[postgis-tickets] [PostGIS] #5020: st_3dintersection causing core dump
PostGIS trac at osgeo.org
Sat Nov 27 01:23:17 PST 2021
  Reporter:  cege        |      Owner:  robe
      Type:  defect      |     Status:  closed
  Priority:  high        |  Milestone:  PostGIS SFCGAL
 Component:  sfcgal      |    Version:  3.1.x
Resolution:  worksforme  |   Keywords:  st_3dintersection
Comment (by cege):
 Hi robe
 That worked - I simply swapped out the libSFCGAL.so file for the newer
 one, and then ran select postgis_extensions_upgrade()
 st_3dintersection is now working fine, many thanks!
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5020#comment:6>
