[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-181-gcea69ba
git at osgeo.org
git at osgeo.org
Fri May 7 11:43:43 PDT 2021
the project "PostGIS".
via cea69ba7aebce4fc719b4a2a687c8f19b756a36a (commit)
from 2a439cb5fad50bb50c62ed9b418656a8712dde29 (commit)
revisions in full, below.
commit cea69ba7aebce4fc719b4a2a687c8f19b756a36a
Author: Martin Davis <mtnclimb at gmail.com>
Date: Fri May 7 11:43:36 2021 -0700
Add doc Geometry sections
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index fa2930e..5145651 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -3,122 +3,249 @@
<title>Data Management</title>
<sect1 id="RefObject">
- <title>Geometry Data Type</title>
+ <title>Spatial Data Model</title>
+ <sect2 id="OGC_Geometry">
+ <title>OGC Geometry</title>
<para>The Open Geospatial Consortium (OGC) developed the
<ulink url="https://www.ogc.org/standards/sfa"><emphasis>Simple Features Access</emphasis></ulink>
standard (SFA) to provide a model for geospatial data.
It defines the fundamental spatial data type of Geometry, with
a set of subtypes that represent various kinds and dimensions of geometric shapes.
+ The latest SFA version
+ <ulink url="https://portal.ogc.org/files/?artifact_id=25355"><emphasis>Simple Features Access - Part 1: Common architecture v1.2.1</emphasis></ulink>
+ adds subtypes for the more complex geometric objects PolyhedralSurfaces, Triangles and TINs.
</para>
- <para>The core Geometry subtypes model shapes on the 2-dimensional Cartesian coordinate plane
- constructed from points and line segments:</para>
- <itemizedlist>
- <listitem>
- <para>Point - a 0-dimensional geometry that represents a single location in coordinate space</para>
- </listitem>
- <listitem>
- <para>LineString - a 1-dimensional line formed by a contigous sequence of line segments</para>
- </listitem>
- <listitem>
- <para>LinearRing - a LineString which is closed and simple (non-intersecting)</para>
- </listitem>
- <listitem>
- <para>Polygon - a 2-dimensional planar region, delimited by an exterior boundary and zero or more interior boundaries (holes).
- The boundaries are formed by LinearRings
- </para>
- </listitem>
- <listitem>
- <para>MultiPoint - a collection of Points</para>
- </listitem>
- <listitem>
- <para>MultiLineString - a collection of LineStrings</para>
- </listitem>
- <listitem>
- <para>MultiPolygon - a collection of non-overlapping polygons</para>
- </listitem>
- <listitem>
- <para>GeometryCollection - a heterogenous (mixed) collection of geometries</para>
- </listitem>
- </itemizedlist>
+ <para>The geometry types model shapes on the 2-dimensional Cartesian plane
+ constructed from points and line segments.
+ The size and location of shapes are specified by their <emphasis role="bold">coordinates</emphasis>.
+ The points and line segments are defined by one or two coordinates in the plane.
+ Each coordinate has a X and Y value determining its location in the plane.
+ </para>
- <para>The subsequent SFA standard
- <ulink url="https://portal.ogc.org/files/?artifact_id=25355"><emphasis>Simple Features Access - Part 1: Common architecture v1.2.1</emphasis></ulink>
- added the following subtypes:
+ <para>Coordinates may also contain optional Z and M ordinate values.
+ The Z ordinate is usually used to represent elevation above the plane.
+ The M ordinate can be used to contain a measure value,
+ which may represent time or distance.
+ If Z or M values are present in a geometry value, they must be defined for each point in the geometry.
+ If a geometry has Z or M ordinates the <emphasis role="bold">coordinate dimension</emphasis> is 3D;
+ if it has both Z and M the coordinate dimension is 4D.
</para>
- <itemizedlist>
- <listitem>
- <para>PolyhedralSurface - a 3-dimensional surface consisting of a set of planar Polygons defined in 3D space</para>
- </listitem>
- <listitem>
- <para>Triangle - a triangle defined by 3 distinct non-collinear coordinates</para>
- </listitem>
- <listitem>
- <para>TIN - a collection of non-overlapping Triangles representing a triangulated irregular network</para>
- </listitem>
- </itemizedlist>
+ <para>Each geometry value is associated with a
+ <emphasis role="bold">spatial reference system</emphasis>
+ indicating the coordinate system in which it is embedded.
