_scan_bytes wkt_yy_scan_bytes
#define yy_init_buffer wkt_yy_init_buffer
#define yy_flush_buffer wkt_yy_flush_buffer
#define yy_load_buffer_state wkt_yy_load_buffer_state
#define yy_switch_to_buffer wkt_yy_switch_to_buffer
+#define yypush_buffer_state wkt_yypush_buffer_state
+#define yypop_buffer_state wkt_yypop_buffer_state
+#define yyensure_buffer_stack wkt_yyensure_buffer_stack
+#define yy_flex_debug wkt_yy_flex_debug
#define yyin wkt_yyin
#define yyleng wkt_yyleng
#define yylex wkt_yylex
@@ -27,12 +33,246 @@
#define FLEX_SCANNER
#define YY_FLEX_MAJOR_VERSION 2
-#define YY_FLEX_MINOR_VERSION 5
-#define YY_FLEX_SUBMINOR_VERSION 35
+#define YY_FLEX_MINOR_VERSION 6
+#define YY_FLEX_SUBMINOR_VERSION 4
#if YY_FLEX_SUBMINOR_VERSION > 0
#define FLEX_BETA
#endif
+#ifdef yy_create_buffer
+#define wkt_yy_create_buffer_ALREADY_DEFINED
+#else
+#define yy_create_buffer wkt_yy_create_buffer
+#endif
+#ifdef yy_delete_buffer
+#define wkt_yy_delete_buffer_ALREADY_DEFINED
+#else
+#define yy_delete_buffer wkt_yy_delete_buffer
+#endif
+#ifdef yy_scan_buffer
+#define wkt_yy_scan_buffer_ALREADY_DEFINED
+#else
+#endif
+#ifdef yy_scan_string
+#define wkt_yy_scan_string_ALREADY_DEFINED
+#else
+#endif
+#ifdef yy_scan_bytes
+#define wkt_yy_scan_bytes_ALREADY_DEFINED
+#else
+#endif
+#ifdef yy_init_buffer
+#define wkt_yy_init_buffer_ALREADY_DEFINED
+#else
+#define yy_init_buffer wkt_yy_init_buffer
+#endif
+#ifdef yy_flush_buffer
+#define wkt_yy_flush_buffer_ALREADY_DEFINED
+#else
+#define yy_flush_buffer wkt_yy_flush_buffer
+#endif
+#ifdef yy_load_buffer_state
+#define wkt_yy_load_buffer_state_ALREADY_DEFINED
+#else
+#define yy_load_buffer_state wkt_yy_load_buffer_state
+#endif
+#ifdef yy_switch_to_buffer
+#define wkt_yy_switch_to_buffer_ALREADY_DEFINED
+#else
+#define yy_switch_to_buffer wkt_yy_switch_to_buffer
+#endif
+#ifdef yypush_buffer_state
+#define wkt_yypush_buffer_state_ALREADY_DEFINED
+#else
+#endif
+#ifdef yypop_buffer_state
+#define wkt_yypop_buffer_state_ALREADY_DEFINED
+#else
+#endif
+#ifdef yyensure_buffer_stack
+#define wkt_yyensure_buffer_stack_ALREADY_DEFINED
+#else
+#endif
+#ifdef yylex
+#define wkt_yylex_ALREADY_DEFINED
+#else
+#define yylex wkt_yylex
+#endif
+#ifdef yyrestart
+#define wkt_yyrestart_ALREADY_DEFINED
+#else
+#define yyrestart wkt_yyrestart
+#endif
+#ifdef yylex_init
+#define wkt_yylex_init_ALREADY_DEFINED
+#else
+#define yylex_init wkt_yylex_init
+#endif
+#ifdef yylex_init_extra
+#define wkt_yylex_init_extra_ALREADY_DEFINED
+#else
+#define yylex_init_extra wkt_yylex_init_extra
+#endif
+#ifdef yylex_destroy
+#define wkt_yylex_destroy_ALREADY_DEFINED
+#else
+#define yylex_destroy wkt_yylex_destroy
+#endif
+#ifdef yyget_debug
+#define wkt_yyget_debug_ALREADY_DEFINED
+#else
+#define yyget_debug wkt_yyget_debug
+#endif
+#ifdef yyset_debug
+#define wkt_yyset_debug_ALREADY_DEFINED
+#else
+#define yyset_debug wkt_yyset_debug
+#endif
+#ifdef yyget_extra
+#define wkt_yyget_extra_ALREADY_DEFINED
+#else
+#define yyget_extra wkt_yyget_extra
+#endif
+#ifdef yyset_extra
+#define wkt_yyset_extra_ALREADY_DEFINED
+#else
+#define yyset_extra wkt_yyset_extra
+#endif
+#ifdef yyget_in
+#define wkt_yyget_in_ALREADY_DEFINED
+#else
+#define yyget_in wkt_yyget_in
+#endif
+#ifdef yyset_in
+#define wkt_yyset_in_ALREADY_DEFINED
+#else
+#define yyset_in wkt_yyset_in
+#endif
+#ifdef yyget_out
+#define wkt_yyget_out_ALREADY_DEFINED
+#else
+#define yyget_out wkt_yyget_out
+#endif
+#ifdef yyset_out
+#define wkt_yyset_out_ALREADY_DEFINED
+#else
+#define yyset_out wkt_yyset_out
+#endif
+#ifdef yyget_leng
+#define wkt_yyget_leng_ALREADY_DEFINED
+#else
+#define yyget_leng wkt_yyget_leng
+#endif
+#ifdef yyget_text
+#define wkt_yyget_text_ALREADY_DEFINED
+#else
+#define yyget_text wkt_yyget_text
+#endif
+#ifdef yyget_lineno
+#define wkt_yyget_lineno_ALREADY_DEFINED
+#else
+#define yyget_lineno wkt_yyget_lineno
+#endif
+#ifdef yyset_lineno
+#define wkt_yyset_lineno_ALREADY_DEFINED
+#else
+#define yyset_lineno wkt_yyset_lineno
+#endif
+#ifdef yywrap
+#define wkt_yywrap_ALREADY_DEFINED
+#else
+#define yywrap wkt_yywrap
+#endif
+#ifdef yyalloc
+#define wkt_yyalloc_ALREADY_DEFINED
+#else
+#define yyalloc wkt_yyalloc
+#endif
+#ifdef yyrealloc
+#define wkt_yyrealloc_ALREADY_DEFINED
+#else
+#define yyrealloc wkt_yyrealloc
+#endif
+#ifdef yyfree
+#define wkt_yyfree_ALREADY_DEFINED
+#else
+#define yyfree wkt_yyfree
+#endif
+#ifdef yytext
+#define wkt_yytext_ALREADY_DEFINED
+#else
+#define yytext wkt_yytext
+#endif
+#ifdef yyleng
+#define wkt_yyleng_ALREADY_DEFINED
+#else
+#define yyleng wkt_yyleng
+#endif
+#ifdef yyin
+#define wkt_yyin_ALREADY_DEFINED
+#else
+#define yyin wkt_yyin
+#endif
+#ifdef yyout
+#define wkt_yyout_ALREADY_DEFINED
+#else
+#define yyout wkt_yyout
+#endif
+#ifdef yy_flex_debug
+#define wkt_yy_flex_debug_ALREADY_DEFINED
+#else
+#endif
+#ifdef yylineno
+#define wkt_yylineno_ALREADY_DEFINED
+#else
+#define yylineno wkt_yylineno
+#endif
/* First, we deal with platform-specific or compiler-specific issues. */
/* begin standard C headers. */
@@ -66,7 +306,6 @@ typedef int16_t flex_int16_t;
typedef uint16_t flex_uint16_t;
typedef int32_t flex_int32_t;
typedef uint32_t flex_uint32_t;
-typedef uint64_t flex_uint64_t;
#else
typedef signed char flex_int8_t;
typedef short int flex_int16_t;
@@ -74,7 +313,6 @@ typedef int flex_int32_t;
typedef unsigned char flex_uint8_t;
typedef unsigned short int flex_uint16_t;
typedef unsigned int flex_uint32_t;
-#endif /* ! C99 */
/* Limits of integral types. */
#ifndef INT8_MIN
@@ -105,63 +343,61 @@ typedef unsigned int flex_uint32_t;
#define UINT32_MAX (4294967295U)
#endif
-#endif /* ! FLEXINT_H */
-#ifdef __cplusplus
-/* The "const" storage-class-modifier is valid. */
-#define YY_USE_CONST
-#else /* ! __cplusplus */
+#ifndef SIZE_MAX
+#define SIZE_MAX (~(size_t)0)
+#endif
-/* C99 requires __STDC__ to be defined as 1. */
-#if defined (__STDC__)
+#endif /* ! C99 */
+#endif /* ! FLEXINT_H */
-#endif /* defined (__STDC__) */
-#endif /* ! __cplusplus */
+/* begin standard C++ headers. */
-#ifdef YY_USE_CONST
+/* TODO: this is always defined, so inline it */
#define yyconst const
+#if defined(__GNUC__) && __GNUC__ >= 3
+#define yynoreturn __attribute__((__noreturn__))
#else
-#define yyconst
+#define yynoreturn
#endif
/* Returned upon end-of-file. */
#define YY_NULL 0
-/* Promotes a possibly negative, possibly signed char to an unsigned
- * integer for use as an array index. If the signed char is negative,
- * we want to instead treat it as an 8-bit unsigned char, hence the
- * double cast.
