[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-179-g155a4e6
git at osgeo.org
git at osgeo.org
Wed May 5 12:07:17 PDT 2021
the project "PostGIS".
via 155a4e664b51ed6742ca8adffbdc60f1059a9c30 (commit)
via 30706a68a780d6a1555f950f7bae673e649d64ef (commit)
from 87c0512dac0b6f1e06cb0a23d6e2a5d9b7534325 (commit)
revisions in full, below.
commit 155a4e664b51ed6742ca8adffbdc60f1059a9c30
Author: Sandro Santilli <strk at kbt.io>
Date: Tue May 4 18:13:22 2021 +0200
Move hard-coded upgrade data from run_test.pl to hook scripts
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 8203a16..963bcb9 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -41,7 +41,7 @@ clean-local:
# TODO: drop 'test' target..
test: check
-check: check-no-trailing-blanks check-unit check-regress docs-check check-news
+check: check-no-trailing-blanks check-unit check-regress docs-check check-news
staged-install: all
$(MAKE) -C regress staged-install
@@ -197,11 +197,9 @@ ifeq ($(HAVE_SFCGAL),yes)
include sfcgal/regress/tests.mk
endif
ifeq (@TOPOLOGY@,topology)
- override RUNTESTFLAGS := $(RUNTESTFLAGS) --topology
include topology/test/tests.mk
endif
ifeq (@RASTER@,raster)
- override RUNTESTFLAGS := $(RUNTESTFLAGS) --raster
include raster/test/regress/tests.mk
endif
diff --git a/raster/test/regress/Makefile.in b/raster/test/regress/Makefile.in
index 5c0ea48..9117380 100644
--- a/raster/test/regress/Makefile.in
+++ b/raster/test/regress/Makefile.in
@@ -180,9 +180,8 @@ rtpostgis.sql: ../../rt_pg/rtpostgis.sql
$(PERL) -lpe "s'\\\$$libdir'$(REGRESS_INSTALLDIR)/lib'g" $< > $@
-override RUNTESTFLAGS := $(RUNTESTFLAGS) --raster
topsrcdir = $(realpath ../../../)
+srcdir = $(realpath .)
include tests.mk
include ../../../regress/runtest.mk
diff --git a/raster/test/regress/hooks/hook-after-upgrade-raster.sql b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
new file mode 100644
index 0000000..49f5117
--- /dev/null
+++ b/raster/test/regress/hooks/hook-after-upgrade-raster.sql
@@ -0,0 +1 @@
+DROP TABLE upgrade_test_raster;
diff --git a/raster/test/regress/hooks/hook-before-upgrade-raster.sql b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
index 0000000..8c000db
--- /dev/null
+++ b/raster/test/regress/hooks/hook-before-upgrade-raster.sql
@@ -0,0 +1,16 @@
+CREATE TABLE upgrade_test_raster(r raster);
+INSERT INTO upgrade_test_raster(r) VALUES
+ ST_AddBand(
+ ST_MakeEmptyRaster(
+ 10, 10, 1, 1, 2, 2, 0, 0,4326
+ 1,
+ '8BSI'::text,
+ -129,
+ NULL
+--SET client_min_messages TO ERROR;
+SELECT AddRasterConstraints('upgrade_test_raster', 'r');
diff --git a/raster/test/regress/tests.mk b/raster/test/regress/tests.mk
index 07fc69e..db11bdd 100644
--- a/raster/test/regress/tests.mk
+++ b/raster/test/regress/tests.mk
@@ -10,6 +10,12 @@
+override RUNTESTFLAGS := $(RUNTESTFLAGS) --raster
+RUNTESTFLAGS_INTERNAL += \
+ --before-upgrade-script $(topsrcdir)/raster/test/regress/hooks/hook-before-upgrade-raster.sql \
+ --after-upgrade-script $(topsrcdir)/raster/test/regress/hooks/hook-after-upgrade-raster.sql
RASTER_TEST_FIRST = \
$(topsrcdir)/raster/test/regress/check_gdal \
$(topsrcdir)/raster/test/regress/load_outdb
