[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta1-30-gb24d7125a
git at osgeo.org
git at osgeo.org
Thu Nov 25 02:02:46 PST 2021
the project "PostGIS".
via b24d7125a3b9de291bcc46d6d92721a66702f71c (commit)
via f523c156430076330ba62ec11f65fee195a184b0 (commit)
via 10d9f092f728d573cf7092e1a5c2cf04e901f915 (commit)
from 352fe49e965aed08819d7088df9d370714c1f5ec (commit)
revisions in full, below.
commit b24d7125a3b9de291bcc46d6d92721a66702f71c
Author: Björn Harrtell <bjorn at wololo.org>
Date: Thu Nov 25 10:22:18 2021 +0100
Also construct and check with correct table structure
diff --git a/regress/core/flatgeobuf.sql b/regress/core/flatgeobuf.sql
index 7c26e93aa..15df3aaab 100644
--- a/regress/core/flatgeobuf.sql
+++ b/regress/core/flatgeobuf.sql
@@ -134,10 +134,21 @@ select 'A1', id, ST_AsText(geom), bool_1, int_1, int_2, smallint_1, bigint_1, fl
select '--- Exotic roundtrips ---';
--- 2D Point not first geometry
-select 'E1', id, ST_AsText(geom) from ST_FromFlatGeobuf(null::flatgeobuf_t1, (
- select ST_AsFlatGeobuf(q) fgb from (select true::boolean as bool_1, ST_MakePoint(1.1, 2.1)) q)
+-- 2D Point geometry at column index 2
+select ST_TableFromFlatGeobuf('public', 'flatgeobuf_e1', (select ST_AsFlatGeobuf(q) fgb from (select
+ true::boolean as bool_1,
+ ST_MakePoint(1.1, 2.1),
+ false::boolean as bool_2
+ ) q));
+select 'E1', id, bool_1, ST_AsText(geom), bool_2 from ST_FromFlatGeobuf(null::flatgeobuf_e1, (
+ select ST_AsFlatGeobuf(q) fgb from (select
+ ) q)
drop table if exists public.flatgeobuf_t1;
drop table if exists public.flatgeobuf_a1;
+drop table if exists public.flatgeobuf_e1;
diff --git a/regress/core/flatgeobuf_expected b/regress/core/flatgeobuf_expected
index b95cd5f31..bb17110b6 100644
--- a/regress/core/flatgeobuf_expected
+++ b/regress/core/flatgeobuf_expected
@@ -22,4 +22,4 @@ P1|1|POINT(3 4)
--- Attribute roundtrips ---
A1|0||t|1|2|3|4|1.2|1.3|2016-06-23 03:44:52.134125+00|hello
-E1|0|POINT(1.1 2.1)
+E1|0|t|POINT(1.1 2.1)|f
commit f523c156430076330ba62ec11f65fee195a184b0
Date: Thu Nov 25 10:14:51 2021 +0100
Fix inspect/encode order issue
diff --git a/postgis/flatgeobuf.c b/postgis/flatgeobuf.c
index 7704cdbf7..566e6cdca 100644
--- a/postgis/flatgeobuf.c
+++ b/postgis/flatgeobuf.c
@@ -66,7 +66,7 @@ static uint8_t get_column_type(Oid typoid) {
typoid);
-static void encode_header(struct flatgeobuf_agg_ctx *ctx)
+static void inspect_table(struct flatgeobuf_agg_ctx *ctx)
flatgeobuf_column *c;
flatgeobuf_column **columns;
@@ -77,7 +77,7 @@ static void encode_header(struct flatgeobuf_agg_ctx *ctx)
int natts = tupdesc->natts;
bool geom_found = false;
- POSTGIS_DEBUG(2, "calling encode_header");
+ POSTGIS_DEBUG(2, "calling inspect_table");
columns = palloc(sizeof(flatgeobuf_column *) * natts);
ctx->tupdesc = tupdesc;
@@ -91,13 +91,13 @@ static void encode_header(struct flatgeobuf_agg_ctx *ctx)
if (ctx->geom_name == NULL) {
if (!geom_found && typoid == postgis_oid(GEOMETRYOID)) {
ctx->geom_index = i;
- geom_found = 1;
+ geom_found = true;
continue;
} else {
if (!geom_found && strcmp(key, ctx->geom_name) == 0) {
- geom_found = 1;
continue;
@@ -114,8 +114,6 @@ static void encode_header(struct flatgeobuf_agg_ctx *ctx)
ctx->ctx->columns = columns;
ctx->ctx->columns_size = columns_size;
- flatgeobuf_encode_header(ctx->ctx);
// ensure properties has room for at least size
@@ -522,16 +520,18 @@ void flatgeobuf_agg_transfn(struct flatgeobuf_agg_ctx *ctx)
Datum datum;
GSERIALIZED *gs;
+ if (ctx->ctx->features_count == 0)
+ inspect_table(ctx);
datum = GetAttributeByNum(ctx->row, ctx->geom_index + 1, &isnull);
if (!isnull) {
gs = (GSERIALIZED *) PG_DETOAST_DATUM_COPY(datum);
lwgeom = lwgeom_from_gserialized(gs);
ctx->ctx->lwgeom = lwgeom;
- encode_header(ctx);
+ flatgeobuf_encode_header(ctx->ctx);
encode_properties(ctx);
if (ctx->ctx->create_index)
@@ -551,9 +551,8 @@ uint8_t *flatgeobuf_agg_finalfn(struct flatgeobuf_agg_ctx *ctx)
flatgeobuf_agg_ctx_init(NULL, false);
// header only result
if (ctx->ctx->features_count == 0) {
- else if (ctx->ctx->create_index) {
+ } else if (ctx->ctx->create_index) {
ctx->ctx->index_node_size = 16;
flatgeobuf_create_index(ctx->ctx);
commit 10d9f092f728d573cf7092e1a5c2cf04e901f915
Date: Thu Nov 25 09:57:42 2021 +0100
Add reproduction test
index e324f8080..7c26e93aa 100644
@@ -133,5 +133,11 @@ select 'A1', id, ST_AsText(geom), bool_1, int_1, int_2, smallint_1, bigint_1, fl
) q)
+select '--- Exotic roundtrips ---';
+-- 2D Point not first geometry
+select 'E1', id, ST_AsText(geom) from ST_FromFlatGeobuf(null::flatgeobuf_t1, (
+ select ST_AsFlatGeobuf(q) fgb from (select true::boolean as bool_1, ST_MakePoint(1.1, 2.1)) q)
index 4d1b4b375..b95cd5f31 100644
@@ -21,3 +21,5 @@ P1|0|POINT(1 2)
P1|1|POINT(3 4)
+--- Exotic roundtrips ---
+E1|0|POINT(1.1 2.1)
Summary of changes:
postgis/flatgeobuf.c | 21 ++++++++++-----------
regress/core/flatgeobuf.sql | 17 +++++++++++++++++
regress/core/flatgeobuf_expected | 2 ++
3 files changed, 29 insertions(+), 11 deletions(-)
hooks/post-receive
