[postgis-tickets] [PostGIS] #4326: Circular strings distances are wrong
trac at osgeo.org
Fri May 7 06:58:10 PDT 2021
Reporter: komzpa | Owner: strk
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.5.3
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Changes (by robe):
* status: closed => reopened
* resolution: fixed =>
Comment:
As noted by abobov on IRC this returns 0 instead of some non-zero answer
WITH DATA AS (SELECT 'SRID=3857;CURVEPOLYGON(CIRCULARSTRING(7874821
8715927,8907663 8715927,8844683 7750316,7937800 7750316,7874821
8715927))'::geometry AS a,
'SRID=3857;Point (5433865 8243495)'::geometry AS b)
SELECT st_distance(a, b), a && b AS bbox_intersect FROM DATA;
Returns:
0 false
I would expect it to return something in ballpark of applying
ST_LineToCurve answer:
ST_CurveToLine('SRID=3857;CURVEPOLYGON(CIRCULARSTRING(7874821
8715927))'::geometry) AS a,
SELECT st_distance(a, b) FROM DATA;
which returns:
2271892.5770899933
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4326#comment:7>
