[postgis-tickets] [PostGIS] #4890: ST_Transform large slow down from upgrade to 3.1.1 from 2.4
trac at osgeo.org
Mon May 17 16:09:18 PDT 2021
Reporter: SAbernethy | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.2
Component: postgis | Version: 3.1.x
Resolution: | Keywords:
Comment (by robe):
Test from David Boone that exercises the issue:
I’ve been fighting a performance issue for a while with some installs of
Postgres/PostGIS, and finally managed to create a small reproducible test
case. It shows a simple query’s execution time going from 10 to 400 ms
when upgrading PostGIS from 2.5 -> 3.1. This may be the same issue or
related to: https://trac.osgeo.org/postgis/ticket/4890
DROP EXTENSION IF EXISTS postgis CASCADE;
DROP TABLE IF EXISTS points;
CREATE EXTENSION postgis;
CREATE TABLE points AS SELECT * FROM (VALUES ('SRID=4326;POINT(-124.9921
49.6851)'::geometry), ('SRID=4326;POINT(-119.4032 50.0305)'::geometry),
('SRID=4326;POINT(-122.799 49.1671)'::geometry),
('SRID=4326;POINT(-122.3379 49.0597)'::geometry),
('SRID=4326;POINT(-123.1264 49.2671)'::geometry),
('SRID=4326;POINT(-122.7132 49.0519)'::geometry),
('SRID=4326;POINT(-124.3475 49.3042)'::geometry),
('SRID=4326;POINT(-119.389 49.8891)'::geometry),
('SRID=4326;POINT(-123.126 49.281)'::geometry),
('SRID=4326;POINT(-122.6606 49.1134)'::geometry),
('SRID=4326;POINT(-124.3233 49.312)'::geometry),
('SRID=4326;POINT(-124.0478 49.2397)'::geometry),
('SRID=4326;POINT(-119.2683 50.266)'::geometry),
('SRID=4326;POINT(-121.9705 49.081)'::geometry),
('SRID=4326;POINT(-123.8854 49.482)'::geometry),
('SRID=4326;POINT(-123.1528 49.77)'::geometry),
('SRID=4326;POINT(-120.8051 50.488)'::geometry),
('SRID=4326;POINT(-122.6403 49.1652)'::geometry),
('SRID=4326;POINT(-122.7717 49.2433)'::geometry),
('SRID=4326;POINT(-121.9587 49.1661)'::geometry))
p(g);
CREATE INDEX ON points USING gist(g);
CREATE OR REPLACE FUNCTION get_closest(p geometry(POINT)) RETURNS
geometry(POINT) AS $$
SELECT g FROM points ORDER BY st_transform(p, 3005) <->
st_transform(points.g, 3005) LIMIT 1
STABLE
LANGUAGE SQL;
SELECT postgis_full_version();
EXPLAIN (ANALYZE) SELECT *, get_closest(g) FROM points ;
I hope this is useful, please feel free to add it to the issue tracker or
any other place / person it can be of use. Please let me know if I can
help further or contribute in any way.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4890#comment:14>
