[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-187-g8245dd1
git at osgeo.org
git at osgeo.org
Thu May 13 19:12:04 PDT 2021
the project "PostGIS".
via 8245dd1d2202c933c20c7d78fa626f11394de31a (commit)
via 13ea2201fa3d21532db3cd8c2e6784faaf56eb27 (commit)
via 034717488e2bcf3738db3b91d5e9883f8e77b4ea (commit)
via b73546d16cfc3dbb1427c2f4def1c92e9099b420 (commit)
via b984995719470caa24402ebe992e6753126c23e0 (commit)
from 5ab22a7dd6a4518a8ed3456d8cfcf09fa8ab9892 (commit)
revisions in full, below.
commit 8245dd1d2202c933c20c7d78fa626f11394de31a
Merge: 5ab22a7 13ea220
Author: Regina Obe <lr at pcorp.us>
Date: Thu May 13 21:21:31 2021 -0400
Properly test -Z switch. Closes #4905
Closes https://github.com/postgis/postgis/pull/612
commit 13ea2201fa3d21532db3cd8c2e6784faaf56eb27
Author: Stefan Petrea <stefan.petrea at gmail.com>
Date: Thu May 6 18:52:40 2021 +0300
moved test table to public schema; added negative test
- moved test table to default schema (removed pre/post sql)
- added TestANALYZE as the negative test (TestSkipANALYZE is the positive one)
diff --git a/regress/loader/TestANALYZE.dbf b/regress/loader/TestANALYZE.dbf
new file mode 100644
index 0000000..13b4aee
Binary files /dev/null and b/regress/loader/TestANALYZE.dbf differ
diff --git a/regress/loader/TestANALYZE.opts b/regress/loader/TestANALYZE.opts
index 0000000..d82cb4c
--- /dev/null
+++ b/regress/loader/TestANALYZE.opts
@@ -0,0 +1,2 @@
+# Test with ANALYZE
+-g the_geom {regdir}/loader/TestSkipANALYZE loadedshp
diff --git a/regress/loader/TestANALYZE.select.expected b/regress/loader/TestANALYZE.select.expected
index 0000000..d00491f
--- /dev/null
+++ b/regress/loader/TestANALYZE.select.expected
@@ -0,0 +1 @@
+1
diff --git a/regress/loader/TestANALYZE.select.sql b/regress/loader/TestANALYZE.select.sql
index 0000000..de56987
--- /dev/null
+++ b/regress/loader/TestANALYZE.select.sql
@@ -0,0 +1,4 @@
+-- Expecting the table to have been analyzed
+SELECT COUNT(stanumbers1)
+FROM pg_statistic
+WHERE starelid = 'public.loadedshp'::regclass AND stanumbers1 IS NOT NULL;
diff --git a/regress/loader/TestANALYZE.shp b/regress/loader/TestANALYZE.shp
index 0000000..51d38e7
Binary files /dev/null and b/regress/loader/TestANALYZE.shp differ
diff --git a/regress/loader/TestANALYZE.shx b/regress/loader/TestANALYZE.shx
index 0000000..7db02af
Binary files /dev/null and b/regress/loader/TestANALYZE.shx differ
diff --git a/regress/loader/TestSkipANALYZE-post.sql b/regress/loader/TestSkipANALYZE-post.sql
deleted file mode 100644
index fd98c18..0000000
--- a/regress/loader/TestSkipANALYZE-post.sql
+++ /dev/null
@@ -1,3 +0,0 @@
-DROP TABLE IF EXISTS pgreg.loadedshp;
---DELETE FROM geometry_columns WHERE f_table_schema='pgreg';
-DROP SCHEMA pgreg;
diff --git a/regress/loader/TestSkipANALYZE-pre.sql b/regress/loader/TestSkipANALYZE-pre.sql
index 6a860c3..0000000
--- a/regress/loader/TestSkipANALYZE-pre.sql
+++ /dev/null
@@ -1 +0,0 @@
-CREATE SCHEMA pgreg;