+ See <xref linkend="spatial_ref_sys" />.
+ The spatial reference system is identifed by a SRID number.
+ In <emphasis role="bold">planar</emphasis> reference systems the X and Y coordinates typically
+ represent easting and northing,
+ while in <emphasis role="bold">geodetic</emphasis> systems
+ they represent longitude and latitude.
+ The units of the X and Y axes are determined by the reference system.
+ SRID 0 represents an infinite Cartesian plane with no units assigned to its axes.
+ </para>
- <para>The ISO SQL/MM standard introduced Geometry subtypes
- to model geospatial data containing circular arcs
- (see also <xref linkend="SQL_MM_Part3" />):</para>
+ <para>The geometry <emphasis role="bold">dimension</emphasis> is a property of geometry types.
+ Point types have dimension 0, linear types have dimension 1,
+ and polygonal types have dimension 2.
+ Collections have the dimension of the maximum element dimension.
+ </para>
- <itemizedlist>
- <listitem>
- <para>CircularString - a 1-dimensional curve formed by a contiguous sequence of circular arcs</para>
- </listitem>
- <listitem>
- <para>CompoundCurve - a 1-dimensional curve formed by a contiguous sequence of LineStrings or CircularStrings</para>
- </listitem>
- <listitem>
- <para>CurvePolygon - a 2-dimensional planar region delimited by a CompoundCurve outer boundary
- and zero or more CompoundCurve interior boundaries (holes)</para>
- </listitem>
- <listitem>
- <para>MultiCurve - a collection of LineStrings or CompoundCurves</para>
- </listitem>
- <listitem>
- <para>MultiSurface - a collection of Polygons and CurvePolygons</para>
- </listitem>
- </itemizedlist>
+ <para>A geometry value may be <emphasis role="bold">empty</emphasis>.
+ Empty values contain no vertices (for atomic geometry types)
+ or no elements (for collections).
+ </para>
- <para>PostGIS implements the OGC Simple Features model
- by defining a PostgreSQL data type called <varname>geometry</varname>.
- It represents all of the OGC subtypes by using an internal type code
- (see <xref linkend="GeometryType" />).
+ <para>The geometry model allows evaluating topological spatial relationships as
+ described in <xref linkend="DE-9IM" />.
+ To support this the concepts of
+ <emphasis role="bold">interior</emphasis>, <emphasis role="bold">boundary</emphasis>
+ and <emphasis role="bold">exterior</emphasis>
+ are defined for each geometry type.
</para>
- <para>The <varname>geometry</varname> data type is <emphasis>opaque</emphasis>,
- which means that all access is done via invoking functions on geometry data objects.
- The functions allow creating geometry objects,
- accessing or updating all internal fields,
- and compute new geometry values.
- PostGIS supports all the functions specified in the OGC
- <ulink url="https://portal.ogc.org/files/?artifact_id=25354"><emphasis>Simple feature access - Part 2: SQL option</emphasis></ulink>
- (SFS) specification, as well many others.
- See <xref linkend="reference" /> for the full list.</para>
+ <sect3 id="Point">
+ <title>Point</title>
+ <para>A Point is a 0-dimensional geometry that represents a single location in coordinate space.</para>
+ <programlisting>POINT (1 2)</programlisting>
+ </sect3>
+ <sect3 id="LineString">
+ <title>LineString</title>
+ <para>A LineString is a 1-dimensional line formed by a contigous sequence of line segments.
+ Each line segment is defined by two points, with the end point of one segment
+ forming the start point of the next segment.
+ A LineString must have at least two points.
+ LineStrings may cross themselves (self-intersect).
+ A LineString is closed if the start and end points are the same.
+ </para>
+ <programlisting>LINESTRING (1 2, 3 4)</programlisting>
+ </sect3>
+ <sect3 id="LinearRing">
+ <title>LinearRing</title>
+ <para>A LinearRing is a LineString which is closed
+ and simple (non-intersecting).</para>
+ <programlisting>LINEARRING (0 0 0,4 0 0,4 4 0,0 4 0,0 0 0)</programlisting>
+ </sect3>
+ <sect3 id="Polygon">
+ <title>Polygon</title>
+ <para>A Polygon is a 2-dimensional planar region,
+ delimited by an exterior boundary (the shell)
+ and zero or more interior boundaries (holes).