+/* Promotes a possibly negative, possibly signed char to an
+ * integer in range [0..255] for use as an array index.
-#define YY_SC_TO_UI(c) ((unsigned int) (unsigned char) c)
+#define YY_SC_TO_UI(c) ((YY_CHAR) (c))
/* Enter a start condition. This macro really ought to take a parameter,
* but we do it the disgusting crufty way forced on us by the ()-less
* definition of BEGIN.
#define BEGIN (yy_start) = 1 + 2 *
/* Translate the current start state into a value that can be later handed
* to BEGIN to return to the state. The YYSTATE alias is for lex
* compatibility.
#define YY_START (((yy_start) - 1) / 2)
#define YYSTATE YY_START
/* Action number for EOF rule of a given start state. */
#define YY_STATE_EOF(state) (YY_END_OF_BUFFER + state + 1)
/* Special action meaning "start processing a new file". */
-#define YY_NEW_FILE wkt_yyrestart(wkt_yyin )
+#define YY_NEW_FILE yyrestart( yyin )
#define YY_END_OF_BUFFER_CHAR 0
/* Size of default input buffer. */
#ifndef YY_BUF_SIZE
+#ifdef __ia64__
+/* On IA-64, the buffer size is 16k, not 8k.
+ * Moreover, YY_BUF_SIZE is 2*YY_READ_BUF_SIZE in the general case.
+ * Ditto for the __ia64__ case accordingly.
+#define YY_BUF_SIZE 32768
+#else
#define YY_BUF_SIZE 16384
+#endif /* __ia64__ */
#endif
/* The state buf must be large enough to hold one state per character in the main buffer.
@@ -178,30 +414,30 @@ typedef struct yy_buffer_state *YY_BUFFER_STATE;
typedef size_t yy_size_t;
#endif
-extern yy_size_t wkt_yyleng;
+extern int yyleng;
-extern FILE *wkt_yyin, *wkt_yyout;
+extern FILE *yyin, *yyout;
#define EOB_ACT_CONTINUE_SCAN 0
#define EOB_ACT_END_OF_FILE 1
#define EOB_ACT_LAST_MATCH 2
#define YY_LESS_LINENO(n)
+ #define YY_LINENO_REWIND_TO(ptr)
/* Return all but the first "n" matched characters back to the input stream. */
#define yyless(n) \
do \
- /* Undo effects of setting up wkt_yytext. */ \
+ /* Undo effects of setting up yytext. */ \
int yyless_macro_arg = (n); \
YY_LESS_LINENO(yyless_macro_arg);\
*yy_cp = (yy_hold_char); \
YY_RESTORE_YY_MORE_OFFSET \
(yy_c_buf_p) = yy_cp = yy_bp + yyless_macro_arg - YY_MORE_ADJ; \
- YY_DO_BEFORE_ACTION; /* set up wkt_yytext again */ \
+ YY_DO_BEFORE_ACTION; /* set up yytext again */ \
while ( 0 )
#define unput(c) yyunput( c, (yytext_ptr) )
#ifndef YY_STRUCT_YY_BUFFER_STATE
@@ -216,12 +452,12 @@ struct yy_buffer_state
/* Size of input buffer in bytes, not including room for EOB
* characters.
- yy_size_t yy_buf_size;
+ int yy_buf_size;
/* Number of characters read into yy_ch_buf, not including EOB
* characters.
- yy_size_t yy_n_chars;
+ int yy_n_chars;
/* Whether we "own" the buffer - i.e., we know we created it,
* and can realloc() it to grow it, and should free() it to
@@ -244,7 +480,7 @@ struct yy_buffer_state
int yy_bs_lineno; /**< The line count. */
int yy_bs_column; /**< The column count. */
/* Whether to try to fill the input buffer when we reach the
* end of it.
@@ -261,8 +497,8 @@ struct yy_buffer_state
* possible backing-up.
* When we actually see the EOF, we change the status to "new"
- * (via wkt_yyrestart()), so that the user can continue scanning by
- * just pointing wkt_yyin at a new input file.
+ * (via yyrestart()), so that the user can continue scanning by
+ * just pointing yyin at a new input file.
#define YY_BUFFER_EOF_PENDING 2
@@ -272,7 +508,7 @@ struct yy_buffer_state
/* Stack of input buffers. */
static size_t yy_buffer_stack_top = 0; /**< index of top of stack. */
static size_t yy_buffer_stack_max = 0; /**< capacity of stack. */
-static YY_BUFFER_STATE * yy_buffer_stack = 0; /**< Stack as an array. */
+static YY_BUFFER_STATE * yy_buffer_stack = NULL; /**< Stack as an array. */
/* We provide macros for accessing buffer states in case in the
* future we want to put the buffer states in a more general
@@ -283,106 +519,101 @@ static YY_BUFFER_STATE * yy_buffer_stack = 0; /**< Stack as an array. */
#define YY_CURRENT_BUFFER ( (yy_buffer_stack) \
? (yy_buffer_stack)[(yy_buffer_stack_top)] \
: NULL)
/* Same as previous macro, but useful when we know that the buffer stack is not
* NULL or when we need an lvalue. For internal use only.
#define YY_CURRENT_BUFFER_LVALUE (yy_buffer_stack)[(yy_buffer_stack_top)]
-/* yy_hold_char holds the character lost when wkt_yytext is formed. */
+/* yy_hold_char holds the character lost when yytext is formed. */
static char yy_hold_char;
-static yy_size_t yy_n_chars; /* number of characters read into yy_ch_buf */
-yy_size_t wkt_yyleng;
+static int yy_n_chars; /* number of characters read into yy_ch_buf */
+int yyleng;
/* Points to current character in buffer. */
-static char *yy_c_buf_p = (char *) 0;
+static char *yy_c_buf_p = NULL;
static int yy_init = 0; /* whether we need to initialize */
static int yy_start = 0; /* start state number */
-/* Flag which is used to allow wkt_yywrap()'s to do buffer switches
- * instead of setting up a fresh wkt_yyin. A bit of a hack ...
+/* Flag which is used to allow yywrap()'s to do buffer switches
+ * instead of setting up a fresh yyin. A bit of a hack ...
