[postgis-tickets] [PostGIS] #5020: st_3dintersection causing core dump
trac at osgeo.org
Thu Nov 25 14:22:26 PST 2021
Reporter: cege | Owner: robe
Type: defect | Status: closed
Priority: high | Milestone: PostGIS SFCGAL
Component: sfcgal | Version: 3.1.x
Resolution: worksforme | Keywords: st_3dintersection
Comment (by cege):
Hi again
As suggested, I managed to install SFCGAL 1.4.0 and CGAL 5.3 on my server
and make install etc. However, I don't want to update PostGIS as this is
a live server. Is there an easy way to change the SFCGAL version without
doing a full PostGIS update, so that I can test that st_3dintersection
issue is resolved ? I've seen Postgis_extensions_upgrade but can't find
where I configure PostGIS to detect the new version of sfcgal (or is it
simply a question of replacing the library file in the same location as
before and the upgrade process will handle the rest?)
thanks
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5020#comment:4>