+ The boundaries are formed by LinearRings.
+ </para>
+ <programlisting>POLYGON ((0 0 0,4 0 0,4 4 0,0 4 0,0 0 0),(1 1 0,2 1 0,2 2 0,1 2 0,1 1 0))</programlisting>
+ </sect3>
+ <sect3 id="MultiPoint">
+ <title>MultiPoint</title>
+ <para>A MultiPoint is a collection of Points.</para>
+ <programlisting>MULTIPOINT ( (0 0), (1 2) )</programlisting>
+ </sect3>
+ <sect3 id="MultiLineString">
+ <title>MultiLineString</title>
+ <para>A MultiLineString is a collection of LineStrings.
+ A MultiLineString is closed if each of its element is closed.
+ </para>
+ <programlisting>MULTILINESTRING ( (0 0,1 1,1 2), (2 3,3 2,5 4) )</programlisting>
+ </sect3>
- <note>
- <para>PostGIS follows the SFA standard by prefixing spatial functions with "ST_".
- This was intended to stand for "Spatial and Temporal",
- but the temporal part of the standard was never developed.
- Instead it can be interpreted as "Spatial Type".
+ <sect3 id="MultiPolygon">
+ <title>MultiPolygon</title>
+ <para>A MultiPolygon is a collection of non-overlapping, non-adjacent Polygons.
+ Polygons in the collection may touch in only a finite number of points.
</para>
- </note>
+ <programlisting>MULTIPOLYGON (((1 5, 5 5, 5 1, 1 1, 1 5)), ((6 5, 9 1, 6 1, 6 5)))</programlisting>
+ </sect3>
+ <sect3 id="GeometryCollection">
+ <title>GeometryCollection</title>
+ <para>A GeometryCollection is a heterogenous (mixed) collection of geometries.</para>
+ <programlisting>GEOMETRYCOLLECTION ( POINT(2 3), LINESTRING(2 3,3 4))</programlisting>
+ </sect3>
+ <sect3 id="PolyhedralSurface">
+ <title>PolyhedralSurface</title>
+ <para>A PolyhedralSurface is a contiguous collection of patches or facets which share some edges.
+ Each patch is a planar Polygon.
+ If the Polygon coordinates have Z ordinates then the surface is 3-dimensional.</para>
+ <programlisting>POLYHEDRALSURFACE (
+ ((0 0 0, 0 0 1, 0 1 1, 0 1 0, 0 0 0)),
+ ((0 0 0, 0 1 0, 1 1 0, 1 0 0, 0 0 0)),
+ ((0 0 0, 1 0 0, 1 0 1, 0 0 1, 0 0 0)),
+ ((1 1 0, 1 1 1, 1 0 1, 1 0 0, 1 1 0)),
+ ((0 1 0, 0 1 1, 1 1 1, 1 1 0, 0 1 0)),
+ ((0 0 1, 1 0 1, 1 1 1, 0 1 1, 0 0 1)) )</programlisting>
+ </sect3>
+ <sect3 id="Triangle">
+ <title>Triangle</title>
+ <para>A Triangle is a polygon defined by 3 distinct non-collinear points.</para>
+ <programlisting>TRIANGLE ((0 0, 0 9, 9 0, 0 0))</programlisting>
+ </sect3>
+ <sect3 id="Tin">
+ <title>Tin</title>
+ <para>A Tin is a collection of non-overlapping Triangles
+ representing a triangulated irregular network.</para>
+ <programlisting>TIN( ((0 0 0, 0 0 1, 0 1 0, 0 0 0)), ((0 0 0, 0 1 0, 1 1 0, 0 0 0)) )</programlisting>
+ </sect3>
- <para>The SFA standard specifies that spatial objects include a Spatial Reference System
- identifier (SRID). The SRID is required when creating spatial objects
- for insertion into the database (it may be defaulted to 0).
- See <xref linkend="ST_SRID" /> and <xref linkend="spatial_ref_sys" /></para>
- <para>To make querying geometry efficient PostGIS defines
- various kinds of spatial indexes. See <xref linkend="build-indexes" /> for details.
