[postgis-tickets] [PostGIS] #4904: ClipByBox2D against GEOS 3.10 head failing
PostGIS trac at osgeo.org
Sun May 2 08:16:34 PDT 2021
 Reporter:  robe     |      Owner:  pramsey
     Type:  defect   |     Status:  new
 Priority:  blocker  |  Milestone:  PostGIS 3.2.0
Component:  postgis  |    Version:  master
 Keywords:           |
 Both winnie and debbie are failing with this regress failure and are
 running using last GEOS main commit.
 04:05:50  ./regress/core/clipbybox2d .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/3_2_pg14w64/test_89_diff)
 04:05:50
 04:05:50 --- ./regress/core/clipbybox2d_expected        2020-12-16
 21:48:07.371171208 +0000
 04:05:50 +++
 /var/lib/jenkins/workspace/postgis/tmp/3_2_pg14w64/test_89_out
 2021-05-02 08:05:50.739289748 +0000
 04:05:50 @@ -4,7 +4,7 @@
 04:05:50  4|POINT(2 2)
 04:05:50  5|POLYGON((2 2,8 2,2 8,8 8,2 2))
 04:05:50  6|POLYGON((2.5 2,5 4,5 5,5 4,7.5 2,2.5 2))
 04:05:50 -7|POLYGON((2 2,2 5,5 5,5 2,2 2))
 04:05:50 +7|GEOMETRYCOLLECTION EMPTY
 04:05:50  8|SRID=3857;POLYGON EMPTY
 04:05:50  9|SRID=4326;POINT(0 0)
 04:05:50  10|
 04:05:50
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4904>
