[postgis-tickets] [PostGIS] #5020: st_3dintersection causing core dump
trac at osgeo.org
Tue Nov 16 20:02:21 PST 2021
Reporter: cege | Owner: robe
Type: defect | Status: closed
Priority: high | Milestone: PostGIS SFCGAL
Component: sfcgal | Version: 3.1.x
Resolution: worksforme | Keywords: st_3dintersection
Changes (by robe):
* status: new => closed
* resolution: => worksforme
* milestone: PostGIS 3.1.5 => PostGIS SFCGAL
Comment:
Okay I just tried this on my system and I don't get a core-dump. So I
suspect this issue is fixed in newer SFCGAL.
My install is
POSTGIS="3.2.0dev 3.2.0beta1-18-g085cc7f04" [EXTENSION] PGSQL="140"
GEOS="3.10.0-CAPI-1.16.0" PROJ="7.2.1" GDAL="GDAL 3.3.3, released
2021/10/25" LIBXML="2.9.9" LIBJSON="0.12"
LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)" TOPOLOGY RASTER
Although it's puzzling my database doesn't show SFCGAL , but I'm
definitely using it becuase if I do
DROP EXTENSION postgis_sfcgal;
and rerun I get ST_3DIntersection does not exist. I know I am running
SFCGAL 1.4.0 with CGAL 5.3 since I compiled it myself.
Here is the script I am using, mild revision to use newer syntax.
create table public.buildings (
building_id serial,
building_name character varying (200) not null,
location geometry(geometryZ)
CREATE EXTENSION IF NOT EXISTS postgis_sfcgal;
-- insert two rows of data
insert into public.buildings
(building_name, location)
values
('Building 1',st_extrude(st_geomfromtext('POLYGON((300 200 0, 300 2200 0,
1600 2200 0, 1600 200 0, 300 200 0))',27700),0,0,600));
/* Building 2 */
(building_name,location)
values
('Building 2', st_extrude(st_geomfromtext('POLYGON ((2000 1200 0, 2000
2700 0, 2800 2700 0, 2800 1200 0, 2000 1200 0))',27700),0,0,600)
select a.building_id, b.building_id,
ST_AsText(st_3dintersection(a.location, b.location))::varchar(75)
from
public.buildings a, public.buildings b;
Output is:
building_id | building_id | st_astext
1 | 1 | POLYHEDRALSURFACE Z (((300 200 0,300 2200
0,1600 2200 0,300 200 0)),((1600
1 | 2 | GEOMETRYCOLLECTION EMPTY
2 | 1 | GEOMETRYCOLLECTION EMPTY
2 | 2 | POLYHEDRALSURFACE Z (((2000 1200 0,2000 2700
0,2800 2700 0,2000 1200 0)),((
On my sysem running PostGIS 3.1.4 with SFCGAL 1.4.0 works as well
PostgreSQL 14.1, compiled by Visual C++ build 1914, 64-bitPOSTGIS="3.1.4
3.1.4" [EXTENSION] PGSQL="140" GEOS="3.9.1-CAPI-1.14.1" SFCGAL="1.4.0"
PROJ="7.1.1" GDAL="GDAL 3.2.3, released 2021/04/27" LIBXML="2.9.9"
LIBJSON="0.12" LIBPROTOBUF="1.2.1" WAGYU="0.5.0 (Internal)" RASTER
So if you can I'd suggest you try upgrading to a newer SFCGAL.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5020#comment:3>