- </para>
+</sect2>
+ <sect2 id="SQL_MM_Part3">
+ <title>SQL/MM Part 3 - Curves</title>
+ <para>The
+ <ulink url="https://www.iso.org/obp/ui/#iso:std:iso-iec:13249:-3:ed-5:v1:en"><emphasis>ISO/IEC 13249-3 SQL Multimedia - Spatial</emphasis></ulink>
+ standard (SQL/MM) extends the
+ OGC SFA to define Geometry subtypes containing curves with circular arcs.
+ The SQL/MM types supprt 3DM, 3DZ and 4D coordinates.
+ </para>
+ <note>
+ <para>All floating point comparisons within the SQL-MM implementation
+ are performed to a specified tolerance, currently 1E-8.</para>
+ </note>
+ <sect3 id="CircularString">
+ <title>CircularString</title>
+ <para>CircularString is the basic curve type, similar to a
+ LineString in the linear world. A single arc segment requires three
+ points: the start and end points (first and third) and some other
+ point on the arc. The exception to this is for a closed circle,
+ where the start and end points are the same. In this case the
+ second point MUST be the center of the arc, ie the opposite side of
+ the circle. To chain arcs together, the last point of the previous
+ arc is the first point of the next arc, just like in a
+ LineString. This means that a valid circular string must have an
+ odd number of points greater than 1.</para>
+ <programlisting>CIRCULARSTRING(0 0, 1 1, 1 0)
+CIRCULARSTRING(0 0, 4 0, 4 4, 0 4, 0 0)</programlisting>
+ </sect3>
+ <sect3 id="CompoundCurve">
+ <title>CompoundCurve</title>
+ <para>A CompoundCurve is a single continuous curve that may contain both
+ circular arc segments and linear segments. That means that
+ in addition to having well-formed components, the end point of
+ every component (except the last) must be coincident with the
+ start point of the following component.</para>
+ <programlisting>COMPOUNDCURVE( CIRCULARSTRING(0 0, 1 1, 1 0),(1 0, 0 1))</programlisting>
+ </sect3>
+ <sect3 id="CurvePolygon">
+ <title>CurvePolygon</title>
+ <para>A CurvePolygon is like a polygon, with an outer ring
+ and zero or more inner rings. The difference is that a ring can be a
+ CircularString or CompoundCurve as well as a LineString.
+ </para>
+ <para>As of PostGIS 1.4 PostGIS supports compound curves in a curve polygon.</para>
+ <programlisting>CURVEPOLYGON(
+ CIRCULARSTRING(0 0, 4 0, 4 4, 0 4, 0 0),
+ (1 1, 3 3, 3 1, 1 1) )</programlisting>
+ <para>Example: A CurvePolygon with the shell defined by a CompoundCurve
+ containing a CircularString and a LineString,
+ and a hole defined by a CircularString</para>
+ COMPOUNDCURVE( CIRCULARSTRING(0 0,2 0, 2 1, 2 3, 4 3),
+ (4 3, 4 5, 1 4, 0 0)),
+ CIRCULARSTRING(1.7 1, 1.4 0.4, 1.6 0.4, 1.6 0.5, 1.7 1) )</programlisting>
+ </sect3>
+ <sect3 id="MultiCurve">
+ <title>MultiCurve</title>
+ <para>A MultiCurve is a collection of curves which can include
+ LineStrings, CircularStrings or CompoundCurves.</para>
+ <programlisting>MULTICURVE( (0 0, 5 5), CIRCULARSTRING(4 0, 4 4, 8 4))</programlisting>
+ </sect3>
+ <sect3 id="MultiSurface">
+ <title>MultiSurface</title>
+ <para>A MultiSurface is a collection of surfaces, which can be (linear)
+ Polygons or CurvePolygons.</para>
+ <programlisting>MULTISURFACE(
+ CURVEPOLYGON(
+ CIRCULARSTRING( 0 0, 4 0, 4 4, 0 4, 0 0),
+ (1 1, 3 3, 3 1, 1 1)),
+ ((10 10, 14 12, 11 10, 10 10), (11 11, 11.5 11, 11 11.5, 11 11)))</programlisting>
+ </sect3>
+ </sect2>
<sect2 id="OpenGISWKBWKT">
- <title>OGC WKB and WKT</title>
+ <title>WKT and WKB</title>
<para>The OGC SFA specification defines two standard formats for representing
geometry values for external use: Well-Known Text (WKT) and Well-Known
@@ -142,10 +269,18 @@
</listitem>
<listitem>
+ <para>POINT EMPTY</para>
+ </listitem>
+ <listitem>
<para>LINESTRING(0 0,1 1,1 2)</para>
</listitem>
<listitem>
+ <para>LINESTRING EMPTY</para>