static int yy_did_buffer_switch_on_eof;
-void wkt_yyrestart (FILE *input_file );
-void wkt_yy_switch_to_buffer (YY_BUFFER_STATE new_buffer );
-YY_BUFFER_STATE wkt_yy_create_buffer (FILE *file,int size );
-void wkt_yy_delete_buffer (YY_BUFFER_STATE b );
-void wkt_yy_flush_buffer (YY_BUFFER_STATE b );
-void wkt_yypush_buffer_state (YY_BUFFER_STATE new_buffer );
-void wkt_yypop_buffer_state (void );
+void yyrestart ( FILE *input_file );
+void yy_switch_to_buffer ( YY_BUFFER_STATE new_buffer );
+YY_BUFFER_STATE yy_create_buffer ( FILE *file, int size );
+void yy_delete_buffer ( YY_BUFFER_STATE b );
+void yy_flush_buffer ( YY_BUFFER_STATE b );
+void yypush_buffer_state ( YY_BUFFER_STATE new_buffer );
+void yypop_buffer_state ( void );
-static void wkt_yyensure_buffer_stack (void );
-static void wkt_yy_load_buffer_state (void );
-static void wkt_yy_init_buffer (YY_BUFFER_STATE b,FILE *file );
+static void yyensure_buffer_stack ( void );
+static void yy_load_buffer_state ( void );
+static void yy_init_buffer ( YY_BUFFER_STATE b, FILE *file );
+#define YY_FLUSH_BUFFER yy_flush_buffer( YY_CURRENT_BUFFER )
-#define YY_FLUSH_BUFFER wkt_yy_flush_buffer(YY_CURRENT_BUFFER )
+YY_BUFFER_STATE yy_scan_buffer ( char *base, yy_size_t size );
+YY_BUFFER_STATE yy_scan_string ( const char *yy_str );
+YY_BUFFER_STATE yy_scan_bytes ( const char *bytes, int len );
-YY_BUFFER_STATE wkt_yy_scan_buffer (char *base,yy_size_t size );
-YY_BUFFER_STATE wkt_yy_scan_string (yyconst char *yy_str );
-YY_BUFFER_STATE wkt_yy_scan_bytes (yyconst char *bytes,yy_size_t len );
-void *wkt_yyalloc (yy_size_t );
-void *wkt_yyrealloc (void *,yy_size_t );
-void wkt_yyfree (void * );
-#define yy_new_buffer wkt_yy_create_buffer
+void *yyalloc ( yy_size_t );
+void *yyrealloc ( void *, yy_size_t );
+void yyfree ( void * );
+#define yy_new_buffer yy_create_buffer
#define yy_set_interactive(is_interactive) \
if ( ! YY_CURRENT_BUFFER ){ \
- wkt_yyensure_buffer_stack (); \
+ yyensure_buffer_stack (); \
YY_CURRENT_BUFFER_LVALUE = \
- wkt_yy_create_buffer(wkt_yyin,YY_BUF_SIZE ); \
+ yy_create_buffer( yyin, YY_BUF_SIZE ); \
YY_CURRENT_BUFFER_LVALUE->yy_is_interactive = is_interactive; \
#define yy_set_bol(at_bol) \
if ( ! YY_CURRENT_BUFFER ){\
YY_CURRENT_BUFFER_LVALUE->yy_at_bol = at_bol; \
#define YY_AT_BOL() (YY_CURRENT_BUFFER_LVALUE->yy_at_bol)
/* Begin user sect3 */
-#define wkt_yywrap(n) 1
+#define wkt_yywrap() (/*CONSTCOND*/1)
#define YY_SKIP_YYWRAP
+typedef flex_uint8_t YY_CHAR;
-typedef unsigned char YY_CHAR;
-FILE *wkt_yyin = (FILE *) 0, *wkt_yyout = (FILE *) 0;
+FILE *yyin = NULL, *yyout = NULL;
typedef int yy_state_type;
-extern int wkt_yylineno;
-int wkt_yylineno = 1;
+extern int yylineno;
+int yylineno = 1;
-extern char *wkt_yytext;
-#define yytext_ptr wkt_yytext
+extern char *yytext;
+#ifdef yytext_ptr
+#undef yytext_ptr
+#endif
+#define yytext_ptr yytext
-static yy_state_type yy_get_previous_state (void );
-static yy_state_type yy_try_NUL_trans (yy_state_type current_state );
-static int yy_get_next_buffer (void );
-static void yy_fatal_error (yyconst char msg[] );
+static yy_state_type yy_get_previous_state ( void );
+static yy_state_type yy_try_NUL_trans ( yy_state_type current_state );
+static int yy_get_next_buffer ( void );
+static void yynoreturn yy_fatal_error ( const char* msg );
/* Done after the current pattern has been matched and before the
- * corresponding action - sets up wkt_yytext.
+ * corresponding action - sets up yytext.
#define YY_DO_BEFORE_ACTION \
(yytext_ptr) = yy_bp; \
- wkt_yyleng = (yy_size_t) (yy_cp - yy_bp); \
+ yyleng = (int) (yy_cp - yy_bp); \
(yy_hold_char) = *yy_cp; \
*yy_cp = '\0'; \
(yy_c_buf_p) = yy_cp;
#define YY_NUM_RULES 27
#define YY_END_OF_BUFFER 28
/* This struct is not used in this scanner,
@@ -392,7 +623,7 @@ struct yy_trans_info
flex_int32_t yy_verify;
flex_int32_t yy_nxt;
-static yyconst flex_int16_t yy_accept[177] =
+static const flex_int16_t yy_accept[177] =
{ 0,
0, 0, 28, 26, 25, 25, 21, 22, 23, 26,
26, 26, 24, 26, 26, 26, 26, 20, 26, 26,
@@ -415,7 +646,7 @@ static yyconst flex_int16_t yy_accept[177] =
0, 0, 0, 15, 4, 0
-static yyconst flex_int32_t yy_ec[256] =
+static const YY_CHAR yy_ec[256] =
{ 0,
1, 1, 1, 1, 1, 1, 1, 1, 2, 3,
1, 1, 2, 1, 1, 1, 1, 1, 1, 1,
@@ -447,7 +678,7 @@ static yyconst flex_int32_t yy_ec[256] =
1, 1, 1, 1, 1
-static yyconst flex_int32_t yy_meta[53] =
+static const YY_CHAR yy_meta[53] =
{ 0,
1, 1, 1, 1, 1, 1, 1, 1, 1, 1,
@@ -457,7 +688,7 @@ static yyconst flex_int32_t yy_meta[53] =
1, 1
-static yyconst flex_int16_t yy_base[177] =
+static const flex_int16_t yy_base[177] =
{ 0,
0, 0, 374, 391, 51, 53, 391, 391, 391, 48,
362, 57, 391, 41, 41, 52, 49, 42, 59, 50,
@@ -480,7 +711,7 @@ static yyconst flex_int16_t yy_base[177] =
342, 351, 347, 391, 391, 391
-static yyconst flex_int16_t yy_def[177] =
+static const flex_int16_t yy_def[177] =
{ 0,
176, 1, 176, 176, 176, 176, 176, 176, 176, 176,
176, 176, 176, 176, 176, 176, 176, 176, 176, 176,
@@ -503,7 +734,7 @@ static yyconst flex_int16_t yy_def[177] =
176, 176, 176, 176, 176, 0
-static yyconst flex_int16_t yy_nxt[444] =
+static const flex_int16_t yy_nxt[444] =
{ 0,
4, 5, 6, 7, 8, 4, 9, 10, 11, 12,
13, 4, 4, 14, 4, 15, 4, 16, 4, 4,
@@ -556,7 +787,7 @@ static yyconst flex_int16_t yy_nxt[444] =
176, 176, 176
-static yyconst flex_int16_t yy_chk[444] =
+static const flex_int16_t yy_chk[444] =
{ 0,
@@ -612,8 +843,8 @@ static yyconst flex_int16_t yy_chk[444] =
static yy_state_type yy_last_accepting_state;
static char *yy_last_accepting_cpos;
-extern int wkt_yy_flex_debug;
-int wkt_yy_flex_debug = 0;
+extern int yy_flex_debug;
+int yy_flex_debug = 0;
/* The intent behind this definition is that it'll catch
* any uses of REJECT which flex missed.
@@ -622,7 +853,7 @@ int wkt_yy_flex_debug = 0;
#define yymore() yymore_used_but_not_detected
#define YY_MORE_ADJ 0
#define YY_RESTORE_YY_MORE_OFFSET
-char *wkt_yytext;
+char *yytext;
#line 1 "lwin_wkt_lex.l"
#line 2 "lwin_wkt_lex.l"
@@ -654,16 +885,28 @@ static void wkt_lexer_unknown()
* debugging info.
#define YY_USER_ACTION do { \
- wkt_yylloc.first_line = wkt_yylloc.last_line = wkt_yylineno; \
+ wkt_yylloc.first_line = wkt_yylloc.last_line = yylineno; \
wkt_yylloc.first_column = wkt_yylloc.last_column; \
- wkt_yylloc.last_column += wkt_yyleng; \
+ wkt_yylloc.last_column += yyleng; \
LWDEBUGF(5,"lex: %s", wkt_yytext); \
} while (0);
+* Ensure we have a definition of NAN to use when encountering
+* NAN tokens.
+#ifndef _GNU_SOURCE
+#define _GNU_SOURCE
+#endif
+#include <math.h>
+#ifndef NAN
+#define NAN 0.0/0.0
+#endif
+#line 906 "lwin_wkt_lex.c"
#define YY_NO_INPUT 1
/* Suppress the default implementations. */
-#line 667 "lwin_wkt_lex.c"
+#line 909 "lwin_wkt_lex.c"
#define INITIAL 0
@@ -679,36 +922,36 @@ static void wkt_lexer_unknown()
#define YY_EXTRA_TYPE void *
#endif
-static int yy_init_globals (void );
+static int yy_init_globals ( void );
/* Accessor methods to globals.