diff --git a/regress/loader/TestSkipANALYZE.opts b/regress/loader/TestSkipANALYZE.opts
index 0bce557..4ffc225 100644
--- a/regress/loader/TestSkipANALYZE.opts
+++ b/regress/loader/TestSkipANALYZE.opts
@@ -1,2 +1,2 @@
# Test -Z skips ANALYZE
--Z -g the_geom {regdir}/loader/TestSkipANALYZE pgreg.loadedshp
+-Z -g the_geom {regdir}/loader/TestSkipANALYZE loadedshp
diff --git a/regress/loader/TestSkipANALYZE.select.sql b/regress/loader/TestSkipANALYZE.select.sql
index 19ec0aa..295f718 100644
--- a/regress/loader/TestSkipANALYZE.select.sql
+++ b/regress/loader/TestSkipANALYZE.select.sql
@@ -1,5 +1,5 @@
--- Checks if the table pgreg.loadedshp was analyzed by
--- querying the respective PostgreSQL system catalog
+-- Checks if the table was analyzed by looking at the table statistics
+-- in the pg system catalog
FROM pg_statistic
-WHERE starelid = 'pgreg.loadedshp'::regclass AND stanumbers1 IS NOT NULL;
+WHERE starelid = 'loadedshp'::regclass AND stanumbers1 IS NOT NULL;
diff --git a/regress/loader/tests.mk b/regress/loader/tests.mk
index 757edc6..f6be1df 100644
--- a/regress/loader/tests.mk
+++ b/regress/loader/tests.mk
@@ -38,4 +38,5 @@ TESTS += \
$(topsrcdir)/regress/loader/Latin1 \
$(topsrcdir)/regress/loader/Latin1-implicit \
$(topsrcdir)/regress/loader/mfile \
- $(topsrcdir)/regress/loader/TestSkipANALYZE
+ $(topsrcdir)/regress/loader/TestSkipANALYZE \
+ $(topsrcdir)/regress/loader/TestANALYZE
commit 034717488e2bcf3738db3b91d5e9883f8e77b4ea
Date: Thu May 6 02:05:11 2021 +0300
added before-uninstall hook to make this condition true: COUNT(preinstall_objects) == COUNT(postinstall_objects)
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index a9e7902..ddc2820 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -23,7 +23,8 @@ current_dir := $(dir $(abspath $(lastword $(MAKEFILE_LIST))))
RUNTESTFLAGS_INTERNAL += \
--before-upgrade-script $(topsrcdir)/regress/hooks/hook-before-upgrade.sql \
--after-upgrade-script $(topsrcdir)/regress/hooks/hook-after-upgrade.sql \
- --after-create-script $(topsrcdir)/regress/hooks/hook-after-create.sql
+ --after-create-script $(topsrcdir)/regress/hooks/hook-after-create.sql \
+ --before-uninstall-script $(topsrcdir)/regress/hooks/hook-before-uninstall.sql
TESTS += \
$(topsrcdir)/regress/core/affine \
diff --git a/regress/hooks/hook-after-create.sql b/regress/hooks/hook-after-create.sql
index 6db3093..56492bb 100644
--- a/regress/hooks/hook-after-create.sql
+++ b/regress/hooks/hook-after-create.sql
@@ -24,7 +24,6 @@ BEGIN
END;
-DROP EVENT TRIGGER IF EXISTS trg_autovac_disable;
CREATE EVENT TRIGGER trg_autovac_disable ON ddl_command_end
WHEN TAG IN ('CREATE TABLE','CREATE TABLE AS')
EXECUTE PROCEDURE trg_test_disable_table_autovacuum();
diff --git a/regress/hooks/hook-before-uninstall.sql b/regress/hooks/hook-before-uninstall.sql
index 0000000..63b939e
--- /dev/null
+++ b/regress/hooks/hook-before-uninstall.sql
@@ -0,0 +1,2 @@
+DROP EVENT TRIGGER IF EXISTS trg_autovac_disable;