+ </listitem>
+ <listitem>
<para>POLYGON((0 0,4 0,4 4,0 4,0 0),(1 1, 2 1, 2 2, 1 2,1 1))</para>
</listitem>
@@ -158,6 +293,10 @@
</listitem>
<listitem>
+ <para>MULTIPOINT EMPTY</para>
+ </listitem>
+ <listitem>
<para>MULTILINESTRING((0 0,1 1,1 2),(2 3,3 2,5 4))</para>
</listitem>
@@ -169,6 +308,10 @@
<listitem>
<para>GEOMETRYCOLLECTION(POINT(2 3),LINESTRING(2 3,3 4))</para>
</listitem>
+ <listitem>
+ <para>GEOMETRYCOLLECTION EMPTY</para>
+ </listitem>
</itemizedlist>
<para>Input and output of WKT is provided by the functions
@@ -213,6 +356,47 @@ geometry = ST_GeomFromWKB(bytea WKB, SRID);
VALUES ( ST_GeomFromWKB('\x0101000000000000000000f03f000000000000f03f', 312), 'A Place');</programlisting>
</sect2>
+ </sect1>
+ <sect1 id="PostGIS_Geometry">
+ <title>Geometry Data Type</title>
+ <para>PostGIS implements the OGC Simple Features model
+ by defining a PostgreSQL data type called <varname>geometry</varname>.
+ It represents all of the geometry subtypes by using an internal type code
+ (see <xref linkend="GeometryType" /> and <xref linkend="ST_GeometryType" />).
+ This allows modelling spatial features as rows of tables defined
+ with a column of type <varname>geometry</varname>.
+ </para>
+ <para>The <varname>geometry</varname> data type is <emphasis>opaque</emphasis>,
+ which means that all access is done via invoking functions on geometry values.
+ Functions allow creating geometry objects,
+ accessing or updating all internal fields,
+ and compute new geometry values.
+ PostGIS supports all the functions specified in the OGC
+ <ulink url="https://portal.ogc.org/files/?artifact_id=25354"><emphasis>Simple feature access - Part 2: SQL option</emphasis></ulink>
+ (SFS) specification, as well many others.
+ See <xref linkend="reference" /> for the full list of functions.</para>
+ <note>
+ <para>PostGIS follows the SFA standard by prefixing spatial functions with "ST_".
+ This was intended to stand for "Spatial and Temporal",
+ but the temporal part of the standard was never developed.
+ Instead it can be interpreted as "Spatial Type".
+ </para>
+ </note>
+ <para>The SFA standard specifies that spatial objects include a Spatial Reference System
+ identifier (SRID). The SRID is required when creating spatial objects
+ for insertion into the database (it may be defaulted to 0).
+ See <xref linkend="ST_SRID" /> and <xref linkend="spatial_ref_sys" /></para>
+ <para>To make querying geometry efficient PostGIS defines
+ various kinds of spatial indexes, and spatial operators to use them.
+ See <xref linkend="build-indexes" /> and <xref linkend="using-query-indexes" /> for details.
+ </para>
<sect2 id="EWKB_EWKT">
<title>PostGIS EWKB and EWKT</title>
@@ -252,17 +436,17 @@ geometry = ST_GeomFromWKB(bytea WKB, SRID);
<listitem>
<para>For 3DZ geometries the Z qualifier is omitted:</para>
<para>OGC: POINT Z (1 2 3)</para>
- <para>EWKT: POINT(1 2 3)</para>
+ <para>EWKT: POINT (1 2 3)</para>
</listitem>
<listitem>
<para>For 3DM geometries the M qualifier is included:</para>
<para>OGC: POINT M (1 2 3)</para>
- <para>EWKT: POINTM(1 2 3)</para>
+ <para>EWKT: POINTM (1 2 3)</para>
</listitem>
<listitem>
<para>For 4D geometries the ZM qualifier is omitted:</para>
<para>OGC: POINT ZM (1 2 3 4)</para>
- <para>EWKT: POINT(1 2 3 4)</para>
+ <para>EWKT: POINT (1 2 3 4)</para>
</listitem>
</itemizedlist>
@@ -366,79 +550,8 @@ geometry = ST_GeomFromEWKT(text EWKT);</programlisting>
</sect2>
- <sect2 id="SQL_MM_Part3">
- <title>SQL/MM Part 3 - Curves</title>
- <para>The ISO/IEC 13249-3
- <ulink url="https://www.iso.org/obp/ui/#iso:std:iso-iec:13249:-3:ed-5:v1:en"><emphasis>SQL Multimedia - Spatial</emphasis></ulink>
- standard (SQL/MM) extends the
- OGC SFA to define Geometry subtypes containing curves with circular arcs.
