[postgis-tickets] [PostGIS] #5007: dronie docker images for geos are failing expired cert
PostGIS trac at osgeo.org
Fri Oct 1 11:38:36 PDT 2021
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  Website Management, Bots
Component:  buildbots  |    Version:  master
 Keywords:             |
 The images that dronie uses were a casualty in LetsEncrypt as well
 https://letsencrypt.org/docs/dst-root-ca-x3-expiration-september-2021/
 as can be seen here: https://dronie.osgeo.org/postgis/postgis/2188/1/1
 Hoping just rebuild will do the trick, but I think I might need to change
 the base image as well.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5007>
