[postgis-tickets] [PostGIS] #5020: st_3dintersection causing core dump
trac at osgeo.org
Thu Nov 25 16:17:23 PST 2021
Reporter: cege | Owner: robe
Type: defect | Status: closed
Priority: high | Milestone: PostGIS SFCGAL
Component: sfcgal | Version: 3.1.x
Resolution: worksforme | Keywords: st_3dintersection
Comment (by robe):
Which version of PostGIS are you running? If you are running postgis 3.1
then the postgis-sfcgal is a separate lib file. So it wouldn't impact
postgis proper. If it's 3.0 or lower then it's linked into the main
postgis-3.so or postgis-2.5.
You shouldn't need to touch PostGIS as I think all the sfcgal functions
are delegated to the sfcgal library.
I would check what ldd returns:
here is for example an output of an old ubuntu I have
cd /usr/lib/postgresql/11/lib
ldd postgis-2.5.so
Should output something like
linux-vdso.so.1 (0x00007fffad1ec000)
liblwgeom-2.5.so.0 => /usr/lib/liblwgeom-2.5.so.0
(0x00007f564b0ea000)
libgeos_c.so.1 => /usr/lib/x86_64-linux-gnu/libgeos_c.so.1
(0x00007f564aeb9000)
libproj.so.12 => /usr/lib/x86_64-linux-gnu/libproj.so.12
(0x00007f564ac50000)
libjson-c.so.3 => /lib/x86_64-linux-gnu/libjson-c.so.3
(0x00007f564aa45000)
libprotobuf-c.so.1 => /usr/lib/x86_64-linux-gnu/libprotobuf-c.so.1
(0x00007f564a83c000)
libxml2.so.2 => /usr/lib/x86_64-linux-gnu/libxml2.so.2
(0x00007f564a47b000)
libSFCGAL.so.1 => /usr/lib/x86_64-linux-gnu/libSFCGAL.so.1
(0x00007f5649aad000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f56496bc000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f564931e000)
libgeos-3.7.1.so => /usr/lib/x86_64-linux-gnu/libgeos-3.7.1.so
(0x00007f5648f7b000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6
(0x00007f5648bf2000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1
(0x00007f56489da000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0
(0x00007f56487bb000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2
(0x00007f56485b7000)
libicuuc.so.60 => /usr/lib/x86_64-linux-gnu/libicuuc.so.60
(0x00007f56481ff000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f5647fe2000)
liblzma.so.5 => /lib/x86_64-linux-gnu/liblzma.so.5
(0x00007f5647dbc000)
libCGAL_Core.so.13 => /usr/lib/x86_64-linux-gnu/libCGAL_Core.so.13
(0x00007f5647b2c000)
libboost_thread.so.1.65.1 => /usr/lib/x86_64-linux-
gnu/libboost_thread.so.1.65.1 (0x00007f5647907000)
libboost_serialization.so.1.65.1 => /usr/lib/x86_64-linux-
gnu/libboost_serialization.so.1.65.1 (0x00007f56476c9000)
libCGAL.so.13 => /usr/lib/x86_64-linux-gnu/libCGAL.so.13
(0x00007f56474aa000)
libgmp.so.10 => /usr/lib/x86_64-linux-gnu/libgmp.so.10
(0x00007f5647229000)
libgmpxx.so.4 => /usr/lib/x86_64-linux-gnu/libgmpxx.so.4
(0x00007f5647023000)
libmpfr.so.6 => /usr/lib/x86_64-linux-gnu/libmpfr.so.6
(0x00007f5646da3000)
/lib64/ld-linux-x86-64.so.2 (0x00007f564b5dd000)
libicudata.so.60 => /usr/lib/x86_64-linux-gnu/libicudata.so.60
(0x00007f56451fa000)
libboost_system.so.1.65.1 => /usr/lib/x86_64-linux-
gnu/libboost_system.so.1.65.1 (0x00007f5644ff5000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1
(0x00007f5644ded000)
Note the path of below so you want to replace /usr/lib/x86_64-linux-
gnu/libSFCGAL.so.1 (or whatever that path is with your new one)
If you are running postgis-3.1, then you'll probably need to check instead
ldd postgis_sfcgal-3.so
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5020#comment:5>