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 876dead..e8c8102 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -20,6 +20,10 @@ INTERRUPTTESTS=@INTERRUPTTESTS@
current_dir := $(dir $(abspath $(lastword $(MAKEFILE_LIST))))
+ --before-upgrade-script $(topsrcdir)/regress/hooks/hook-before-upgrade.sql \
+ --after-upgrade-script $(topsrcdir)/regress/hooks/hook-after-upgrade.sql
TESTS += \
$(topsrcdir)/regress/core/affine \
$(topsrcdir)/regress/core/bestsrid \
@@ -153,7 +157,7 @@ endif
ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31000),1)
TESTS += \
- $(topsrcdir)/regress/core/geos310
+ $(topsrcdir)/regress/core/geos310
endif
ifeq ($(INTERRUPTTESTS),yes)
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index 0000000..459f802
--- /dev/null
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -0,0 +1,2 @@
+DROP VIEW IF EXISTS upgrade_view_test;
+DROP TABLE upgrade_test;
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index 0000000..d4bcb8c
--- /dev/null
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -0,0 +1,26 @@
+CREATE TABLE upgrade_test(g1 geometry, g2 geography);
+INSERT INTO upgrade_test(g1,g2) VALUES
+('POINT(0 0)', 'LINESTRING(0 0, 1 1)'),
+('POINT(1 0)', 'LINESTRING(0 1, 1 1)');
+-- We know upgrading with an st_union() based view
+-- fails unless you're on PostgreSQL 12, so we don't
+-- even try that.
+-- We could re-enable this test IF we fix the upgrade
+-- in pre-12 versions. Refer to
+-- https://trac.osgeo.org/postgis/ticket/4386
+DO $BODY$
+DECLARE
+ vernum INT;
+BEGIN
+ show server_version_num INTO vernum;
+ IF vernum >= 120000
+ THEN
+ RAISE DEBUG '12+ server (%)', vernum;
+ CREATE VIEW upgrade_view_test AS
+ SELECT ST_Union(g1) FROM upgrade_test;
+ END IF;
+END;
+$BODY$ LANGUAGE 'plpgsql';
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 72b254e..938439c 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -94,7 +94,7 @@ GetOptions (
'after-create-script=s' => \@OPT_HOOK_AFTER_CREATE,
'before-uninstall-script=s' => \@OPT_HOOK_BEFORE_UNINSTALL,
'before-upgrade-script=s' => \@OPT_HOOK_BEFORE_UPGRADE,
- 'after-upgrade-script=s' => \@OPT_HOOK_BEFORE_UPGRADE
+ 'after-upgrade-script=s' => \@OPT_HOOK_AFTER_UPGRADE
if ( @ARGV < 1 )
@@ -297,114 +297,6 @@ sub semver_lessthan
return @bcomp ? 1 : 0;
-sub create_upgrade_test_objects
- # TODO: replace the following with --before-upgrade-script usage
- my $query = "create table upgrade_test(g1 geometry, g2 geography";
- $query .= ", r raster" if ( $OPT_WITH_RASTER );
- $query .= ")";
- my $ret = sql($query);
- unless ( $ret =~ /^CREATE/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong creating upgrade_test table: $ret.\n";
- exit(1);
- $query = "insert into upgrade_test(g1,g2) values ";
- $query .= "('POINT(0 0)', 'LINESTRING(0 0, 1 1)'), ";
- $query .= "('POINT(1 0)', 'LINESTRING(0 1, 1 1)');";
- unless ( $ret =~ /^INSERT/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong populating upgrade_test table: $ret.\n";
- exit(1);
- if ( $pgvernum >= 120000 ) {
- # We know upgrading with an st_union() based view
- # fails unless you're on PostgreSQL 12, so we don't
- # even try that.