These are made visible to non-reentrant scanners for convenience. */
-int wkt_yylex_destroy (void );
+int yylex_destroy ( void );
-int wkt_yyget_debug (void );
+int yyget_debug ( void );
-void wkt_yyset_debug (int debug_flag );
+void yyset_debug ( int debug_flag );
-YY_EXTRA_TYPE wkt_yyget_extra (void );
+YY_EXTRA_TYPE yyget_extra ( void );
-void wkt_yyset_extra (YY_EXTRA_TYPE user_defined );
+void yyset_extra ( YY_EXTRA_TYPE user_defined );
-FILE *wkt_yyget_in (void );
+FILE *yyget_in ( void );
-void wkt_yyset_in (FILE * in_str );
+void yyset_in ( FILE * _in_str );
-FILE *wkt_yyget_out (void );
+FILE *yyget_out ( void );
-void wkt_yyset_out (FILE * out_str );
+void yyset_out ( FILE * _out_str );
-yy_size_t wkt_yyget_leng (void );
+ int yyget_leng ( void );
-char *wkt_yyget_text (void );
+char *yyget_text ( void );
-int wkt_yyget_lineno (void );
+int yyget_lineno ( void );
-void wkt_yyset_lineno (int line_number );
+void yyset_lineno ( int _line_number );
/* Macros after this point can all be overridden by user definitions in
* section 1.
@@ -716,33 +959,41 @@ void wkt_yyset_lineno (int line_number );
#ifndef YY_SKIP_YYWRAP
#ifdef __cplusplus
-extern "C" int wkt_yywrap (void );
+extern "C" int yywrap ( void );
#else
-extern int wkt_yywrap (void );
+extern int yywrap ( void );
+#endif
#endif
+#ifndef YY_NO_UNPUT
#endif
#ifndef yytext_ptr
-static void yy_flex_strncpy (char *,yyconst char *,int );
+static void yy_flex_strncpy ( char *, const char *, int );
#endif
#ifdef YY_NEED_STRLEN
-static int yy_flex_strlen (yyconst char * );
+static int yy_flex_strlen ( const char * );
#endif
#ifndef YY_NO_INPUT
#ifdef __cplusplus
-static int yyinput (void );
+static int yyinput ( void );
#else
-static int input (void );
+static int input ( void );
#endif
#endif
/* Amount of stuff to slurp up with each read. */
#ifndef YY_READ_BUF_SIZE
+#ifdef __ia64__
+/* On IA-64, the buffer size is 16k, not 8k */
+#define YY_READ_BUF_SIZE 16384
+#else
#define YY_READ_BUF_SIZE 8192
#endif
/* Copy whatever the last rule matched to the standard output. */
@@ -750,7 +1001,7 @@ static int input (void );
/* This used to be an fputs(), but since the string might contain NUL's,
* we now use fwrite().
-#define ECHO fwrite( wkt_yytext, wkt_yyleng, 1, wkt_yyout )
+#define ECHO do { if (fwrite( yytext, (size_t) yyleng, 1, yyout )) {} } while (0)
#endif
/* Gets input and stuffs it into "buf". number of characters read, or YY_NULL,
@@ -761,20 +1012,20 @@ static int input (void );
if ( YY_CURRENT_BUFFER_LVALUE->yy_is_interactive ) \
int c = '*'; \
- yy_size_t n; \
+ int n; \
for ( n = 0; n < max_size && \
- (c = getc( wkt_yyin )) != EOF && c != '\n'; ++n ) \
+ (c = getc( yyin )) != EOF && c != '\n'; ++n ) \
buf[n] = (char) c; \
if ( c == '\n' ) \
buf[n++] = (char) c; \
- if ( c == EOF && ferror( wkt_yyin ) ) \
+ if ( c == EOF && ferror( yyin ) ) \
YY_FATAL_ERROR( "input in flex scanner failed" ); \
result = n; \
else \
errno=0; \
- while ( (result = fread(buf, 1, max_size, wkt_yyin))==0 && ferror(wkt_yyin)) \
+ while ( (result = (int) fread(buf, 1, (yy_size_t) max_size, yyin)) == 0 && ferror(yyin)) \
if( errno != EINTR) \
@@ -782,7 +1033,7 @@ static int input (void );
break; \
errno=0; \
- clearerr(wkt_yyin); \
+ clearerr(yyin); \
@@ -815,12 +1066,12 @@ static int input (void );
#ifndef YY_DECL
#define YY_DECL_IS_OURS 1
-extern int wkt_yylex (void);
+extern int yylex (void);
-#define YY_DECL int wkt_yylex (void)
+#define YY_DECL int yylex (void)
#endif /* !YY_DECL */
-/* Code executed at the beginning of each rule, after wkt_yytext and wkt_yyleng
+/* Code executed at the beginning of each rule, after yytext and yyleng
* have been set up.
#ifndef YY_USER_ACTION
@@ -829,7 +1080,7 @@ extern int wkt_yylex (void);
/* Code executed at the end of each rule. */
#ifndef YY_BREAK
-#define YY_BREAK break;
+#define YY_BREAK /*LINTED*/break;
#endif
#define YY_RULE_SETUP \
@@ -839,15 +1090,10 @@ extern int wkt_yylex (void);
YY_DECL
- register yy_state_type yy_current_state;
- register char *yy_cp, *yy_bp;
- register int yy_act;
+ yy_state_type yy_current_state;
+ char *yy_cp, *yy_bp;
+ int yy_act;
-#line 49 "lwin_wkt_lex.l"
-#line 850 "lwin_wkt_lex.c"
if ( !(yy_init) )
(yy_init) = 1;
@@ -859,26 +1105,32 @@ YY_DECL
if ( ! (yy_start) )
(yy_start) = 1; /* first start state */
- if ( ! wkt_yyin )
- wkt_yyin = stdin;
+ if ( ! yyin )
+ yyin = stdin;
- if ( ! wkt_yyout )
- wkt_yyout = stdout;
+ if ( ! yyout )
+ yyout = stdout;
if ( ! YY_CURRENT_BUFFER ) {
- wkt_yy_load_buffer_state( );
+ yy_load_buffer_state( );
- while ( 1 ) /* loops until end-of-file is reached */
+#line 60 "lwin_wkt_lex.l"
+#line 1127 "lwin_wkt_lex.c"
+ while ( /*CONSTCOND*/1 ) /* loops until end-of-file is reached */
yy_cp = (yy_c_buf_p);
- /* Support of wkt_yytext. */
+ /* Support of yytext. */
/* yy_bp points to the position in yy_ch_buf of the start of
@@ -890,7 +1142,7 @@ YY_DECL
yy_match:
do