+DROP FUNCTION IF EXISTS trg_test_disable_table_autovacuum();
commit b73546d16cfc3dbb1427c2f4def1c92e9099b420
Date: Thu May 6 01:45:16 2021 +0300
moved the disable_autovacuum.sql under regress/hooks/hook-after-create.sql
index e8c8102..a9e7902 100644
@@ -22,7 +22,8 @@ current_dir := $(dir $(abspath $(lastword $(MAKEFILE_LIST))))
- --after-upgrade-script $(topsrcdir)/regress/hooks/hook-after-upgrade.sql
+ --after-upgrade-script $(topsrcdir)/regress/hooks/hook-after-upgrade.sql \
TESTS += \
diff --git a/regress/disable_autovacuum.sql b/regress/hooks/hook-after-create.sql
similarity index 100%
rename from regress/disable_autovacuum.sql
rename to regress/hooks/hook-after-create.sql
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 1b23e12..938439c 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -1267,9 +1267,7 @@ sub count_postgis_objects
sub create_db
my $createcmd = "createdb --encoding=UTF-8 --template=template0 --lc-collate=C $DB > $REGRESS_LOG";
- my $rv = system($createcmd);
- system("psql -d $DB -f disable_autovacuum.sql ");
- return $rv;
+ return system($createcmd);
sub create_spatial
commit b984995719470caa24402ebe992e6753126c23e0
Date: Wed May 5 22:09:07 2021 +0300
test if -Z works properly by checking pg system catalogs
diff --git a/regress/disable_autovacuum.sql b/regress/disable_autovacuum.sql
index 0000000..6db3093
--- /dev/null
+++ b/regress/disable_autovacuum.sql
@@ -0,0 +1,30 @@
+-- Disable autovacuum on the tables created as part of the test suite
+-- to make sure autovacuum does not run VACUUM or ANALYZE on the tables
+-- created by the test suite.
+-- Some of the tests are designed with the assumption that ANALYZE will
+-- only be run explicitly, and not from an external source like autovacuum.
+CREATE OR REPLACE FUNCTION trg_test_disable_table_autovacuum()
+RETURNS event_trigger
+LANGUAGE plpgsql
+AS $$
+DECLARE
+ obj record;
+BEGIN
+ FOR obj IN SELECT * FROM pg_event_trigger_ddl_commands() WHERE command_tag in ('CREATE TABLE','CREATE TABLE AS')
+ LOOP
+ IF obj.object_identity = 'public.spatial_ref_sys' THEN
+ CONTINUE;
+ END IF;
+ EXECUTE format('ALTER TABLE %s SET (autovacuum_enabled = false);',obj.object_identity);
+ END LOOP;
+END;
+CREATE EVENT TRIGGER trg_autovac_disable ON ddl_command_end
+WHEN TAG IN ('CREATE TABLE','CREATE TABLE AS')
+EXECUTE PROCEDURE trg_test_disable_table_autovacuum();
index 0000000..fd98c18
--- /dev/null
+++ b/regress/loader/TestSkipANALYZE-post.sql
@@ -0,0 +1,3 @@
+DROP TABLE IF EXISTS pgreg.loadedshp;
+--DELETE FROM geometry_columns WHERE f_table_schema='pgreg';
+DROP SCHEMA pgreg;
index 0000000..6a860c3
--- /dev/null
+++ b/regress/loader/TestSkipANALYZE-pre.sql
@@ -0,0 +1 @@
+CREATE SCHEMA pgreg;
diff --git a/regress/loader/TestSkipANALYZE.dbf b/regress/loader/TestSkipANALYZE.dbf
Binary files /dev/null and b/regress/loader/TestSkipANALYZE.dbf differ
index 0000000..0bce557
--- /dev/null
@@ -0,0 +1,2 @@
+# Test -Z skips ANALYZE
+-Z -g the_geom {regdir}/loader/TestSkipANALYZE pgreg.loadedshp