- # We could re-enable this test IF we fix the upgrade
- # in pre-12 versions. Refer to
- # https://trac.osgeo.org/postgis/ticket/4386
- $query = "create view upgrade_view_test as ";
- $query .= "select st_union(g1) from upgrade_test;";
- `dropdb $DB`;
- print "\nSomething went wrong creating upgrade_view_test view: $ret.\n";
- exit(1);
- if ( $OPT_WITH_RASTER )
- $query = "UPDATE upgrade_test SET r = ";
- $query .= " ST_AddBand(ST_MakeEmptyRaster(10, 10, 1, 1, 2, 2, 0, 0,4326), 1, '8BSI'::text, -129, NULL);";
- $ret = sql($query);
- unless ( $ret =~ /^UPDATE/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong setting raster into upgrade_test table: $ret.\n";
- exit(1);
- $query = "set client_min_messages to error; select AddRasterConstraints('upgrade_test', 'r')";
- unless ( $ret =~ /^t$/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong adding raster constraints to upgrade_test: " . $ret . "\n";
- exit(1);
- if ( $OPT_WITH_TOPO )
- $query = "select topology.createTopology('upgrade_test');";
- unless ( $ret =~ /^[1-9][0-9]*$/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong adding upgrade_test topology: " . $ret . "\n";
- exit(1);
-sub drop_upgrade_test_objects
- # TODO: allow passing the "upgrade-cleanup" script via commandline
- my $ret = sql("drop view if exists upgrade_view_test;");
- unless ( $ret =~ /^DROP/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong dropping spatial view: $ret.\n";
- exit(1);
- my $ret = sql("drop table upgrade_test;");
- `dropdb $DB`;
- print "\nSomething went wrong dropping spatial tables: $ret.\n";
- exit(1);
- my $query = "SELECT topology.DropTopology('upgrade_test');";
- unless ( $ret =~ /^Topology 'upgrade_test' dropped$/ ) {
- `dropdb $DB`;
- print "\nSomething went wrong dropping upgrade_test topology: " . $ret . "\n";
- exit(1);
if ( $OPT_UPGRADE )
print "Upgrading from postgis $libver\n";
@@ -415,8 +307,6 @@ if ( $OPT_UPGRADE )
die unless load_sql_file($hook, 1);
- create_upgrade_test_objects();
if ( $OPT_EXTENSIONS )
upgrade_spatial_extensions();
@@ -426,11 +316,9 @@ if ( $OPT_UPGRADE )
upgrade_spatial();
- drop_upgrade_test_objects();
foreach my $hook (@OPT_HOOK_AFTER_UPGRADE)
- print " Running after-upgrade-script $hook\n";
+ print "Running after-upgrade-script $hook\n";
diff --git a/regress/runtest.mk b/regress/runtest.mk
index cd4cf26..5df1a39 100644
--- a/regress/runtest.mk
+++ b/regress/runtest.mk
@@ -4,17 +4,22 @@ abssrcdir := $(realpath .)
TESTS := $(patsubst $(topsrcdir)/%,$(abstopsrcdir)/%,$(TESTS))
TESTS := $(patsubst $(abssrcdir)/%,./%,$(TESTS))
check-regress:
- @$(PERL) $(topsrcdir)/regress/run_test.pl $(RUNTESTFLAGS) $(TESTS)
+ @echo "RUNTESTFLAGS: $(RUNTESTFLAGS)"
+ @echo "RUNTESTFLAGS_INTERNAL: $(RUNTESTFLAGS_INTERNAL)"
+ @$(PERL) $(topsrcdir)/regress/run_test.pl $(RUNTESTFLAGS) $(RUNTESTFLAGS_INTERNAL) $(TESTS)
# Will now run upgrade test if RUNTESTFLAGS was not already doing that
@if echo "$(RUNTESTFLAGS)" | grep -vq -- --upgrade; then \
- $(PERL) $(topsrcdir)/regress/run_test.pl --upgrade $(RUNTESTFLAGS) $(TESTS); \
+ $(PERL) $(topsrcdir)/regress/run_test.pl \
+ --upgrade \
+ $(RUNTESTFLAGS) \
+ $(TESTS); \
fi
check-long:
diff --git a/topology/test/Makefile.in b/topology/test/Makefile.in
