[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-194-g0e5d871
Thu May 27 10:08:36 PDT 2021
the project "PostGIS".
       via  0e5d871404e2cb076ab987a58c246ca6f784ebf2 (commit)
      from  c815ecd7d2d59fc362f39c9adfd99b01d12aea89 (commit)
revisions in full, below.
commit 0e5d871404e2cb076ab987a58c246ca6f784ebf2
Author: Martin Davis <mtnclimb at gmail.com>
Date:   Thu May 27 10:08:30 2021 -0700
    Improve doc for ST_LineMerge
diff --git a/doc/reference_editor.xml b/doc/reference_editor.xml
index 793003d..742b81b 100644
--- a/doc/reference_editor.xml
+++ b/doc/reference_editor.xml
@@ -1090,73 +1090,6 @@ GEOMETRYCOLLECTION(
 		</refsection>
 	</refentry>
-	<refentry id="ST_LineMerge">
-		<refnamediv>
-			<refname>ST_LineMerge</refname>
-			<refpurpose>Return a (set of) LineString(s) formed by sewing together
-			a MULTILINESTRING.</refpurpose>
-		</refnamediv>
-		<refsynopsisdiv>
-			<funcsynopsis>
-			  <funcprototype>
-				<funcdef>geometry <function>ST_LineMerge</function></funcdef>
-				<paramdef><type>geometry </type> <parameter>amultilinestring</parameter></paramdef>
-			  </funcprototype>
-			</funcsynopsis>
-		</refsynopsisdiv>
-		<refsection>
-			<title>Description</title>
-			<para>Returns a (set of) LineString(s) formed by sewing together
-			the constituent line work of a MULTILINESTRING. </para>
-			<note><para>Only use with MULTILINESTRING/LINESTRINGs. If you feed a polygon or geometry collection into this function, it
-			will return an empty GEOMETRYCOLLECTION</para></note>
-			<para>Performed by the GEOS module.</para>
-			<para>Availability: 1.1.0</para>
-			<warning><para>Will strip the M dimension.</para></warning>
-		</refsection>
-		<refsection>
-			<title>Examples</title>
-			<programlisting>SELECT ST_AsText(ST_LineMerge(
-ST_GeomFromText('MULTILINESTRING((-29 -27,-30 -29.7,-36 -31,-45 -33),(-45 -33,-46 -32))')
-st_astext
-LINESTRING(-29 -27,-30 -29.7,-36 -31,-45 -33,-46 -32)
-(1 row)
---If can't be merged - original MULTILINESTRING is returned
-SELECT ST_AsText(ST_LineMerge(
-ST_GeomFromText('MULTILINESTRING((-29 -27,-30 -29.7,-36 -31,-45 -33),(-45.2 -33.2,-46 -32))')
-st_astext
-MULTILINESTRING((-45.2 -33.2,-46 -32),(-29 -27,-30 -29.7,-36 -31,-45 -33))
--- example with Z dimension
-ST_GeomFromText('MULTILINESTRING((-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 6), (-29 -27 12,-30 -29.7 5), (-45 -33 1,-46 -32 11))')
-st_astext
-LINESTRING Z (-30 -29.7 5,-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 1,-46 -32 11)
-(1 row)
-			</programlisting>
-		</refsection>
-		<refsection>
-			<title>See Also</title>
-			<para><xref linkend="ST_Segmentize" />, <xref linkend="ST_LineSubstring" /></para>
-		</refsection>
-	</refentry>
     <refentry id="ST_LineToCurve">
       <refnamediv>
         <refname>ST_LineToCurve</refname>
diff --git a/doc/reference_processing.xml b/doc/reference_processing.xml
index 928f968..1a0ab6b 100644
--- a/doc/reference_processing.xml
+++ b/doc/reference_processing.xml
@@ -1285,6 +1285,75 @@ FROM test;
     </refentry>
+	<refentry id="ST_LineMerge">
+		<refnamediv>
+			<refname>ST_LineMerge</refname>
+			<refpurpose>Return the lines formed by sewing together
+			a MultiLineString.</refpurpose>
+		</refnamediv>
+		<refsynopsisdiv>
+			<funcsynopsis>
+			  <funcprototype>
+				<funcdef>geometry <function>ST_LineMerge</function></funcdef>
+				<paramdef><type>geometry </type> <parameter>amultilinestring</parameter></paramdef>
+			  </funcprototype>
+			</funcsynopsis>
+		</refsynopsisdiv>
+		<refsection>
+			<title>Description</title>
+			<para>Returns a LineString or MultiLineString formed by joining together
+			the constituent line work of a MultiLineString.
+            Lines are joined at their endpoints at 2-way intersections.
+            Lines are not joined across intersections of 3-way or greater degree.
+            </para>
+			<note><para>Only use with MultiLineString/LineStrings. If you pass a Plygon or GeometryCollection into this function, it
+			returns an empty GeometryCollection</para></note>
+			<para>Performed by the GEOS module.</para>
+			<para>Availability: 1.1.0</para>
+			<warning><para>This function will strip the M dimension.</para></warning>
+		</refsection>
+		<refsection>
+			<title>Examples</title>
+			<programlisting>SELECT ST_AsText(ST_LineMerge(
+'MULTILINESTRING((-29 -27,-30 -29.7,-36 -31,-45 -33),(-45 -33,-46 -32))'
+st_astext
+LINESTRING(-29 -27,-30 -29.7,-36 -31,-45 -33,-46 -32)
+</programlisting>
+<para>If merging is not possible due to non-touching lines,
+the original MultiLineString is returned.</para>
+<programlisting>
+SELECT ST_AsText(ST_LineMerge(
+'MULTILINESTRING((-29 -27,-30 -29.7,-36 -31,-45 -33),(-45.2 -33.2,-46 -32))'
+st_astext
+MULTILINESTRING((-45.2 -33.2,-46 -32),(-29 -27,-30 -29.7,-36 -31,-45 -33))
+</programlisting>
+<para>Example showing Z-dimension handling.</para>
+<programlisting>
+      'MULTILINESTRING((-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 6), (-29 -27 12,-30 -29.7 5), (-45 -33 1,-46 -32 11))'
+st_astext
+LINESTRING Z (-30 -29.7 5,-29 -27 11,-30 -29.7 10,-36 -31 5,-45 -33 1,-46 -32 11)
+</programlisting>
+		</refsection>
+		<refsection>
+			<title>See Also</title>
+			<para><xref linkend="ST_Segmentize" />, <xref linkend="ST_LineSubstring" /></para>
+		</refsection>
+	</refentry>
     <refentry id="ST_MaximumInscribedCircle">
       <refnamediv>
         <refname>ST_MaximumInscribedCircle</refname>
Summary of changes:
 doc/reference_editor.xml     | 67 ------------------------------------------
 doc/reference_processing.xml | 69 ++++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 69 insertions(+), 67 deletions(-)
hooks/post-receive
