[postgis-tickets] [PostGIS] #5025: Inconsistent behavior with ST_Within across versions
trac at osgeo.org
Thu Nov 25 01:10:17 PST 2021
Reporter: byrman | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS PostgreSQL
Component: postgis | Version: 3.1.x
Keywords: |
I noticed inconsistent behavior with ST_Within across different
PostgreSQL-PostGIS versions. To demonstrate the issue, I used
postgis/postgis Docker images and a minimal example.
=== Steps to reproduce the problem
-- Create table "a" having both a 2D and 3D spatial index on its geometry
field.
CREATE TABLE a (id serial, geom geometry(PointZ, 4326) NOT NULL);
CREATE INDEX a_2d_idx ON a USING GIST(geom);
CREATE INDEX a_3d_idx ON a USING GIST(geom gist_geometry_ops_nd);
-- Create table "b" having both a 2D and 3D spatial index on its geometry
field.
CREATE TABLE b (id serial, geom geometry(PolygonZ, 4326) NOT NULL);
CREATE INDEX b_2d_idx ON b USING GIST (geom);
CREATE INDEX b_3d_idx ON b USING GIST (geom gist_geometry_ops_nd);
-- Insert a polygon (z=0) into table "b".
INSERT INTO b (geom) SELECT ST_Force3D(ST_MakeEnvelope(-1, -1, 1, 1,
4326));
-- Generate 100 pseudo-random points (z=0) which lie within the polygon
and insert them into table "a".
INSERT INTO a (geom) SELECT ST_Force3D((ST_Dump(ST_GeneratePoints((SELECT
geom FROM b), 100))).geom);
-- Change the z coordinate of half of the points from 0 into 1.
UPDATE a SET geom=ST_SetSRID(ST_MakePoint(ST_x(geom), ST_y(geom), 1),
4326) WHERE MOD(id, 2)=0;
-- Ensure up-to-date statistics.
VACUUM ANALYZE;
-- Finally, run the query below.
SELECT COUNT(*) FROM a, b WHERE ST_Within(a.geom, b.geom);
=== Results
postgis/postgis:11-2.5-alpine: 100
postgis/postgis:11-3.0-alpine: 100
postgis/postgis:11-3.1-alpine: 100
postgis/postgis:12-2.5-alpine: 100
postgis/postgis:12-3.0-alpine: 50
postgis/postgis:12-3.1-alpine: 50
postgis/postgis:13-3.0-alpine: 50
postgis/postgis:13-3.1-alpine: 50
postgis/postgis:14-3.1-alpine: 50
1. Clearly, 50 and 100 is the result of a 3D and 2D calculation,
respectively. For a user, however, it's unclear what calculation to
expect. Documentation on ST_Within does not help.
2. Even more confusing is that the result also depends on the indexes
present. For example, dropping index a_3d_idx in 14-3.1-alpine, changes
the result from 50 into 100. I expect the presence of an index to affect
the performance of a query, not its result.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5025>
