[postgis-tickets] [PostGIS] #4883: Topology crash on PostgreSQL 14 mingw windows - sqlmm
    trac at osgeo.org
    Fri Mar 12 08:55:23 PST 2021
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.2.0
Component:  postgis  |    Version:  master
 Keywords:           |
 I sent this upstream as they are having trouble replicating mingw issues
 and there are ton of tests failing on some mingw64 bots (not all).
 https://www.postgresql.org/message-
 id/002001d7175f%248942b020%249bc81060%24%40pcorp.us
 Crash happens here:
 SELECT topology.ST_AddIsoEdge('sqlmm_topology', 1, 2, 'LINESTRING(0 0, 10
 0, 5 5, 5 -5)');
 stack trace below:
 Thread 1 received signal SIGSEGV, Segmentation fault.
 [Switching to Thread 22272.0x49ec]
 0x00007ffe75f5f23f in ntdll!RtlLeaveCriticalSection ()
    from C:\WINDOWS\SYSTEM32\ntdll.dll
 (gdb) bt
 #0  0x00007ffe75f5f23f in ntdll!RtlLeaveCriticalSection ()
 #1  0x00007ffe75fd4c0e in ntdll!memset () from
 #2  0x00007ffe75fbc872 in ntdll!__C_specific_handler ()
 #3  0x00007ffe75fd1fef in ntdll!.chkstk () from
 #4  0x00007ffe75f60939 in ntdll!RtlUnwindEx ()
 #5  0x00007ffe74002eed in msvcrt!_setjmpex ()
    from C:\WINDOWS\System32\msvcrt.dll
 #6  0x00000000008d929a in pg_re_throw () at elog.c:1776
 #7  0x00000000008d911d in errfinish (filename=<optimized out>,
     lineno=<optimized out>, funcname=0x6b025560 <__func__.114531>
 "pg_error")
     at elog.c:589
 #8  0x000000006afc91d3 in pg_error (fmt=<optimized out>, ap=<optimized
 out>)
     at lwgeom_pg.c:250
 #9  0x000000006afdfb03 in lwerror (fmt=0x0) at lwutil.c:197
 #10 0x000000006b000c16 in lwt_AddIsoEdge (topo=topo(at)entry=0x83629b0,
     startNode=startNode(at)entry=1, endNode=endNode(at)entry=2,
     geom=geom(at)entry=0x7a303b8) at lwgeom_topo.c:794
 #11 0x000000006afc70d2 in ST_AddIsoEdge (fcinfo=0x7a2caa8)
     at postgis_topology.c:3567
 #12 0x00000000005f7604 in ExecInterpExpr (state=0x7a2c9c0,
     econtext=0x7a2c6c0, isnull=<optimized out>) at execExprInterp.c:1209
 #13 0x000000000062f23f in ExecEvalExprSwitchContext (isNull=0x509ef9f,
     econtext=0x7a2c6c0, state=0x7a2c9c0)
     at ../../../src/include/executor/executor.h:315
 #14 ExecProject (projInfo=0x7a2c9b8)
     at ../../../src/include/executor/executor.h:349
 #15 ExecResult (pstate=<optimized out>) at nodeResult.c:136
 #16 0x00000000005fc0ca in ExecProcNode (node=0x7a2c5a8)
     at ../../../src/include/executor/executor.h:247
 #17 ExecutePlan (execute_once=<optimized out>, dest=0x7a2b2e8,
     direction=<optimized out>, numberTuples=0, sendTuples=<optimized out>,
     operation=CMD_SELECT, use_parallel_mode=<optimized out>,
     planstate=0x7a2c5a8, estate=0x7a2c370) at execMain.c:1531
 #18 standard_ExecutorRun (queryDesc=0x8338990, direction=<optimized out>,
     count=0, execute_once=<optimized out>) at execMain.c:350
 #19 0x00000000007a08cb in PortalRunSelect (portal=0x79bcc70,
     portal(at)entry=0x7fffffff, forward=forward(at)entry=true,
 count=count(at)entry=0,
     dest=dest(at)entry=0x7a2b2e8) at pquery.c:912
 #20 0x00000000007a20cc in PortalRun (portal=0x7fffffff,
     portal(at)entry=0x79bcc70, count=0, count(at)entry=2147483647,
     isTopLevel=isTopLevel(at)entry=true, run_once=run_once(at)entry=true,
     dest=dest(at)entry=0x7a2b2e8, altdest=altdest(at)entry=0x7a2b2e8,
     qc=qc(at)entry=0x509f2d0) at pquery.c:756
 #21 0x000000000079d6ab in exec_simple_query (
     query_string=0x79fd1e0 "SELECT
 1, 2, 'LINESTRING(0 0, 10 0, 5 5, 5 -5)');") at postgres.c:1173
 #22 0x000000000079ee40 in PostgresMain (argc=argc(at)entry=1,
     argv=argv(at)entry=0x509f980, dbname=<optimized out>,
     username=<optimized out>) at postgres.c:4327
 #23 0x0000000000708608 in BackendRun (port=0x509f7c0, port=0x509f7c0)
     at postmaster.c:4464
 #24 SubPostmasterMain (argc=argc(at)entry=3, argv=argv(at)entry=0x5176af0)
     at postmaster.c:4977
 #25 0x000000000093cb13 in main (argc=3, argv=0x5176af0) at main.c:186
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4883>
