[postgis-tickets] [SCM] PostGIS branch master updated. 3.2.0beta1-31-g6cf2fba94
Thu Nov 25 08:53:16 PST 2021
the project "PostGIS".
       via  6cf2fba94a434e79d6526a6a5cfdb6057a91bff8 (commit)
      from  b24d7125a3b9de291bcc46d6d92721a66702f71c (commit)
revisions in full, below.
commit 6cf2fba94a434e79d6526a6a5cfdb6057a91bff8
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Thu Nov 25 08:52:53 2021 -0800
    Support PCRE2 where available and PCRE otherwise, closes #5019
diff --git a/configure.ac b/configure.ac
index 3532805b8..aa330ebf3 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1190,7 +1190,9 @@ AC_ARG_WITH([address-standardizer],
                     [Disable the address_standardizer extension])],
-HAVE_PCRE=no
+HAVE_PCRE1=no
+HAVE_PCRE2=no
+PCRE_SUPPORT="not found"
 ADDRESS_STANDARDIZER=""
 if test "x$with_address_standardizer" != "xno"; then
@@ -1209,42 +1211,74 @@ if test "x$with_address_standardizer" != "xno"; then
             AC_MSG_ERROR([you must specify a parameter to --with-pcredir, e.g. --with-pcredir=/path/to])
         else
             if test -d "$PCREDIR"; then
-                AC_MSG_RESULT([Using user-specified PCRE directory: $PCREDIR])
-                AC_CHECK_FILE("$PCREDIR/include/pcre.h",
-                            PCRE_CPPFLAGS="-I$PCREDIR/include"
-                            PCRE_LDFLAGS="-L$PCREDIR/lib -lpcre"
-                            HAVE_PCRE=yes
-                            ADDRESS_STANDARDIZER="address_standardizer"
-                        [AC_MSG_ERROR([Could not find header: pcre.h])])
+                AC_MSG_CHECKING([for PCRE in $PCREDIR...])
+                AC_CHECK_FILE("$PCREDIR/include/pcre2.h",
+                        PCRE_CPPFLAGS="-I$PCREDIR/include"
+                        PCRE_LDFLAGS="-L$PCREDIR/lib -lpcre2-8"
+                        HAVE_PCRE2=yes
+                        ADDRESS_STANDARDIZER="address_standardizer"
+                        AC_MSG_RESULT([found pcre2.h])
+                		AC_CHECK_FILE("$PCREDIR/include/pcre.h",
+	                        PCRE_LDFLAGS="-L$PCREDIR/lib -lpcre"
+	                        HAVE_PCRE1=yes
+                            AC_MSG_RESULT([found pcre.h])
+                            AC_MSG_RESULT([no])
+                			AC_MSG_ERROR(["Could not find PCRE header in $PCREDIR/include"])
             else
                 AC_MSG_ERROR([the --with-pcredir directory "$PCREDIR" cannot be found])
             fi
         fi
     elif test ! -z "$PKG_CONFIG"; then
-	PKG_CHECK_MODULES([PCRE], [libpcre], [
-                PCRE_CPPFLAGS="$PCRE_CFLAGS"
-                PCRE_LDFLAGS="$PCRE_LIBS"
+        PKG_CHECK_MODULES([PCRE2], [libpcre2-8], [
+                PCRE_CPPFLAGS="$PCRE2_CFLAGS"
+                PCRE_LDFLAGS="$PCRE2_LIBS"
-                HAVE_PCRE=yes
+                HAVE_PCRE2=yes
-                ADDRESS_STANDARDIZER=""
-                HAVE_PCRE=no
+                PKG_CHECK_MODULES([PCRE], [libpcre], [
