[postgis-tickets] [PostGIS] #4911: Capturing coordinate epoch in database
PostGIS trac at osgeo.org
Fri May 14 10:06:53 PDT 2021
  Reporter:  rouault      |      Owner:  pramsey
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:  PostGIS 3.1.2
 Component:  postgis      |    Version:
Resolution:               |   Keywords:
Comment (by mdavis):
 Another option:
 * Store the epoch as a column beside the geometry column.  This could be
 an epoch number, or a Postgres timestamp.  Add an option to the
 `ST_Transform` function to accept an epoch modifier for each CRS.
 This is a low-bar option, which might be a good first step to providing
 more "baked-in" support for epochs.  It also aligns with existing models
 for storing temporal information about spatial data.
 The modification to `ST_Transform` seems like a good idea regardless.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4911#comment:7>
