[postgis-tickets] [PostGIS] #4922: Axis order wrong in PostGIS 3.1.2 (may releates to #4842)
trac at osgeo.org
Wed May 26 06:11:05 PDT 2021
Reporter: tjay | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS PostgreSQL
Component: postgis | Version: 3.1.x
Keywords: |
Since 3.1.2 ST_Transform swaps the coordinates of EPSG:31466 on output. In
all cases Proj uses proj-datumgrid-1.8.zip.
cs2cs does not show these swaps...
Postgis 3.1.2 and Proj 8.0.1
POSTGIS="3.1.2 cbe925d" [EXTENSION] PGSQL="120" GEOS="3.9.1-CAPI-1.14.2"
SFCGAL="1.3.8" PROJ="8.0.1" GDAL="GDAL 3.2.3, released 2021/04/27"
LIBXML="2.9.1" LIBJSON="0.11"
TOPOLOGY RASTER
Unexpected result
test=# select
ST_AsEWKT(ST_Transform(ST_GeomFromEWKT('SRID=25832;POINT(343806.1686
5676555.6896)'),31466),4);
st_asewkt
SRID=31466;POINT(5676286.92 2553378.32)
(1 Zeile)
Postgis 3.1.2 and Proj 7.2.1
SFCGAL="1.3.8" PROJ="7.2.1" GDAL="GDAL 3.2.3, released 2021/04/27"
TOPOLOGY RASTER
Unexpected result
test=# select
st_asewkt
(1 Zeile)
Postgis 3.1.1 and Proj 7.2.1
POSTGIS="3.1.1 aaf4c79" [EXTENSION] PGSQL="120" GEOS="3.9.1-CAPI-1.14.2"
LIBXML="2.9.1"
LIBJSON="0.11" TOPOLOGY RASTER
Expected result
select
st_asewkt
SRID=31466;POINT(2553378.32 5676286.92)
(1 Zeile)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4922>