diff --git a/regress/loader/TestSkipANALYZE.select.expected b/regress/loader/TestSkipANALYZE.select.expected
index 0000000..573541a
--- /dev/null
+++ b/regress/loader/TestSkipANALYZE.select.expected
@@ -0,0 +1 @@
+0
index 0000000..19ec0aa
--- /dev/null
@@ -0,0 +1,5 @@
+-- Checks if the table pgreg.loadedshp was analyzed by
+-- querying the respective PostgreSQL system catalog
+FROM pg_statistic
+WHERE starelid = 'pgreg.loadedshp'::regclass AND stanumbers1 IS NOT NULL;
diff --git a/regress/loader/TestSkipANALYZE.shp b/regress/loader/TestSkipANALYZE.shp
Binary files /dev/null and b/regress/loader/TestSkipANALYZE.shp differ
diff --git a/regress/loader/TestSkipANALYZE.shx b/regress/loader/TestSkipANALYZE.shx
Binary files /dev/null and b/regress/loader/TestSkipANALYZE.shx differ
index 85031b7..757edc6 100644
@@ -37,4 +37,5 @@ TESTS += \
$(topsrcdir)/regress/loader/ReprojectPtsGeogD \
- $(topsrcdir)/regress/loader/mfile
+ $(topsrcdir)/regress/loader/mfile \
index 938439c..1b23e12 100755
@@ -1267,7 +1267,9 @@ sub count_postgis_objects
sub create_db
- return system($createcmd);
+ my $rv = system($createcmd);
+ system("psql -d $DB -f disable_autovacuum.sql ");
+ return $rv;
sub create_spatial
Summary of changes:
regress/core/tests.mk.in | 4 ++-
regress/hooks/hook-after-create.sql | 29 +++++++++++++++++++++
regress/hooks/hook-before-uninstall.sql | 2 ++
regress/loader/{TSTPolygon.dbf => TestANALYZE.dbf} | Bin
regress/loader/TestANALYZE.opts | 2 ++
regress/loader/TestANALYZE.select.expected | 1 +
regress/loader/TestANALYZE.select.sql | 4 +++
.../{PointWithSchema.shp => TestANALYZE.shp} | Bin
.../{PointWithSchema.shx => TestANALYZE.shx} | Bin
.../loader/{TSTPolygon.dbf => TestSkipANALYZE.dbf} | Bin
regress/loader/TestSkipANALYZE.opts | 2 ++
regress/loader/TestSkipANALYZE.select.expected | 1 +
regress/loader/TestSkipANALYZE.select.sql | 5 ++++
.../{PointWithSchema.shp => TestSkipANALYZE.shp} | Bin
.../{PointWithSchema.shx => TestSkipANALYZE.shx} | Bin
regress/loader/tests.mk | 4 ++-
16 files changed, 52 insertions(+), 2 deletions(-)
create mode 100644 regress/hooks/hook-after-create.sql
create mode 100644 regress/hooks/hook-before-uninstall.sql
copy regress/loader/{TSTPolygon.dbf => TestANALYZE.dbf} (100%)
create mode 100644 regress/loader/TestANALYZE.opts
create mode 100644 regress/loader/TestANALYZE.select.expected
create mode 100644 regress/loader/TestANALYZE.select.sql
copy regress/loader/{PointWithSchema.shp => TestANALYZE.shp} (100%)
copy regress/loader/{PointWithSchema.shx => TestANALYZE.shx} (100%)
copy regress/loader/{TSTPolygon.dbf => TestSkipANALYZE.dbf} (100%)
create mode 100644 regress/loader/TestSkipANALYZE.opts
create mode 100644 regress/loader/TestSkipANALYZE.select.expected
create mode 100644 regress/loader/TestSkipANALYZE.select.sql
copy regress/loader/{PointWithSchema.shp => TestSkipANALYZE.shp} (100%)
copy regress/loader/{PointWithSchema.shx => TestSkipANALYZE.shx} (100%)
hooks/post-receive