- register YY_CHAR yy_c = yy_ec[YY_SC_TO_UI(*yy_cp)];
+ YY_CHAR yy_c = yy_ec[YY_SC_TO_UI(*yy_cp)] ;
if ( yy_accept[yy_current_state] )
(yy_last_accepting_state) = yy_current_state;
@@ -900,9 +1152,9 @@ yy_match:
yy_current_state = (int) yy_def[yy_current_state];
if ( yy_current_state >= 177 )
- yy_c = yy_meta[(unsigned int) yy_c];
+ yy_c = yy_meta[yy_c];
- yy_current_state = yy_nxt[yy_base[yy_current_state] + (unsigned int) yy_c];
+ yy_current_state = yy_nxt[yy_base[yy_current_state] + yy_c];
++yy_cp;
while ( yy_current_state != 176 );
@@ -928,7 +1180,7 @@ do_action: /* This label is used only to access EOF actions. */
case 1:
/* rule 1 can match eol */
YY_RULE_SETUP
-#line 51 "lwin_wkt_lex.l"
+#line 62 "lwin_wkt_lex.l"
LWDEBUG(5,"DOUBLE");
wkt_yylval.doublevalue = atof(wkt_yytext);
@@ -939,17 +1191,17 @@ YY_RULE_SETUP
case 2:
/* rule 2 can match eol */
YY_RULE_SETUP
-#line 58 "lwin_wkt_lex.l"
+#line 69 "lwin_wkt_lex.l"
LWDEBUG(5,"DOUBLE NAN");
- wkt_yylval.doublevalue = atof(wkt_yytext);
+ wkt_yylval.doublevalue = NAN;
yyless(wkt_yyleng-1);
return DOUBLE_TOK;
YY_BREAK
case 3:
YY_RULE_SETUP
-#line 65 "lwin_wkt_lex.l"
+#line 76 "lwin_wkt_lex.l"
LWDEBUG(5,"SRID");
wkt_yylval.integervalue = wkt_lexer_read_srid(wkt_yytext);
@@ -958,87 +1210,87 @@ YY_RULE_SETUP
YY_BREAK
case 4:
YY_RULE_SETUP
-#line 71 "lwin_wkt_lex.l"
+#line 82 "lwin_wkt_lex.l"
{ return COLLECTION_TOK; }
YY_BREAK
case 5:
YY_RULE_SETUP
-#line 72 "lwin_wkt_lex.l"
+#line 83 "lwin_wkt_lex.l"
{ return MSURFACE_TOK; }
YY_BREAK
case 6:
YY_RULE_SETUP
-#line 73 "lwin_wkt_lex.l"
+#line 84 "lwin_wkt_lex.l"
{ return MPOLYGON_TOK; }
YY_BREAK
case 7:
YY_RULE_SETUP
-#line 74 "lwin_wkt_lex.l"
+#line 85 "lwin_wkt_lex.l"
{ return MCURVE_TOK; }
YY_BREAK
case 8:
YY_RULE_SETUP
-#line 75 "lwin_wkt_lex.l"
+#line 86 "lwin_wkt_lex.l"
{ return MLINESTRING_TOK; }
YY_BREAK
case 9:
YY_RULE_SETUP
-#line 76 "lwin_wkt_lex.l"
+#line 87 "lwin_wkt_lex.l"
{ return MPOINT_TOK; }
YY_BREAK
case 10:
YY_RULE_SETUP
-#line 77 "lwin_wkt_lex.l"
+#line 88 "lwin_wkt_lex.l"
{ return CURVEPOLYGON_TOK; }
YY_BREAK
case 11:
YY_RULE_SETUP
-#line 78 "lwin_wkt_lex.l"
+#line 89 "lwin_wkt_lex.l"
{ return POLYGON_TOK; }
YY_BREAK
case 12:
YY_RULE_SETUP
-#line 79 "lwin_wkt_lex.l"
+#line 90 "lwin_wkt_lex.l"
{ return COMPOUNDCURVE_TOK; }
YY_BREAK
case 13:
YY_RULE_SETUP
-#line 80 "lwin_wkt_lex.l"
+#line 91 "lwin_wkt_lex.l"
{ return CIRCULARSTRING_TOK; }
YY_BREAK
case 14:
YY_RULE_SETUP
-#line 81 "lwin_wkt_lex.l"
+#line 92 "lwin_wkt_lex.l"
{ return LINESTRING_TOK; }
YY_BREAK
case 15:
YY_RULE_SETUP
-#line 82 "lwin_wkt_lex.l"
+#line 93 "lwin_wkt_lex.l"
{ return POLYHEDRALSURFACE_TOK; }
YY_BREAK
case 16:
YY_RULE_SETUP
-#line 83 "lwin_wkt_lex.l"
+#line 94 "lwin_wkt_lex.l"
{ return TRIANGLE_TOK; }
YY_BREAK
case 17:
YY_RULE_SETUP
-#line 84 "lwin_wkt_lex.l"
+#line 95 "lwin_wkt_lex.l"
{ return TIN_TOK; }
YY_BREAK
case 18:
YY_RULE_SETUP
-#line 85 "lwin_wkt_lex.l"
+#line 96 "lwin_wkt_lex.l"
{ return POINT_TOK; }
YY_BREAK
case 19:
YY_RULE_SETUP
-#line 86 "lwin_wkt_lex.l"
+#line 97 "lwin_wkt_lex.l"
{ return EMPTY_TOK; }
YY_BREAK
case 20:
YY_RULE_SETUP
-#line 88 "lwin_wkt_lex.l"
+#line 99 "lwin_wkt_lex.l"
LWDEBUG(5,"DIMENSIONALITY");
wkt_yylval.stringvalue = wkt_yytext;
@@ -1047,33 +1299,33 @@ YY_RULE_SETUP
YY_BREAK
case 21:
YY_RULE_SETUP
-#line 94 "lwin_wkt_lex.l"
+#line 105 "lwin_wkt_lex.l"
{ LWDEBUG(5,"LBRACKET"); return LBRACKET_TOK; }
YY_BREAK
case 22:
YY_RULE_SETUP
-#line 95 "lwin_wkt_lex.l"
+#line 106 "lwin_wkt_lex.l"
{ LWDEBUG(5,"RBRACKET"); return RBRACKET_TOK; }
YY_BREAK
case 23:
YY_RULE_SETUP
-#line 96 "lwin_wkt_lex.l"
+#line 107 "lwin_wkt_lex.l"
{ LWDEBUG(5,"COMMA"); return COMMA_TOK; }
YY_BREAK
case 24:
YY_RULE_SETUP
-#line 97 "lwin_wkt_lex.l"
+#line 108 "lwin_wkt_lex.l"
{ LWDEBUG(5,"SEMICOLON"); return SEMICOLON_TOK; }
YY_BREAK
case 25:
/* rule 25 can match eol */
YY_RULE_SETUP
-#line 99 "lwin_wkt_lex.l"
+#line 110 "lwin_wkt_lex.l"
{ /* ignore whitespace */ LWDEBUG(5,"WHITESPACE"); }
YY_BREAK
case 26:
YY_RULE_SETUP
-#line 101 "lwin_wkt_lex.l"
+#line 112 "lwin_wkt_lex.l"
{ /* Error out and stop parsing on unknown/unexpected characters */
LWDEBUG(5,"UNKNOWN");
wkt_lexer_unknown();
@@ -1082,10 +1334,10 @@ YY_RULE_SETUP
YY_BREAK
case 27:
YY_RULE_SETUP
-#line 107 "lwin_wkt_lex.l"
+#line 118 "lwin_wkt_lex.l"
ECHO;
YY_BREAK
-#line 1089 "lwin_wkt_lex.c"
+#line 1340 "lwin_wkt_lex.c"
case YY_STATE_EOF(INITIAL):
yyterminate();
@@ -1102,15 +1354,15 @@ case YY_STATE_EOF(INITIAL):
/* We're scanning a new file or input source. It's
* possible that this happened because the user
- * just pointed wkt_yyin at a new source and called
- * wkt_yylex(). If so, then we have to assure
+ * just pointed yyin at a new source and called
+ * yylex(). If so, then we have to assure
* consistency between YY_CURRENT_BUFFER and our
* globals. Here is the right place to do so, because
* this is the first action (other than possibly a
* back-up) that will match for the new input source.
