[postgis-tickets] [PostGIS] #4874: PostGIS 3.2 / GEOS 3.10dev windows - subdivide regress
trac at osgeo.org
Tue Mar 9 19:17:37 PST 2021
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.2.0
Component: buildbots | Version: master
Keywords: |
./regress/core/subdivide .. failed (diff expected obtained:
/projects/postgis/tmp/3.2.0dev_pg13_geos3.10_gdal3.2.0w64/test_90_diff)
--- ./regress/core/subdivide_expected 2021-03-02 15:19:47.256187600
-0500
+++ /projects/postgis/tmp/3.2.0dev_pg13_geos3.10_gdal3.2.0w64/test_90_out
2021-03-09 22:08:13.942357400 -0500
@@ -4,6 +4,7 @@
ERROR: lwgeom_subdivide_prec: cannot subdivide to fewer than 5 vertices
per output
#3522|POINT(1 1)
#3744|1600000000000000
+SELECT 1857
4|29321996468.6|29321996468.6|256
#4211|0.00008316000
#4217|0.00002463668
I'm getting this locally using winnie's geos 3.10 build from today. Also
seeing same issue on winnie. Debbie seems okay so might be windows
specific.
The regress looks extremely odd though - like how did a selcted get in
there.
I think it might be coming from this line:
\i :regdir/core/regress_big_polygon.sql
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4874>