- The SQL/MM definitions include 3DM, 3DZ and 4D coordinates, but do
- not allow the embedding of SRID information.
- </para>
- <para>Examples of curved geometries are shown below:</para>
- <itemizedlist>
- <listitem>
- <para>CIRCULARSTRING(0 0, 1 1, 1 0)</para>
- <para>CIRCULARSTRING(0 0, 4 0, 4 4, 0 4, 0 0)</para>
- <para>The CIRCULARSTRING is the basic curve type, similar to a
- LINESTRING in the linear world. A single segment required three
- points, the start and end points (first and third) and any other
- point on the arc. The exception to this is for a closed circle,
- where the start and end points are the same. In this case the
- second point MUST be the center of the arc, ie the opposite side of
- the circle. To chain arcs together, the last point of the previous
- arc becomes the first point of the next arc, just like in
- LINESTRING. This means that a valid circular string must have an
- odd number of points greater than 1.</para>
- </listitem>
- <listitem>
- <para>COMPOUNDCURVE(CIRCULARSTRING(0 0, 1 1, 1 0),(1 0, 0 1))</para>
- <para>A compound curve is a single, continuous curve that has both
- curved (circular) segments and linear segments. That means that
- in addition to having well-formed components, the end point of
- every component (except the last) must be coincident with the
- start point of the following component.</para>
- </listitem>
- <listitem>
- <para>CURVEPOLYGON(CIRCULARSTRING(0 0, 4 0, 4 4, 0 4, 0 0),(1 1, 3
- 3, 3 1, 1 1))</para>
- <para>Example compound curve in a curve polygon:
- CURVEPOLYGON(COMPOUNDCURVE(CIRCULARSTRING(0 0,2 0, 2 1, 2 3, 4 3),(4 3, 4 5, 1 4, 0 0)),
- CIRCULARSTRING(1.7 1, 1.4 0.4, 1.6 0.4, 1.6 0.5, 1.7 1) )
- </para>
- <para>A CURVEPOLYGON is just like a polygon, with an outer ring
- and zero or more inner rings. The difference is that a ring can
- take the form of a circular string, linear string or compound
- string.</para>
- <para>As of PostGIS 1.4 PostGIS supports compound curves in a curve polygon.</para>
- </listitem>
- <listitem>
- <para>MULTICURVE((0 0, 5 5),CIRCULARSTRING(4 0, 4 4, 8 4))</para>
- <para>The MULTICURVE is a collection of curves, which can include
- linear strings, circular strings or compound strings.</para>
- </listitem>
- <listitem>
- <para>MULTISURFACE(CURVEPOLYGON(CIRCULARSTRING(0 0, 4 0, 4 4, 0 4, 0
- 0),(1 1, 3 3, 3 1, 1 1)),((10 10, 14 12, 11 10, 10 10),(11 11, 11.5
- 11, 11 11.5, 11 11)))</para>
- <para>This is a collection of surfaces, which can be (linear)
- polygons or curve polygons.</para>
- </listitem>
- </itemizedlist>
- <note>
- <para>All floating point comparisons within the SQL-MM implementation
- are performed to a specified tolerance, currently 1E-8.</para>
- </note>
- </sect2>
</sect1>
<sect1 id="PostGIS_Geography">
<title>Geography Data Type</title>
Summary of changes:
doc/using_postgis_dataman.xml | 451 ++++++++++++++++++++++++++----------------
1 file changed, 282 insertions(+), 169 deletions(-)
hooks/post-receive