(yy_n_chars) = YY_CURRENT_BUFFER_LVALUE->yy_n_chars;
- YY_CURRENT_BUFFER_LVALUE->yy_input_file = wkt_yyin;
+ YY_CURRENT_BUFFER_LVALUE->yy_input_file = yyin;
YY_CURRENT_BUFFER_LVALUE->yy_buffer_status = YY_BUFFER_NORMAL;
@@ -1164,11 +1416,11 @@ case YY_STATE_EOF(INITIAL):
(yy_did_buffer_switch_on_eof) = 0;
- if ( wkt_yywrap( ) )
+ if ( yywrap( ) )
/* Note: because we've taken care in
* yy_get_next_buffer() to have set up
- * wkt_yytext, we can now set up
+ * yytext, we can now set up
* yy_c_buf_p so that if some total
* hoser (like flex itself) wants to
* call the scanner after we return the
@@ -1217,7 +1469,8 @@ case YY_STATE_EOF(INITIAL):
"fatal flex scanner internal error--no action found" );
} /* end of action switch */
} /* end of scanning one token */
-} /* end of wkt_yylex */
+ } /* end of user's declarations */
+} /* end of yylex */
/* yy_get_next_buffer - try to read in a new buffer
@@ -1228,9 +1481,9 @@ case YY_STATE_EOF(INITIAL):
static int yy_get_next_buffer (void)
- register char *dest = YY_CURRENT_BUFFER_LVALUE->yy_ch_buf;
- register char *source = (yytext_ptr);
- register int number_to_move, i;
+ char *dest = YY_CURRENT_BUFFER_LVALUE->yy_ch_buf;
+ char *source = (yytext_ptr);
+ int number_to_move, i;
int ret_val;
if ( (yy_c_buf_p) > &YY_CURRENT_BUFFER_LVALUE->yy_ch_buf[(yy_n_chars) + 1] )
@@ -1259,7 +1512,7 @@ static int yy_get_next_buffer (void)
/* Try to read more data. */
/* First move last chars to start of buffer. */
- number_to_move = (int) ((yy_c_buf_p) - (yytext_ptr)) - 1;
+ number_to_move = (int) ((yy_c_buf_p) - (yytext_ptr) - 1);
for ( i = 0; i < number_to_move; ++i )
*(dest++) = *(source++);
@@ -1272,21 +1525,21 @@ static int yy_get_next_buffer (void)
else
- yy_size_t num_to_read =
+ int num_to_read =
YY_CURRENT_BUFFER_LVALUE->yy_buf_size - number_to_move - 1;
while ( num_to_read <= 0 )
{ /* Not enough room in the buffer - grow it. */
/* just a shorter name for the current buffer */
- YY_BUFFER_STATE b = YY_CURRENT_BUFFER;
+ YY_BUFFER_STATE b = YY_CURRENT_BUFFER_LVALUE;
int yy_c_buf_p_offset =
(int) ((yy_c_buf_p) - b->yy_ch_buf);
if ( b->yy_is_our_buffer )
- yy_size_t new_size = b->yy_buf_size * 2;
+ int new_size = b->yy_buf_size * 2;
if ( new_size <= 0 )
b->yy_buf_size += b->yy_buf_size / 8;
@@ -1295,11 +1548,12 @@ static int yy_get_next_buffer (void)
b->yy_ch_buf = (char *)
/* Include room in for 2 EOB chars. */
- wkt_yyrealloc((void *) b->yy_ch_buf,b->yy_buf_size + 2 );
+ yyrealloc( (void *) b->yy_ch_buf,
+ (yy_size_t) (b->yy_buf_size + 2) );
else
/* Can't grow it, we don't own it. */
- b->yy_ch_buf = 0;
+ b->yy_ch_buf = NULL;
if ( ! b->yy_ch_buf )
YY_FATAL_ERROR(
@@ -1327,7 +1581,7 @@ static int yy_get_next_buffer (void)
if ( number_to_move == YY_MORE_ADJ )
ret_val = EOB_ACT_END_OF_FILE;
- wkt_yyrestart(wkt_yyin );
+ yyrestart( yyin );
else
@@ -1341,12 +1595,15 @@ static int yy_get_next_buffer (void)
else
ret_val = EOB_ACT_CONTINUE_SCAN;
- if ((yy_size_t) ((yy_n_chars) + number_to_move) > YY_CURRENT_BUFFER_LVALUE->yy_buf_size) {
+ if (((yy_n_chars) + number_to_move) > YY_CURRENT_BUFFER_LVALUE->yy_buf_size) {
/* Extend the array by 50%, plus the number we really need. */
- yy_size_t new_size = (yy_n_chars) + number_to_move + ((yy_n_chars) >> 1);
- YY_CURRENT_BUFFER_LVALUE->yy_ch_buf = (char *) wkt_yyrealloc((void *) YY_CURRENT_BUFFER_LVALUE->yy_ch_buf,new_size );
+ int new_size = (yy_n_chars) + number_to_move + ((yy_n_chars) >> 1);
+ YY_CURRENT_BUFFER_LVALUE->yy_ch_buf = (char *) yyrealloc(
+ (void *) YY_CURRENT_BUFFER_LVALUE->yy_ch_buf, (yy_size_t) new_size );
if ( ! YY_CURRENT_BUFFER_LVALUE->yy_ch_buf )
YY_FATAL_ERROR( "out of dynamic memory in yy_get_next_buffer()" );
+ /* "- 2" to take care of EOB's */
+ YY_CURRENT_BUFFER_LVALUE->yy_buf_size = (int) (new_size - 2);
(yy_n_chars) += number_to_move;
@@ -1362,14 +1619,14 @@ static int yy_get_next_buffer (void)
static yy_state_type yy_get_previous_state (void)
- register char *yy_cp;
+ char *yy_cp;
yy_current_state = (yy_start);
for ( yy_cp = (yytext_ptr) + YY_MORE_ADJ; yy_cp < (yy_c_buf_p); ++yy_cp )
- register YY_CHAR yy_c = (*yy_cp ? yy_ec[YY_SC_TO_UI(*yy_cp)] : 1);
+ YY_CHAR yy_c = (*yy_cp ? yy_ec[YY_SC_TO_UI(*yy_cp)] : 1);
@@ -1379,9 +1636,9 @@ static int yy_get_next_buffer (void)
return yy_current_state;
@@ -1394,10 +1651,10 @@ static int yy_get_next_buffer (void)
static yy_state_type yy_try_NUL_trans (yy_state_type yy_current_state )
- register int yy_is_jam;
- register char *yy_cp = (yy_c_buf_p);
+ int yy_is_jam;
+ char *yy_cp = (yy_c_buf_p);
- register YY_CHAR yy_c = 1;
+ YY_CHAR yy_c = 1;
@@ -1407,14 +1664,18 @@ static int yy_get_next_buffer (void)
yy_is_jam = (yy_current_state == 176);
- return yy_is_jam ? 0 : yy_current_state;
+ return yy_is_jam ? 0 : yy_current_state;
+#endif
#ifndef YY_NO_INPUT
#ifdef __cplusplus
static int yyinput (void)
@@ -1439,7 +1700,7 @@ static int yy_get_next_buffer (void)
else
{ /* need more input */
- yy_size_t offset = (yy_c_buf_p) - (yytext_ptr);
+ int offset = (int) ((yy_c_buf_p) - (yytext_ptr));
++(yy_c_buf_p);
switch ( yy_get_next_buffer( ) )
@@ -1456,13 +1717,13 @@ static int yy_get_next_buffer (void)
/* Reset buffer status. */
/*FALLTHROUGH*/
case EOB_ACT_END_OF_FILE:
+ if ( yywrap( ) )
return 0;
if ( ! (yy_did_buffer_switch_on_eof) )
@@ -1482,7 +1743,7 @@ static int yy_get_next_buffer (void)
c = *(unsigned char *) (yy_c_buf_p); /* cast for 8-bit char's */
- *(yy_c_buf_p) = '\0'; /* preserve wkt_yytext */
+ *(yy_c_buf_p) = '\0'; /* preserve yytext */
(yy_hold_char) = *++(yy_c_buf_p);
return c;
@@ -1494,32 +1755,32 @@ static int yy_get_next_buffer (void)
* @note This function does not reset the start condition to @c INITIAL .
- void wkt_yyrestart (FILE * input_file )
+ void yyrestart (FILE * input_file )
- wkt_yy_init_buffer(YY_CURRENT_BUFFER,input_file );
+ yy_init_buffer( YY_CURRENT_BUFFER, input_file );
/** Switch to a different input buffer.
* @param new_buffer The new input buffer.
- void wkt_yy_switch_to_buffer (YY_BUFFER_STATE new_buffer )
+ void yy_switch_to_buffer (YY_BUFFER_STATE new_buffer )
/* TODO. We should be able to replace this entire function body
* with
- * wkt_yypop_buffer_state();
- * wkt_yypush_buffer_state(new_buffer);
+ * yypop_buffer_state();
+ * yypush_buffer_state(new_buffer);
if ( YY_CURRENT_BUFFER == new_buffer )
return;
@@ -1532,21 +1793,21 @@ static int yy_get_next_buffer (void)
YY_CURRENT_BUFFER_LVALUE = new_buffer;
/* We don't actually know whether we did this switch during
- * EOF (wkt_yywrap()) processing, but the only time this flag
- * is looked at is after wkt_yywrap() is called, so it's safe
+ * EOF (yywrap()) processing, but the only time this flag
+ * is looked at is after yywrap() is called, so it's safe
* to go ahead and always set it.
(yy_did_buffer_switch_on_eof) = 1;
-static void wkt_yy_load_buffer_state (void)
+static void yy_load_buffer_state (void)
(yytext_ptr) = (yy_c_buf_p) = YY_CURRENT_BUFFER_LVALUE->yy_buf_pos;
- wkt_yyin = YY_CURRENT_BUFFER_LVALUE->yy_input_file;
+ yyin = YY_CURRENT_BUFFER_LVALUE->yy_input_file;
(yy_hold_char) = *(yy_c_buf_p);
@@ -1556,35 +1817,35 @@ static void wkt_yy_load_buffer_state (void)
* @return the allocated buffer state.
- YY_BUFFER_STATE wkt_yy_create_buffer (FILE * file, int size )
+ YY_BUFFER_STATE yy_create_buffer (FILE * file, int size )
YY_BUFFER_STATE b;
- b = (YY_BUFFER_STATE) wkt_yyalloc(sizeof( struct yy_buffer_state ) );
+ b = (YY_BUFFER_STATE) yyalloc( sizeof( struct yy_buffer_state ) );
if ( ! b )
- YY_FATAL_ERROR( "out of dynamic memory in wkt_yy_create_buffer()" );
+ YY_FATAL_ERROR( "out of dynamic memory in yy_create_buffer()" );
b->yy_buf_size = size;
/* yy_ch_buf has to be 2 characters longer than the size given because
* we need to put in 2 end-of-buffer characters.