index 732d01b..19d7770 100644
--- a/topology/test/Makefile.in
+++ b/topology/test/Makefile.in
@@ -39,9 +39,8 @@ check-regress: check-regress-deps
check-regress-deps: topo_predicates.sql load_topology.sql load_topology-4326.sql
-override RUNTESTFLAGS := $(RUNTESTFLAGS) --topology
topsrcdir = $(realpath ../../)
include tests.mk
include ../../regress/runtest.mk
diff --git a/topology/test/regress/hooks/hook-after-upgrade-topology.sql b/topology/test/regress/hooks/hook-after-upgrade-topology.sql
index 0000000..c7e2e9c
--- /dev/null
+++ b/topology/test/regress/hooks/hook-after-upgrade-topology.sql
@@ -0,0 +1,2 @@
+SELECT topology.DropTopology('upgrade_test');
diff --git a/topology/test/regress/hooks/hook-before-upgrade-topology.sql b/topology/test/regress/hooks/hook-before-upgrade-topology.sql
index 0000000..9c5529f
--- /dev/null
+++ b/topology/test/regress/hooks/hook-before-upgrade-topology.sql
@@ -0,0 +1,2 @@
+SELECT topology.createTopology('upgrade_test');
diff --git a/topology/test/tests.mk b/topology/test/tests.mk
index 2d8a8da..c2aa2f7 100644
--- a/topology/test/tests.mk
+++ b/topology/test/tests.mk
@@ -10,6 +10,12 @@
+override RUNTESTFLAGS := $(RUNTESTFLAGS) --topology
+ --before-upgrade-script $(topsrcdir)/topology/test/regress/hooks/hook-before-upgrade-topology.sql \
+ --after-upgrade-script $(topsrcdir)/topology/test/regress/hooks/hook-after-upgrade-topology.sql
TESTS += \
$(topsrcdir)/topology/test/regress/addedge.sql \
$(topsrcdir)/topology/test/regress/addface2.5d.sql \
commit 30706a68a780d6a1555f950f7bae673e649d64ef
Date: Tue May 4 22:58:01 2021 +0200
gitlab-ci: avoid unit tests when testing dump/restore
diff --git a/.gitlab-ci.yml b/.gitlab-ci.yml
index 175ca4d..30457ff 100644
--- a/.gitlab-ci.yml
+++ b/.gitlab-ci.yml
@@ -19,7 +19,7 @@ test:
- ./configure CFLAGS="-Wall -fno-omit-frame-pointer -Werror"
- make
- RUNTESTFLAGS=-v make check
- - RUNTESTFLAGS="-v --dumprestore" make check
+ - RUNTESTFLAGS="-v --dumprestore" make check-regress
- make install
- RUNTESTFLAGS=-v make installcheck
- RUNTESTFLAGS="-v --dumprestore" make installcheck
Summary of changes:
.gitlab-ci.yml | 2 +-
GNUmakefile.in | 4 +-
raster/test/regress/Makefile.in | 3 +-
.../regress/hooks/hook-after-upgrade-raster.sql | 1 +
.../regress/hooks/hook-before-upgrade-raster.sql | 16 +++
raster/test/regress/tests.mk | 6 ++
regress/core/tests.mk.in | 6 +-
regress/hooks/hook-after-upgrade.sql | 2 +
regress/hooks/hook-before-upgrade.sql | 26 +++++
regress/run_test.pl | 116 +--------------------
regress/runtest.mk | 11 +-
topology/test/Makefile.in | 3 +-
.../regress/hooks/hook-after-upgrade-topology.sql | 2 +
.../regress/hooks/hook-before-upgrade-topology.sql | 2 +
topology/test/tests.mk | 6 ++
15 files changed, 80 insertions(+), 126 deletions(-)
create mode 100644 raster/test/regress/hooks/hook-after-upgrade-raster.sql
create mode 100644 raster/test/regress/hooks/hook-before-upgrade-raster.sql
create mode 100644 regress/hooks/hook-after-upgrade.sql
create mode 100644 regress/hooks/hook-before-upgrade.sql
create mode 100644 topology/test/regress/hooks/hook-after-upgrade-topology.sql
create mode 100644 topology/test/regress/hooks/hook-before-upgrade-topology.sql
hooks/post-receive
