[postgis-tickets] [PostGIS] #5014: flatgeobuf test failure
trac at osgeo.org
Sat Nov 6 19:15:02 PDT 2021
Reporter: Bas Couwenberg | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.2.0
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by robe):
thanks Bas. I was able to replicate with your setup and get a back trace
#0 0x00007f9c0c34acd1 in ?? () from /lib/x86_64-linux-gnu/libc.so.6
#1 0x00007f9c00bc7ec7 in memcpy (__len=<optimized out>, __src=<optimized
out>, __dest=<optimized out>) at /usr/include/x86_64-linux-
gnu/bits/string_fortified.h:29
#2 flatbuffers::vector_downward::push (num=<optimized out>,
bytes=<optimized out>, this=0x7ffe4fe29440) at
include/flatbuffers/flatbuffers.h:1031
#3 flatbuffers::vector_downward::push (num=<optimized out>,
include/flatbuffers/flatbuffers.h:1030
#4 flatbuffers::FlatBufferBuilder::PushBytes (size=<optimized out>,
include/flatbuffers/flatbuffers.h:1347
#5 flatbuffers::FlatBufferBuilder::CreateVector<double> (len=<optimized
out>, v=<optimized out>, this=<optimized out>) at
include/flatbuffers/flatbuffers.h:1712
#6 flatbuffers::FlatBufferBuilder::CreateVector<double> (v=..., v=...,
this=0x7ffe4fe29440) at include/flatbuffers/flatbuffers.h:1740
#7 FlatGeobuf::CreateHeaderDirect (metadata=0x0, description=0x0,
title=0x0, crs=..., index_node_size=16, features_count=1,
columns=<optimized out>, has_tm=false, has_t=false, has_m=false,
has_z=false, geometry_type=<optimized out>, envelope=<optimized out>,
name=<optimized out>, _fbb=...) at
./deps/flatgeobuf/header_generated.h:660
#8 flatgeobuf_encode_header (ctx=0x56325fab2d38) at
./deps/flatgeobuf/flatgeobuf_c.cpp:87
#9 0x00007f9c00bc9268 in flatgeobuf_create_index (ctx=<optimized out>) at
./deps/flatgeobuf/flatgeobuf_c.cpp:195
#10 0x00007f9c00ba8591 in flatgeobuf_agg_finalfn (ctx=0x56325fab2ce8) at
./postgis/flatgeobuf.c:558
#11 0x000056325e629e70 in ?? ()
#12 0x000056325e62ae9e in ?? ()
#13 0x000056325e62bf50 in ?? ()
#14 0x000056325e649988 in ExecSetParamPlan ()
#15 0x000056325e616192 in ?? ()
#16 0x000056325e6213bd in ?? ()
#17 0x000056325e621d44 in ExecMakeTableFunctionResult ()
#18 0x000056325e6328c1 in ?? ()
#19 0x000056325e622430 in ExecScan ()
#20 0x000056325e61973d in standard_ExecutorRun ()
#21 0x000056325e79211b in ?? ()
#22 0x000056325e7935ab in PortalRun ()
#23 0x000056325e78f6ed in ?? ()
#24 0x000056325e79162c in PostgresMain ()
#25 0x000056325e70f618 in ?? ()
#26 0x000056325e710484 in PostmasterMain ()
#27 0x000056325e485e99 in main ()
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5014#comment:6>
