[postgis-tickets] [PostGIS] #4890: ST_Transform large slow down from upgrade to 3.1.1 from 2.4
trac at osgeo.org
Thu May 20 06:06:49 PDT 2021
Reporter: SAbernethy | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.1.2
Component: postgis | Version: 3.1.x
Resolution: fixed | Keywords:
Comment (by robe):
@icehong why do you think that?
The issue is that the Proj new API takes much longer to cache. Like a 10
to 100 times longer than Proj 5.2. There is nothing we can do about that.
The tests might be worded a little badly.
What the regress_proj_cache_overflow is testing is rotating thru like 20
SRIDs to make sure we don't crash the cache. So it's more of a crasher
test than a speed test. So essentially to cost in new Proj of caching the
20 or so spatial refs overshadows it's use. It is what it is.
As far as the proj_basic - it's more or less the same story. I was
thinking I should add more proj calls of the SRIDs loaded so that the
caching does not overshadow the actual use. It's like only 10 calls in
there with 3 different projs right now.
Question to @pramsey -- I assume we aren't caching proj in shared mem
right (or are we) and it's only cached at the session level now? That's
the only thing I can think would help here, but maybe we are doing that
already and it's just cause the tests are using different projs that we
don't see the effect.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4890#comment:20>
