[postgis-tickets] [PostGIS] #4877: PostgreSQL 14 / windows can't compile PostGIS
trac at osgeo.org
Wed Mar 10 20:16:43 PST 2021
Reporter: robe | Owner: robe
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Resolution: | Keywords: windows, mingw64
Comment (by robe):
Seems they introduced this line in include/server/port/win32_port.h
which is conflicting with mingw64 definition. Might be my mingw is old
and shouldn't have it defined or they should have a mingw64 guard around
this like they have other sections of the win32_port.h
#define stat microsoft_native_stat
also
C:/MING64~1/projects/POSTGR~1/rel/PG14W6~1/include/server/port/win32_port.h:258:8:
error: redefinition of 'struct stat'
struct stat /* This should match struct __stat64 */
* Supplement to <sys/stat.h>.
* We must pull in sys/stat.h before this part, else our overrides lose.
* stat() is not guaranteed to set the st_size field on win32, so we
* redefine it to our own implementation. See src/port/win32stat.c.
* The struct stat is 32 bit in MSVC, so we redefine it as a copy of
* struct __stat64. This also fixes the struct size for MINGW builds.
_dev_t st_dev;
_ino_t st_ino;
unsigned short st_mode;
short st_nlink;
short st_uid;
short st_gid;
_dev_t st_rdev;
__int64 st_size;
__time64_t st_atime;
__time64_t st_mtime;
__time64_t st_ctime;
I put a
#if !defined(__MINGW64_VERSION_MAJOR) || defined(_MSC_VER)
#endif
guard around these sections that allowed me to compile. I'll report as
possible bug upstream.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4877#comment:1>