+                    PCRE_CPPFLAGS="$PCRE_CFLAGS"
+                    PCRE_LDFLAGS="$PCRE_LIBS"
+                    HAVE_PCRE1=yes
     fi
+    if test "x$HAVE_PCRE2" = "xyes"; then
+        PCRE_SUPPORT="Version 2"
+        PCRE_VERSION=2
+    elif test "x$HAVE_PCRE1" = "xyes"; then
+        PCRE_SUPPORT="Version 1"
+        PCRE_VERSION=1
+    else
+        ADDRESS_STANDARDIZER=""
+        PCRE_SUPPORT="not found"
+        PCRE_VERSION=0
+        AC_MSG_RESULT([ADDRESS_STANDARDIZER support: disabled])
+    fi
     AC_SUBST([PCRE_CPPFLAGS])
     AC_SUBST([PCRE_LDFLAGS])
+    AC_SUBST([PCRE_LDFLAGS])
+    AC_SUBST([PCRE_VERSION])
 else
 fi
-AC_SUBST([HAVE_PCRE])
 AC_SUBST([ADDRESS_STANDARDIZER])
 CPPFLAGS="$PGSQL_CPPFLAGS $GEOS_CPPFLAGS $PROJ_CPPFLAGS $PROTOBUF_CPPFLAGS $XML2_CPPFLAGS $SFCGAL_CPPFLAGS $JSON_CPPFLAGS $PCRE_CPPFLAGS $CPPFLAGS"
@@ -1730,7 +1764,7 @@ if test "x$HAVE_PROTOBUF" = "xyes"; then
   AC_MSG_RESULT([  protobuf-c version:   ${PROTOC_VERSION}])
 fi
-AC_MSG_RESULT([  PCRE support:         ${HAVE_PCRE}])
+AC_MSG_RESULT([  PCRE support:         ${PCRE_SUPPORT}])
 AC_MSG_RESULT([  Perl:                 ${PERL}])
 AC_MSG_RESULT()
diff --git a/extensions/address_standardizer/Makefile.in b/extensions/address_standardizer/Makefile.in
index 502648f31..3a3632c69 100644
--- a/extensions/address_standardizer/Makefile.in
+++ b/extensions/address_standardizer/Makefile.in
@@ -55,7 +55,7 @@ EXTRA_CLEAN = sql/
 DOCS = README.address_standardizer
-PG_CPPFLAGS = @CFLAGS@ @CPPFLAGS@
+PG_CPPFLAGS = @CFLAGS@ @CPPFLAGS@ -DPCRE_VERSION=@PCRE_VERSION@
 SHLIB_LINK = @SHLIB_LINK@ @PCRE_LDFLAGS@
 EXTRA_CLEAN = usps-st-city-name.txt mk-st-regexp mk-city-regex test_main
diff --git a/extensions/address_standardizer/address_parser.c b/extensions/address_standardizer/address_parser.c
index 892b42c45..3e1c642bf 100644
--- a/extensions/address_standardizer/address_parser.c
+++ b/extensions/address_standardizer/address_parser.c
@@ -8,7 +8,6 @@
 #include "utils/builtins.h"
 #include "parseaddress-api.h"
-#include <pcre.h>
 #include <string.h>
 #undef DEBUG
diff --git a/extensions/address_standardizer/expected/test-standardize_address_1.out b/extensions/address_standardizer/expected/test-standardize_address_1.out
index 34e825809..65e1767bf 100644
--- a/extensions/address_standardizer/expected/test-standardize_address_1.out
+++ b/extensions/address_standardizer/expected/test-standardize_address_1.out
@@ -10,7 +10,7 @@ select * from standardize_address('us_lex'::text, 'us_gaz'::text, 'us_rules'::te
           | 123       |        |      |         | MAIN | STREET  |        |            |       | KANSAS CITY | MISSOURI |         | 45678    |     |
 (1 row)
-SELECT '#2981' As ticket, * FROM standardize_address('us_lex','us_gaz','us_rules', '1566 NEW STATE HWY, RAYNHAM, MA') ;
+SELECT '#2981' As ticket, * FROM standardize_address('us_lex','us_gaz','us_rules', '1566 NEW STATE HWY, RAYNHAM, MA');