- b->yy_ch_buf = (char *) wkt_yyalloc(b->yy_buf_size + 2 );
+ b->yy_ch_buf = (char *) yyalloc( (yy_size_t) (b->yy_buf_size + 2) );
b->yy_is_our_buffer = 1;
- wkt_yy_init_buffer(b,file );
+ yy_init_buffer( b, file );
return b;
/** Destroy the buffer.
- * @param b a buffer created with wkt_yy_create_buffer()
+ * @param b a buffer created with yy_create_buffer()
- void wkt_yy_delete_buffer (YY_BUFFER_STATE b )
+ void yy_delete_buffer (YY_BUFFER_STATE b )
if ( ! b )
@@ -1594,27 +1855,27 @@ static void wkt_yy_load_buffer_state (void)
YY_CURRENT_BUFFER_LVALUE = (YY_BUFFER_STATE) 0;
- wkt_yyfree((void *) b->yy_ch_buf );
+ yyfree( (void *) b->yy_ch_buf );
- wkt_yyfree((void *) b );
+ yyfree( (void *) b );
/* Initializes or reinitializes a buffer.
* This function is sometimes called more than once on the same buffer,
- * such as during a wkt_yyrestart() or at EOF.
+ * such as during a yyrestart() or at EOF.
- static void wkt_yy_init_buffer (YY_BUFFER_STATE b, FILE * file )
+ static void yy_init_buffer (YY_BUFFER_STATE b, FILE * file )
int oerrno = errno;
- wkt_yy_flush_buffer(b );
+ yy_flush_buffer( b );
b->yy_input_file = file;
b->yy_fill_buffer = 1;
- /* If b is the current buffer, then wkt_yy_init_buffer was _probably_
- * called from wkt_yyrestart() or through yy_get_next_buffer.
+ /* If b is the current buffer, then yy_init_buffer was _probably_
+ * called from yyrestart() or through yy_get_next_buffer.
* In that case, we don't want to reset the lineno or column.
if (b != YY_CURRENT_BUFFER){
@@ -1631,7 +1892,7 @@ static void wkt_yy_load_buffer_state (void)
* @param b the buffer state to be flushed, usually @c YY_CURRENT_BUFFER.
- void wkt_yy_flush_buffer (YY_BUFFER_STATE b )
+ void yy_flush_buffer (YY_BUFFER_STATE b )
if ( ! b )
return;
@@ -1651,7 +1912,7 @@ static void wkt_yy_load_buffer_state (void)
b->yy_buffer_status = YY_BUFFER_NEW;
if ( b == YY_CURRENT_BUFFER )
/** Pushes the new state onto the stack. The new state becomes
@@ -1660,14 +1921,14 @@ static void wkt_yy_load_buffer_state (void)
* @param new_buffer The new state.
+void yypush_buffer_state (YY_BUFFER_STATE new_buffer )
if (new_buffer == NULL)
return;
- wkt_yyensure_buffer_stack();
+ yyensure_buffer_stack();
- /* This block is copied from wkt_yy_switch_to_buffer. */
+ /* This block is copied from yy_switch_to_buffer. */
if ( YY_CURRENT_BUFFER )
/* Flush out information for old buffer. */
@@ -1681,8 +1942,8 @@ void wkt_yypush_buffer_state (YY_BUFFER_STATE new_buffer )
(yy_buffer_stack_top)++;
- /* copied from wkt_yy_switch_to_buffer. */
+ /* copied from yy_switch_to_buffer. */
@@ -1690,18 +1951,18 @@ void wkt_yypush_buffer_state (YY_BUFFER_STATE new_buffer )
* The next element becomes the new top.
-void wkt_yypop_buffer_state (void)
+void yypop_buffer_state (void)
if (!YY_CURRENT_BUFFER)
return;
- wkt_yy_delete_buffer(YY_CURRENT_BUFFER );
+ yy_delete_buffer(YY_CURRENT_BUFFER );
YY_CURRENT_BUFFER_LVALUE = NULL;
if ((yy_buffer_stack_top) > 0)
--(yy_buffer_stack_top);
if (YY_CURRENT_BUFFER) {
@@ -1709,7 +1970,7 @@ void wkt_yypop_buffer_state (void)
/* Allocates the stack if it does not exist.
* Guarantees space for at least one push.
-static void wkt_yyensure_buffer_stack (void)
+static void yyensure_buffer_stack (void)
yy_size_t num_to_alloc;
@@ -1719,15 +1980,15 @@ static void wkt_yyensure_buffer_stack (void)
* scanner will even need a stack. We use 2 instead of 1 to avoid an
* immediate realloc on the next call.
- num_to_alloc = 1;
- (yy_buffer_stack) = (struct yy_buffer_state**)wkt_yyalloc
+ num_to_alloc = 1; /* After all that talk, this was set to 1 anyways... */
+ (yy_buffer_stack) = (struct yy_buffer_state**)yyalloc
(num_to_alloc * sizeof(struct yy_buffer_state*)
if ( ! (yy_buffer_stack) )
- YY_FATAL_ERROR( "out of dynamic memory in wkt_yyensure_buffer_stack()" );
+ YY_FATAL_ERROR( "out of dynamic memory in yyensure_buffer_stack()" );
memset((yy_buffer_stack), 0, num_to_alloc * sizeof(struct yy_buffer_state*));
(yy_buffer_stack_max) = num_to_alloc;
(yy_buffer_stack_top) = 0;
return;
@@ -1736,15 +1997,15 @@ static void wkt_yyensure_buffer_stack (void)
if ((yy_buffer_stack_top) >= ((yy_buffer_stack_max)) - 1){
/* Increase the buffer to prepare for a possible push. */
- int grow_size = 8 /* arbitrary grow size */;
+ yy_size_t grow_size = 8 /* arbitrary grow size */;
num_to_alloc = (yy_buffer_stack_max) + grow_size;
- (yy_buffer_stack) = (struct yy_buffer_state**)wkt_yyrealloc
+ (yy_buffer_stack) = (struct yy_buffer_state**)yyrealloc
((yy_buffer_stack),
/* zero only the new slots.*/
memset((yy_buffer_stack) + (yy_buffer_stack_max), 0, grow_size * sizeof(struct yy_buffer_state*));
@@ -1756,9 +2017,9 @@ static void wkt_yyensure_buffer_stack (void)
* @param base the character buffer
* @param size the size in bytes of the character buffer
- * @return the newly allocated buffer state object.
+ * @return the newly allocated buffer state object.
-YY_BUFFER_STATE wkt_yy_scan_buffer (char * base, yy_size_t size )
+YY_BUFFER_STATE yy_scan_buffer (char * base, yy_size_t size )
YY_BUFFER_STATE b;
@@ -1766,68 +2027,69 @@ YY_BUFFER_STATE wkt_yy_scan_buffer (char * base, yy_size_t size )
base[size-2] != YY_END_OF_BUFFER_CHAR ||
base[size-1] != YY_END_OF_BUFFER_CHAR )
/* They forgot to leave room for the EOB's. */
- return 0;
+ return NULL;
if ( ! b )
- YY_FATAL_ERROR( "out of dynamic memory in wkt_yy_scan_buffer()" );
+ YY_FATAL_ERROR( "out of dynamic memory in yy_scan_buffer()" );
- b->yy_buf_size = size - 2; /* "- 2" to take care of EOB's */
+ b->yy_buf_size = (int) (size - 2); /* "- 2" to take care of EOB's */
b->yy_buf_pos = b->yy_ch_buf = base;
b->yy_is_our_buffer = 0;
- b->yy_input_file = 0;
+ b->yy_input_file = NULL;
b->yy_n_chars = b->yy_buf_size;
b->yy_is_interactive = 0;
b->yy_at_bol = 1;
b->yy_fill_buffer = 0;
- wkt_yy_switch_to_buffer(b );
+ yy_switch_to_buffer( b );
return b;
-/** Setup the input buffer state to scan a string. The next call to wkt_yylex() will
+/** Setup the input buffer state to scan a string. The next call to yylex() will
* scan from a @e copy of @a str.
* @param yystr a NUL-terminated string to scan
* @note If you want to scan bytes that may contain NUL values, then use
- * wkt_yy_scan_bytes() instead.
+ * yy_scan_bytes() instead.
