[postgis-tickets] [PostGIS] #4911: Capturing coordinate epoch in database
PostGIS trac at osgeo.org
Sat May 8 12:17:19 PDT 2021
  Reporter:  rouault      |      Owner:  pramsey
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.1.2
 Component:  postgis      |    Version:
Resolution:               |   Keywords:
Comment (by rouault):
 > So if the source or target SRSs require an epoch you would read it from
 the geometry header (if available) or from the SRID (if available). Would
 that make sense?
 Yes
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4911#comment:2>