  ticket | building | house_num | predir | qual | pretype |       name        | suftype | sufdir | ruralroute | extra |  city   |     state     | country | postcode | box | unit
  #2981  |          | 1566      |        |      |         | NEW STATE HIGHWAY |         |        |            |       | RAYNHAM | MASSACHUSETTS | USA     |          |     |
diff --git a/extensions/address_standardizer/parseaddress-api.c b/extensions/address_standardizer/parseaddress-api.c
index d5008c3f7..41efcf231 100644
--- a/extensions/address_standardizer/parseaddress-api.c
+++ b/extensions/address_standardizer/parseaddress-api.c
@@ -20,7 +20,16 @@
 #include <string.h>
 #include <ctype.h>
 #include <stdio.h>
-#include <pcre.h>
+#if PCRE_VERSION <= 1
+# include <pcre.h>
+# define PARSE_CASELESS PCRE_CASELESS
+#else
+# define PCRE2_CODE_UNIT_WIDTH 8
+# include <pcre2.h>
+# define PARSE_CASELESS PCRE2_CASELESS
+#endif
 #undef DEBUG
@@ -87,6 +96,7 @@ void strtoupper(char *s)
         s[i] = toupper(s[i]);
 int match(char *pattern, char *s, int *ovect, int options)
     const char *error;
@@ -101,10 +111,51 @@ int match(char *pattern, char *s, int *ovect, int options)
     free(re);
     if (rc < 0) return rc;
-    else if (rc == 0) rc = OVECCOUNT/3;
+    else if (rc == 0) rc = OVECPAIRS; // more matches than ovect can hold
     return rc;
+#else
+int match(char *pattern, char *s, int *ovect, int options)
+    int errorcode;
+    PCRE2_SIZE erroffset;
+    pcre2_code *re;
+    int rc;
+    pcre2_match_data *match_data;
+    PCRE2_SIZE *ovect2;
+    int i;
+    re = pcre2_compile((PCRE2_SPTR8)pattern, PCRE2_ZERO_TERMINATED, options, &errorcode, &erroffset, NULL);
+    if (!re) return -99;
+    match_data = pcre2_match_data_create(OVECPAIRS, NULL);
+    rc = pcre2_match(re, (PCRE2_SPTR8)s, strlen(s), 0, 0, match_data, NULL);
+    if (rc < 0) { // no match or error
+        pcre2_code_free(re);
+        pcre2_match_data_free(match_data);
+        return rc;
+    if (rc == 0) { // more matches than ovect can hold
+        rc = OVECPAIRS;
+    // copy the results out so we can free everything
+    // before returning
+    ovect2 = pcre2_get_ovector_pointer(match_data);
+    for (i = 0; i < rc; i++) {
+        ovect[2*i] = ovect2[2*i];
+        ovect[2*i + 1] = ovect2[2*i + 1];
+    return rc;
+#endif
 #define RET_ERROR(a,e) if (!a) {*reterr = e; return NULL;}
@@ -180,7 +231,7 @@ ADDRESS *parseaddress(HHash *stH, char *s, int *reterr)
     /* get canada zipcode components */
     else {
-        rc = match("\\b([a-z]\\d[a-z]\\s?\\d[a-z]\\d)$", s, ovect, PCRE_CASELESS);
+        rc = match("\\b([a-z]\\d[a-z]\\s?\\d[a-z]\\d)$", s, ovect, PARSE_CASELESS);
         if (rc >= 1) {
             ret->zip = (char *) palloc0((ovect[1]-ovect[0]+1) * sizeof(char));
             strncpy(ret->zip, s+ovect[0], ovect[1]-ovect[0]);
@@ -199,7 +250,7 @@ ADDRESS *parseaddress(HHash *stH, char *s, int *reterr)
     caregx = "^(?-xism:(?i:(?=[abmnopqsy])(?:n[ltsu]|[am]b|[bq]c|on|pe|sk|yt)))$";