-YY_BUFFER_STATE wkt_yy_scan_string (yyconst char * yystr )
+YY_BUFFER_STATE yy_scan_string (const char * yystr )
- return wkt_yy_scan_bytes(yystr,strlen(yystr) );
+ return yy_scan_bytes( yystr, (int) strlen(yystr) );
-/** Setup the input buffer state to scan the given bytes. The next call to wkt_yylex() will
+/** Setup the input buffer state to scan the given bytes. The next call to yylex() will
* scan from a @e copy of @a bytes.
- * @param bytes the byte buffer to scan
- * @param len the number of bytes in the buffer pointed to by @a bytes.
+ * @param yybytes the byte buffer to scan
+ * @param _yybytes_len the number of bytes in the buffer pointed to by @a bytes.
-YY_BUFFER_STATE wkt_yy_scan_bytes (yyconst char * yybytes, yy_size_t _yybytes_len )
+YY_BUFFER_STATE yy_scan_bytes (const char * yybytes, int _yybytes_len )
YY_BUFFER_STATE b;
char *buf;
- yy_size_t n, i;
+ yy_size_t n;
+ int i;
/* Get memory for full buffer, including space for trailing EOB's. */
- n = _yybytes_len + 2;
- buf = (char *) wkt_yyalloc(n );
+ n = (yy_size_t) (_yybytes_len + 2);
+ buf = (char *) yyalloc( n );
if ( ! buf )
- YY_FATAL_ERROR( "out of dynamic memory in wkt_yy_scan_bytes()" );
+ YY_FATAL_ERROR( "out of dynamic memory in yy_scan_bytes()" );
for ( i = 0; i < _yybytes_len; ++i )
buf[i] = yybytes[i];
buf[_yybytes_len] = buf[_yybytes_len+1] = YY_END_OF_BUFFER_CHAR;
- b = wkt_yy_scan_buffer(buf,n );
+ b = yy_scan_buffer( buf, n );
if ( ! b )
- YY_FATAL_ERROR( "bad buffer in wkt_yy_scan_bytes()" );
+ YY_FATAL_ERROR( "bad buffer in yy_scan_bytes()" );
/* It's okay to grow etc. this buffer, and we should throw it
* away when we're done.
@@ -1841,9 +2103,9 @@ YY_BUFFER_STATE wkt_yy_scan_bytes (yyconst char * yybytes, yy_size_t _yybytes_
#define YY_EXIT_FAILURE 2
#endif
-static void yy_fatal_error (yyconst char* msg )
+static void yynoreturn yy_fatal_error (const char* msg )
- (void) fprintf( stderr, "%s\n", msg );
+ fprintf( stderr, "%s\n", msg );
exit( YY_EXIT_FAILURE );
@@ -1853,14 +2115,14 @@ static void yy_fatal_error (yyconst char* msg )
#define yyless(n) \
do \
- wkt_yytext[wkt_yyleng] = (yy_hold_char); \
- (yy_c_buf_p) = wkt_yytext + yyless_macro_arg; \
+ yytext[yyleng] = (yy_hold_char); \
+ (yy_c_buf_p) = yytext + yyless_macro_arg; \
(yy_hold_char) = *(yy_c_buf_p); \
*(yy_c_buf_p) = '\0'; \
- wkt_yyleng = yyless_macro_arg; \
+ yyleng = yyless_macro_arg; \
while ( 0 )
@@ -1869,126 +2131,126 @@ static void yy_fatal_error (yyconst char* msg )
/** Get the current line number.
-int wkt_yyget_lineno (void)
+int yyget_lineno (void)
- return wkt_yylineno;
+ return yylineno;
/** Get the input stream.
-FILE *wkt_yyget_in (void)
+FILE *yyget_in (void)
- return wkt_yyin;
+ return yyin;
/** Get the output stream.
-FILE *wkt_yyget_out (void)
+FILE *yyget_out (void)
- return wkt_yyout;
+ return yyout;
/** Get the length of the current token.
-yy_size_t wkt_yyget_leng (void)
+int yyget_leng (void)
- return wkt_yyleng;
+ return yyleng;
/** Get the current token.
-char *wkt_yyget_text (void)
+char *yyget_text (void)
- return wkt_yytext;
+ return yytext;
/** Set the current line number.
- * @param line_number
+ * @param _line_number line number
+void yyset_lineno (int _line_number )
- wkt_yylineno = line_number;
+ yylineno = _line_number;
/** Set the input stream. This does not discard the current
* input buffer.
- * @param in_str A readable stream.
+ * @param _in_str A readable stream.
- * @see wkt_yy_switch_to_buffer
+ * @see yy_switch_to_buffer
+void yyset_in (FILE * _in_str )
- wkt_yyin = in_str ;
+ yyin = _in_str ;
+void yyset_out (FILE * _out_str )
- wkt_yyout = out_str ;
+ yyout = _out_str ;
-int wkt_yyget_debug (void)
+int yyget_debug (void)
- return wkt_yy_flex_debug;
+ return yy_flex_debug;
-void wkt_yyset_debug (int bdebug )
+void yyset_debug (int _bdebug )
- wkt_yy_flex_debug = bdebug ;
+ yy_flex_debug = _bdebug ;
static int yy_init_globals (void)
/* Initialization is the same as for the non-reentrant scanner.
- * This function is called from wkt_yylex_destroy(), so don't allocate here.
+ * This function is called from yylex_destroy(), so don't allocate here.
- (yy_buffer_stack) = 0;
+ (yy_buffer_stack) = NULL;
(yy_buffer_stack_max) = 0;
- (yy_c_buf_p) = (char *) 0;
+ (yy_c_buf_p) = NULL;
(yy_init) = 0;
(yy_start) = 0;
/* Defined in main.c */
#ifdef YY_STDINIT
- wkt_yyin = stdin;
+ yyin = stdin;
+ yyout = stdout;
#else
- wkt_yyin = (FILE *) 0;
- wkt_yyout = (FILE *) 0;
+ yyin = NULL;
+ yyout = NULL;
#endif
/* For future reference: Set errno on error, since we are called by
- * wkt_yylex_init()
+ * yylex_init()
return 0;
-/* wkt_yylex_destroy is for both reentrant and non-reentrant scanners. */
-int wkt_yylex_destroy (void)
+/* yylex_destroy is for both reentrant and non-reentrant scanners. */
+int yylex_destroy (void)
/* Pop the buffer stack, destroying each element. */
while(YY_CURRENT_BUFFER){
+ yy_delete_buffer( YY_CURRENT_BUFFER );
- wkt_yypop_buffer_state();
+ yypop_buffer_state();
/* Destroy the stack itself. */
- wkt_yyfree((yy_buffer_stack) );
+ yyfree((yy_buffer_stack) );
/* Reset the globals. This is important in a non-reentrant scanner so the next time
- * wkt_yylex() is called, initialization will occur. */
+ * yylex() is called, initialization will occur. */
yy_init_globals( );
return 0;
@@ -1999,18 +2261,19 @@ int wkt_yylex_destroy (void)
#ifndef yytext_ptr
-static void yy_flex_strncpy (char* s1, yyconst char * s2, int n )
+static void yy_flex_strncpy (char* s1, const char * s2, int n )
- register int i;
+ int i;
for ( i = 0; i < n; ++i )
s1[i] = s2[i];
#endif
-static int yy_flex_strlen (yyconst char * s )
+static int yy_flex_strlen (const char * s )
- register int n;
+ int n;
for ( n = 0; s[n]; ++n )
@@ -2020,8 +2283,7 @@ static int yy_flex_strlen (yyconst char * s )
#define YYTABLES_NAME "yytables"
void *wkt_yyalloc (yy_size_t size )
diff --git a/liblwgeom/lwin_wkt_lex.l b/liblwgeom/lwin_wkt_lex.l
index 273a979..d301a22 100644
--- a/liblwgeom/lwin_wkt_lex.l
+++ b/liblwgeom/lwin_wkt_lex.l
@@ -34,6 +34,17 @@ static void wkt_lexer_unknown()
} while (0);
+* NAN tokens.
+#endif
+#include <math.h>
+#ifndef NAN
+#endif
@@ -57,7 +68,7 @@ static void wkt_lexer_unknown()
([Nn][Aa][Nn])[ \,\)\t\n\r] {
return DOUBLE_TOK;
Summary of changes:
liblwgeom/lwin_wkt_lex.c | 942 ++++++++++++++++++++++++++++++-----------------
liblwgeom/lwin_wkt_lex.l | 13 +-
2 files changed, 614 insertions(+), 341 deletions(-)
hooks/post-receive
