[postgis-tickets] [PostGIS] #4916: st_asgeobuf() with WINDOW PARTITION crashes server
trac at osgeo.org
Tue May 18 05:28:55 PDT 2021
Reporter: Robins | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.1.2
Component: postgis | Version: 3.0.x
Keywords: st_asgeobuf |
When I use `st_asgeobuf()` with WINDOW PARTITION it crashes server. Here
is a simple example.
$ psql
psql (13beta2, server 13.3)
Type "help" for help.
regression=> \x
Expanded display is on.
regression=> \dx postgis
List of installed extensions
-[ RECORD 1
Name | postgis
Version | 3.0.3
Schema | public
Description | PostGIS geometry, geography, and raster spatial types and
functions
regression=> \x
Expanded display is off.
regression=> SELECT public.st_asgeobuf(NULL::pg_class, version()) over
(partition by RANDOM());
server closed the connection unexpectedly
This probably means the server terminated abnormally
before or while processing the request.
The connection to the server was lost. Attempting reset: Failed.
!?> \q
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4916>
