[postgis-tickets] [PostGIS] #4877: PostgreSQL 14 / windows can't compile PostGIS
trac at osgeo.org
Wed Mar 10 08:16:23 PST 2021
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Keywords: windows, mingw64 |
In trying to troubleshoot #4876 I seem to have run into another issue
which seems windows/mingw specific which prevents me from being able to
even compile, though my PostgreSQL 14 installed fine.
NG64~1/projects/POSTGR~1/rel/PG14W6~1/include/server/port/win32
-DWIN32_STACK_RLIMIT=4194304
-c -o lwgeom_in_gml.o lwgeom_in_gml.c
In file included from
C:/MING64~1/projects/POSTGR~1/rel/PG14W6~1/include/server/port.h:26,
from
C:/MING64~1/projects/POSTGR~1/rel/PG14W6~1/include/server/c.h:1355,
from
C:/MING64~1/projects/POSTGR~1/rel/PG14W6~1/include/server/postgres.h:4
6,
from lwgeom_in_gml.c:55:
C:/MING64~1/projects/POSTGR~1/rel/PG14W6~1/include/server/port/win32_port.h:57:14:
warning:
'struct microsoft_native_stat' declared inside parameter list will not be
visible outside of
this definition or declaration
#define stat microsoft_native_stat
warning:
visible outside of
warning:
visible outside of
warning:
visible outside of
C:/MING64~1/projects/POSTGR~1/rel/PG14W6~1/include/server/port/win32_port.h:56:15:
error: co
nflicting types for 'microsoft_native_fstat'
#define fstat microsoft_native_fstat
note: pre
vious declaration of 'microsoft_native_fstat' was here
ort.h:58,
from
from
from
6,
C:/ming64gcc81/mingw64/x86_64-w64-mingw32/include/sys/stat.h: In function
'microsoft_native_
fstat':
C:/ming64gcc81/mingw64/x86_64-w64-mingw32/include/sys/stat.h:226:27:
error: invalid applicat
ion of 'sizeof' to incomplete type 'struct microsoft_native_stat'
memset(_Stat,0,sizeof(struct stat));
C:/ming64gcc81/mingw64/x86_64-w64-mingw32/include/sys/stat.h:231:8: error:
dereferencing poi
nter to incomplete type 'struct microsoft_native_stat'
_Stat->st_dev=st.st_dev;
from
from
6,
At top level:
C:/MING64~1/projects/POSTGR~1/rel/PG14W6~1/include/server/port/win32_port.h:256:8:
error: re
definition of 'struct stat'
struct stat /* This should match struct __stat64 */
C:/ming64gcc81/mingw64/x86_64-w64-mingw32/include/wchar.h:424,
from C:/ming64gcc81/projects/rel-
libiconv-1.15w64gcc81/include/iconv.h:110,
from C:/ming64gcc81/projects/libxml/rel-
libxml2-2.9.9w64gcc81/include/libxm
l2/libxml/encoding.h:28,
l2/libxml/parser.h:810,
l2/libxml/globals.h:18,
l2/libxml/threads.h:35,
l2/libxml/xmlmemory.h:218,
l2/libxml/tree.h:1307,
from lwgeom_in_gml.c:50:
C:/ming64gcc81/mingw64/x86_64-w64-mingw32/include/_mingw_stat64.h:43:10:
note: originally de
fined here
struct stat {
make[1]: *** [<builtin>: lwgeom_in_gml.o] Error 1
make[1]: Leaving directory '/projects/postgis/postgis-git/postgis'
make: *** [GNUmakefile:22: all] Error 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4877>
