[postgis-tickets] [PostGIS] #5007: dronie docker images for postgis are failing expired cert
trac at osgeo.org
Fri Oct 1 18:00:17 PDT 2021
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: blocker | Milestone: Website Management, Bots
Component: buildbots | Version: master
Resolution: fixed | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
Upgrade image from trisquel:8.0 to trisquel:9.0
1) upgrade PG repo to bionic (as 9.0 is compatible with bionic)
2) Fix libjson-c-dev
3) Add PostgreSQL 12
3) Get rid of PostGIS 2.2 so EOL who cares
4) Added PostGIS 3.1
As noted in https://git.osgeo.org/gitea/postgis/postgis-
docker/commit/653a14120b0e1b3000e863ce92b06a4357198be9 and
docker/commit/bba9303ff1565ac570be53b1014621eed6729793
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5007#comment:2>
