[postgis-tickets] [PostGIS] #4909: Add the ability to read back (and edit) mvt
PostGIS trac at osgeo.org
Thu May 6 10:06:46 PDT 2021
 Reporter:  autra        |      Owner:  pramsey
     Type:  enhancement  |     Status:  new
 Priority:  medium       |  Milestone:  PostGIS 3.1.2
Component:  postgis      |    Version:  master
 Keywords:  mvt          |
 == Description
 Provide a way to read back mvt tile content.
 == Context and use case
 I'm using a table to cache feature simplification for visualization
 purpose (with pg_tileserv). The dataset is quite big (will be around
 600GB).
 I want to cache some x,y,z tile alongside the tile in mvt format. But
 after updating part of the underlying dataset, if I want to refresh the
 cache, I would need to update part of a mvt tile (or regenerate the whole
 pyramid, but that's not feasible in my case).
 The solution I've chosen now is to to keep each mvtgeometry and aggregate
 only when visualizing, but I'd like to be able to do the extra mile and
 keep only the mvt. If it were possible, it would allow me to get better
 serving speed (and simplify the serving function).
 == Proposition
 Implement a ST_FromMvt or ST_ExplodeMvt, or ST_DumpMvt that would
 basically do the reverse operation of ST_AsMvt.
 Thanks!
 (NB: to give the full story : the features are points that are currently
 stored with pgpointcloud extension.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4909>
