[postgis-tickets] [PostGIS] #4882: GetTopoGeomElement{s, Array) return unsigned elements
trac at osgeo.org
Fri Mar 12 00:37:27 PST 2021
#4882: GetTopoGeomElement{s,Array) return unsigned elements
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.2.0
Component: topology | Version:
Keywords: |
While working on a testcase for #4881 I realized that GetTopoGeomElements,
and its friend GetTopoGeomElementArray both drop the sign of element
identifiers in the relation table. The documentation does NOT mention
element_id sign so this is not necessarely a BUG but for sure it is a
limitation that we probably want to overcome somehow. Maybe by adding an
optinoal parameter to the function to retain the elements sign..
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4882>