     stregx = "\\b(?-xism:(?i:(?=[abcdfghiklmnopqrstuvwy])(?:a(?:l(?:a(?:bam|sk)a|berta)?|mer(?:ican)?\\ samoa|r(?:k(?:ansas)?|izona)?|[kszb])|s(?:a(?:moa|skatchewan)|outh\\ (?:carolin|dakot)a|\\ (?:carolin|dakot)a|[cdk])|c(?:a(?:lif(?:ornia)?)?|o(?:nn(?:ecticut)?|lorado)?|t)|d(?:e(?:la(?:ware)?)?|istrict\\ of\\ columbia|c)|f(?:l(?:(?:orid)?a)?|ederal\\ states\\ of\\ micronesia|m)|m(?:i(?:c(?:h(?:igan)?|ronesia)|nn(?:esota)?|ss(?:(?:issipp|our)i)?)?|a(?:r(?:shall(?:\\ is(?:l(?:and)?)?)?|yland)|ss(?:achusetts)?|ine|nitoba)?|o(?:nt(?:ana)?)?|[ehdnstpb])|g(?:u(?:am)?|(?:eorgi)?a)|h(?:awai)?i|i(?:d(?:aho)?|l(?:l(?:inois)?)?|n(?:d(?:iana)?)?|(?:ow)?a)|k(?:(?:ansa)?s|(?:entuck)?y)|l(?:a(?:bordor)?|ouisiana)|n(?:e(?:w(?:\\ (?:foundland(?:\\ and\\ labordor)?|hampshire|jersey|mexico|(?:yor|brunswic)k)|foundland)|(?:brask|vad)a)?|o(?:rth(?:\\ (?:mariana(?:\\ is(?:l(?:and)?)?)?|(?:carolin|dakot)a)|west\\ territor(?:ies|y))|va\\ scotia)|\\ (?:carolin|dakot)a|u(?:navut)?|[vhjmycdblsf]|w?t)|o(?:h(
 ?:io)?|k(?:lahoma)?|r(?:egon)?|n(?:t(?:ario)?)?)|p(?:a(?:lau)?|e(?:nn(?:sylvania)?|i)?|r(?:ince\\ edward\\ island)?|w|uerto\\ rico)|r(?:hode\\ island|i)|t(?:e(?:nn(?:essee)?|xas)|[nx])|ut(?:ah)?|v(?:i(?:rgin(?:\\ islands|ia))?|(?:ermon)?t|a)|w(?:a(?:sh(?:ington)?)?|i(?:sc(?:onsin)?)?|y(?:oming)?|(?:est)?\\ virginia|v)|b(?:ritish\\ columbia|c)|q(?:uebe)?c|y(?:ukon|t))))$";
-    rc = match(stregx, s, ovect, PCRE_CASELESS);
+    rc = match(stregx, s, ovect, PARSE_CASELESS);
     if (rc > 0) {
         state = (char *) palloc0((ovect[1]-ovect[0]+1) * sizeof(char));
         strncpy(state, s+ovect[0], ovect[1]-ovect[0]);
@@ -229,7 +280,7 @@ ADDRESS *parseaddress(HHash *stH, char *s, int *reterr)
         /* check if it a Canadian Province */
-        rc = match(caregx, ret->st, ovect, PCRE_CASELESS);
+        rc = match(caregx, ret->st, ovect, PARSE_CASELESS);
         if (rc > 0) {
             strcpy(ret->cc, "CA");
             // if (ret->cc) printf("  CC: %s\n", ret->cc);
diff --git a/extensions/address_standardizer/parseaddress-api.h b/extensions/address_standardizer/parseaddress-api.h
index a3773a431..2037ef6da 100644
--- a/extensions/address_standardizer/parseaddress-api.h
+++ b/extensions/address_standardizer/parseaddress-api.h
@@ -20,7 +20,8 @@ THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLI
 #include "postgres.h"
-#define OVECCOUNT 30
+#define OVECPAIRS 10
+#define OVECCOUNT 3*OVECPAIRS
 #ifdef USE_HSEARCH
Summary of changes:
 configure.ac                                       | 72 ++++++++++++++++------
 extensions/address_standardizer/Makefile.in        |  2 +-
 extensions/address_standardizer/address_parser.c   |  1 -
 .../expected/test-standardize_address_1.out        |  2 +-
 extensions/address_standardizer/parseaddress-api.c | 61 ++++++++++++++++--
 extensions/address_standardizer/parseaddress-api.h |  3 +-
 6 files changed, 113 insertions(+), 28 deletions(-)
hooks/post-receive
